Like Tree26Likes
Old 10-01-2005, 11:22 PM   #6511
beerbarron's Avatar
Is it possible to have a center one way on a TC4?
beerbarron is offline   Reply With Quote
Old 10-02-2005, 05:01 AM   #6512
Trader Rating: 21 (100%+)
Default gearing
Originally Posted by xDeeDubYax
LOTUS1: Im assuming you are running foams, and if so, pinion choice will vary greatly with tire/track size. If you choose a 100 tooth spur (64 pitch) for stock class (Monster Stock motor), you can run a pinion from 30-36 to start. 19T (C2 locked endbell) is geared a little higher than stock, in GENERAL, 2 teeth (64pitch) more than a stock motor. There are alot of variations with gearing, its always best to ask local racers first, then start on the lowside and work your way up.
- DaveW
Thanks.Will work from there.Mario.
lotus1 is offline   Reply With Quote
Old 10-02-2005, 08:38 AM   #6513
lem2's Avatar
Default Maiden Run!
The FT-TC4 is a great car! I run the one way set up with a diff. and stif with all the stand offs and the center plate.
Struggled a little bit with my set up during qualifying, and ended 2nd in B a little tweaking got me 1st in the B. The car ran very smoothly! I think breaking in the gears helped a lot! Ran it for 30 minutes without any load!
and also the car ran great without the sway bars in stock.
3Racing parts really look good, but the quality of the Knuckles and rear hub needs improvement. Because the bearings is a little loose inside, like, you do not struggle to install it-- it just goes right thru.
first pic is the breaking in of the gears, 2nd is my TC4 at my very messy pit table! the last picture is the FT of ROBORAT, his pit table is more clean and organized than mine.
Hope all your races went good this weekend!!
beerbaron: Yokomo came out with a oneway shaft for the SD/CGM/LCG/SDW hopefully they'll come out with one for the TC4 since they made a CF shaft also for the TC4. If your in a hurry-- GPM makes a one way shaft for the TC3, which, i assume will also fit the TC4.
Team Associated TC4-brkin.jpg   Team Associated TC4-imgp0125.jpg   Team Associated TC4-r1.jpg
lem2 is offline   Reply With Quote
Old 10-02-2005, 09:28 AM   #6514
Jsaves's Avatar
Default Yok Bladder caps and bladders
Have any of you guys that run the yok bladder caps and bladder with the foam spacers above the bladder? I know DAVE W. did it I was wondering if anyone else?
Jsaves is offline   Reply With Quote
Old 10-02-2005, 09:29 AM   #6515
Jsaves's Avatar
Default Sorry
With out the foam spacers above the bladders.
What are your findings?
Old 10-02-2005, 01:03 PM   #6516
Super Moderator
Grizzbob's Avatar
Something else to add, actually with the FT car you can go higher than a 36 tooth pinion with a 100 tooth spur, there appears to be room for as big as a 40 tooth(there is most DEFINITELY more room for pinion adjustment on that motor mount that on the older cars), maybe even more, so I think a 100 tooth spur should be fine....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 10-02-2005, 07:25 PM   #6517
Default Grizzbob,thanks
Got another question....I assembled the front input shaft following the instructions.When I go to install it ,the spacing between the bearings doesn't seem to be enough.It doesn't fit snug in the cradle.Playing around with the shims,it seems if I remove one of the front ones the bearing spacing is right but,the drive pinion rubs on the transmission housing.Any ideas or fixes?Removed all flashing and things seem seated right on the shaft,I'm a bit confused.Thanks in advance,Mario.
Old 10-02-2005, 07:59 PM   #6518
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
finally got to run my ride last weekend! all i can say is this car is dialled! will have to do just a few minor tweaks but generally the car is awesome! i miss shaft cars. the rip is just amazing. the car also feels very balanced and transitions very well. can't wait to run it again this weekend.
here are some pics ..... my fttc4 with a Ride MKIII stratus body.
Team Associated TC4-r1.jpg   Team Associated TC4-r3.jpg   Team Associated TC4-r5.jpg
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 10-02-2005, 08:02 PM   #6519
tc3 racer sc's Avatar
Default hvng trouble with gear mesh onn ftc4
i ran my fttc4 today for the first time and had problem with gear mesh and adjusting the motor, what can i do i may chnge from 48 pitch to 64 pitch
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 10-02-2005, 09:27 PM   #6520
Super Moderator
Trader Rating: 17 (100%+)
Yes you can run a center 1 way....I actually like running it.
Tekno | JConcepts | ProTek RC | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 10-02-2005, 11:01 PM   #6521
xDeeDubYax's Avatar
ROBORAT: Sweet pics.
BEERBARON: Yes. And i was going to say to ask BOBBARRY which center one way he has and where he got it, i have never run one to be able to answer how well it works. My experience is with the HD AE front one-way setup.
GRIZZBOB: You are right, i have tried a 39/100 on a 19T before, and still had room for adjustment. I just cant imagine using anything above a 36 on most indoor carpet tracks with that motor (MS). The highest i have run is a 35, and my tires were under 55.5mm. The car was still a bit off on rollout for our track, but the 36 with that spur was definitely too much. That monster motor reaaaly likes to spool... at least how i build 'em anyways. Its got that V-TEC baby! LOL
JSAVES: You have return PM.
LOTUS1: Have you tried using one of the kit shims between the bearing and the cup, and one kit shim between the bearing and the gear? For it to rub the case sounds like you might have a bad gear. (?) Have you tried installing it in the rear gear case to see if the problem is the same? If so, then it is probably the gear... try swapping the rear assembled layshaft into the front gearbox and see if that gear rubs the case, if so then it may be that the front case is bad. After my front/rear layshaft is installed, there is a total of 1/32 of play for the shaft to move back and forth in the bearings (gearcase assembled, both halves mated), the plastic diffs have one shim on the long side, and its the reverse for the steel diffs. I just make sure there is a little play in the mesh between the diffpinion/diffgear when they are at their closest, kinda like when you adjust motor pinion/spur mesh. I know this may be different from one car to the next with tolerances as they are... but it may give you a place to start. Come to think of it... i dont remember what the stock setting (shims) is from the manual, i have built so many TC3/4's that i didnt even crack the manual when i built my FT... i just built it like i did the others.
Keep us posted...
- DaveW
xDeeDubYax is offline   Reply With Quote
Old 10-03-2005, 12:35 AM   #6522
bhambrent's Avatar
Looks like Barry has new rear hubs on his FTTC4. Anyone know more about them?
Thanks,
http://www.rc50.com/modules.php?name...lbum=13&pos=16
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 10-03-2005, 12:58 AM   #6523
RCknight's Avatar
Default I would tell you those are losi hubs.
I run the same thing.
RCknight is offline   Reply With Quote
Old 10-03-2005, 01:02 AM   #6524
Soviet's Avatar
Losi?
BTW...whats the story on a potential FT TC4 conversion kit for us who bought the Team TC4 (actually TC3.5 )
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 10-03-2005, 02:57 AM   #6525
rc-jammer's Avatar
Come on then you hardened TC4 drivers, lets have some feedback if you may.
I've been running a TC4 Team all this year and have done very well with it (if I do say so myself). I'm considering the TC4FT (as well as other cars) but I want to know if people who have got on with the TC4 Team kit what they think when you went over to the TC4FT. Was it better, easier to drive, faster etc etc.
Thanks for the feedback
rc-jammer is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
