Team Associated TC4
#6646
#6647
Originally Posted by jimbobmahua
This FT's top plate is modified from the one that comes standard in FT kit. Is it one that was made especially for the Vegas races? or is it one from another conversion kit?
Also an interesting blue alum 2-hole servo mount...
Oh yea, and anyone notice the shock caps...
#6648
Are those Yokomo shocks?
#6649
Whats the better purchase
Which would be the better aftermarket purchase?
Titanium Racing Ti- input shafts front and rear
Or the 3Racing 64 Titanium Rear Input Shaft & 64 Titanium Front Input Shaft
Thanks,
E
Thanks,
E
#6650
Originally Posted by seamus0g
The top deck in the picture has no "wings" off the diff case top for the stiffener posts. No idea if it is a different thickness, etc. Just interesting that it is different than what comes in the kit...
Those are Associated shocks with what looks like Tamiya shock caps...interesting.
#6651
They are Associated shock bodys and Yokomo caps
#6652
Two strikes--LOL
Those are associated shocks and caps.The caps are a new item that we got in vegas. I would think they will be out very soon!
Walter
Walter
#6653
Originally Posted by walterhenderson
Two strikes--LOL
Walter
Walter
#6654
Did anyone else loose the pics of that FTTC4 above?
Mine is gone, any ideas?
Thanks and God Bless
#6655
I will guess on that one-- Most likly a std top plate with the standoff ears cut of for rubber tire racing.
#6656
Ok heres what I tested this weekend with the BMI chassis.
Front
Purple springs 40wt 2piston
Camber 3 hole 2 washers silver ball stud
plaid fronts
4Deg castor
1 shim in rear 0 shims in front
smallest sway bar
Rear
Gold springs 40wt 2 piston
Camber 4 hole no washers black ballstud
Losi rear zero deg hubs inside hole no washers
Purple rears
Std wheel base front and rear
2.5deg toe
1 shim under front and 1 shim under rear
smallest sway bar
I didnt really have time to get a carpet body on so this was with a Mazda 6. Track is really small. 8 second lap times very tight as well. Basically just a 1/12 scale track but I wanted to play a little. Next month I will be able to put a little more time in. Question for you guys running the losi Hubs. Does it matter that now the camber link is angled so far back. I wouldn't think so but I am not 100% sure.
Front
plaid fronts
4Deg castor
smallest sway bar
Rear
Purple rears
2.5deg toe
smallest sway bar
#6657
Evenin all,
Does anybody know the part number for the yok shock caps that people are usin on the TC4, and do you have to run bladders on them?
Cheers
Crashmaster
Cheers
Crashmaster
#6659
Originally Posted by jt6
They come with the bladders.....#YS-8D
Crashmaster
#6660
