Like Tree18Likes
Old 09-29-2005, 07:34 PM   #6496
Trader Rating: 194 (99%+)
What have some of you guys done to try and get rid of the chatter from the front CVD's when the wheels are full lock?
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 09-29-2005, 09:47 PM   #6497
vegas setups?
carpet foam setups?
G-Dizzle is offline   Reply With Quote
Old 09-30-2005, 03:34 AM   #6498
imr
imr's Avatar
Don't drive full lock. The car doesn't need it.
imr is offline   Reply With Quote
Old 09-30-2005, 03:55 AM   #6499
xDeeDubYax's Avatar
DODGEGUY: IMR is right, you shouldnt need full lock to get the car around the track. You can also add some synthetic 0-5W30 oil... a drop to each joint of each CVD, and it will help with the noise, and keep the parts in better shape. Use a synthetic, regular oil/grease will not last as long.
- DaveW
xDeeDubYax is offline   Reply With Quote
Old 09-30-2005, 04:02 AM   #6500
lem2's Avatar
Default Is this roar legal
I have converted my motor wiring to this. Is this okay?
It's easier to service the motors during a race.
I have not connected the bullet connectors and slid the wire thru so you can see.
lem2 is offline   Reply With Quote
Old 09-30-2005, 04:28 AM   #6501
Originally Posted by PaulC2K
Ey up mate, heard you'd got the FT last week, still in shock that ive bought one (well, team kit) at the moment!!
I did exactly the same thing with the Tamiya shocks, tried a few things to see what worked best, and found that if you put the AE shock bottoms and spring retainer then the whole unit fits on perfectly. extended the shock length about 3mm to allow it to use the droop i want to put on there and thats about it.
Also, im guessing that was you phoning me half a dozen times on Monday lunchtime, wasnt going to get up to answer it because i had a nasty migraine and didnt recognise the phone number (guessing its a PDQ line?).
Any chance of you getting hold of a AE Triangle alum block from Morley for a good price? Got the Circle, Square, 2.5 & 3.0 ones coming from the states today (5 each, bargin!) but the Triangle wasnt in stock and i already have the 2.0 one.
Anyway, cya at Wirral in 10 days, gonna pester you about those 3800s also, was hoping to have a pack of eXpress cells to try over the winter but not heard from them about that.
Sorry it took so long to reply didnt even realise you had put anything up here.
Went to Morley to see if he has the block you want but they dont have it in stock.
With the Tamiaya Shockers there is another mod you can do that is even better but il run through that with you at wirrel mate.
The IB3800 are awsome and a big thanks goes out there to Colin at CS-Racing and also EA Motorsports.
Nick Simpson is offline   Reply With Quote
Old 09-30-2005, 07:15 AM   #6502
I will post my vegas setup this weekend. It was very good when the traction was very high.
Walter
walterhenderson is offline   Reply With Quote
Old 09-30-2005, 12:08 PM   #6503
seamus0g's Avatar
Thanks Walter!
seamus0g is offline   Reply With Quote
Old 10-01-2005, 05:23 AM   #6504
beerbarron's Avatar
Can I just jump in here and ask how everyone likes the FT so far as compared to the other top cars out now? I am using a XXXSG still and need a car designed for the new batteries and stock racing with foams on carpet, primarily. What are the cars strenghts (handling/tuning/durability) and weaknesses as well. Thanks...
beerbarron is offline   Reply With Quote
Old 10-01-2005, 06:38 AM   #6505
PaulC2K's Avatar
Hey Nick,
Think i might know of 2 tips from the grinch already, but i'll be all ears come sunday anyway.
I should be able to get the triangle blocks fairly soon anyway so dont worry bout it, its a light item so its not going to cost much to have it shipped over, could probably ship it 2-3 day and have the total cost come under the UK price anyway esp as it cant be taxed as its under 16 value.
Also, i thought the cells were br00d powah, either of them should be top draw anyway.
PaulC2K is offline   Reply With Quote
Old 10-01-2005, 01:06 PM   #6506
Trader Rating: 21 (100%+)
Default Gearing question
Putting the new baby together.Got a couple of gearing questions.1...Gonna use 64 pitch gears,For stock and or 19 turn,What is a good spur to start with?2 Running a fairly tight carpet course,for stock we have to use the Trinity monster handout motor,any ideas on a start point for the pinion?And last,pinion for 19turn?Thanks.
lotus1 is offline   Reply With Quote
Old 10-01-2005, 02:51 PM   #6507
Super Moderator
Grizzbob's Avatar
I've been very happy running a 100 tooth spur on mine, seems good all-around for both stock & 19 turn, & while the fit for it is VERY tight, it does fit without rubbing anything(& I know why you asked that because it will be VERY hard to change out if you don't like it, or if it strips)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 10-01-2005, 07:27 PM   #6508
Default gearing
Grizzbob,Thanks.That kinda was what I was thinking myself.you know I don't want to be replacing that often.lol.Was considering a 96,but I think the 100 is better also.Thanks again,Mario.
Old 10-01-2005, 09:43 PM   #6509
xDeeDubYax's Avatar
LOTUS1: Im assuming you are running foams, and if so, pinion choice will vary greatly with tire/track size. If you choose a 100 tooth spur (64 pitch) for stock class (Monster Stock motor), you can run a pinion from 30-36 to start. 19T (C2 locked endbell) is geared a little higher than stock, in GENERAL, 2 teeth (64pitch) more than a stock motor. There are alot of variations with gearing, its always best to ask local racers first, then start on the lowside and work your way up.
- DaveW
Old 10-01-2005, 10:19 PM   #6510
A roll out of 1.0 is a good starting point on the Monster. If you are running IB's you may need to adjust for the extra voltage.
www.donatelife.net
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
