Like Tree38Likes
Old 09-27-2005, 07:01 PM   #6481
PaulC2K's Avatar
Originally Posted by Nick Simpson
I run the best shocker in the business on my FT TC4 which is the Tamiya shocker and all iv done is add the BOTTOM of the TC4 shocker to give it little bit more length.This also lets me use standard associated springs.
Ey up mate, heard you'd got the FT last week, still in shock that ive bought one (well, team kit) at the moment!!
I did exactly the same thing with the Tamiya shocks, tried a few things to see what worked best, and found that if you put the AE shock bottoms and spring retainer then the whole unit fits on perfectly. extended the shock length about 3mm to allow it to use the droop i want to put on there and thats about it.
Also, im guessing that was you phoning me half a dozen times on Monday lunchtime, wasnt going to get up to answer it because i had a nasty migraine and didnt recognise the phone number (guessing its a PDQ line?).
Any chance of you getting hold of a AE Triangle alum block from Morley for a good price? Got the Circle, Square, 2.5 & 3.0 ones coming from the states today (5 each, bargin!) but the Triangle wasnt in stock and i already have the 2.0 one.
Anyway, cya at Wirral in 10 days, gonna pester you about those 3800s also, was hoping to have a pack of eXpress cells to try over the winter but not heard from them about that.
PaulC2K is offline   Reply With Quote
Old 09-27-2005, 07:54 PM   #6482
may be it's a silly question....
but i would like to ask if yokomo's SD suspension arm block fit to TC4?
tsuiyuen is offline   Reply With Quote
Old 09-27-2005, 11:52 PM   #6483
spanish armada's Avatar
Default tc3 to tc4
Can parts removed from a tc3 be used to build a tc4 using the tc4 coponent set PN asc31042?
spanish armada is offline   Reply With Quote
Old 09-27-2005, 11:55 PM   #6484
I am going to order the FT TC4 at the LHS tomorrow. Which aluminum blocks come with the car?
THE GOOCH is offline   Reply With Quote
Old 09-28-2005, 12:00 AM   #6485
bhambrent's Avatar
Is there a FT conversion kit for the TC4?
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 09-28-2005, 02:48 AM   #6486
S_fender's Avatar
It comes with all the aluminium blocks (X block is the 2.5)
Yes there will be a conversion kit but I don't know when.
S_fender is offline   Reply With Quote
Old 09-28-2005, 09:38 AM   #6487
Aries326's Avatar
Trader Rating: 19 (100%+)
Not from Team Associated (that I know of) but you can get a carbon fiber kit from BMI or from 3Racing.
http://cgi.ebay.com/3RACING-SSG-GRAP...QQcmdZViewItem
Aries326 is offline   Reply With Quote
Old 09-28-2005, 09:45 AM   #6488
AM03GT's Avatar
there is definitely going to be an FT conversion...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 09-28-2005, 09:51 AM   #6489
bhambrent's Avatar
I have the BMI already.
I just did not know about the FT conversion kit.
Thanks,
Old 09-28-2005, 04:49 PM   #6490
anthony390's Avatar
Send a message via AIM to anthony390
hey i was wondering if someone here can help me... if the IRS Big "DAWG" Bones with the pin cushions for the tc3 may be used for the tc4 because the braces barly touch the outdrives and if i would install it, would it hit the braces?
thanks
anthony390 is offline   Reply With Quote
Old 09-28-2005, 05:24 PM   #6491
vegas setups?
carpet foam setups?
G-Dizzle is offline   Reply With Quote
Old 09-28-2005, 05:33 PM   #6492
xDeeDubYax's Avatar
ANTHONY: The IRS pincushions will hit the threads of the long ballstuds, and the plastic TC4 ballstud mounts. They are really easy to trim, first the plastic part of the pincushion with an XACTO, and then the steel pin part with a cutoff wheel and a dremel, after it has been installed/assembled. Use a pin in a regular dogbone as a template for length.
- DaveW
xDeeDubYax is offline   Reply With Quote
Old 09-28-2005, 06:32 PM   #6493
anthony390's Avatar
i installed the short ball studs and can i just shave some off the braces where the ball stud go into?
Old 09-29-2005, 03:29 PM   #6494
xDeeDubYax's Avatar
ANTHONY: Im sure you could, anything is possible, but it would seem to me you would want to leave as much material there as possible for strength. If you notice on the plastic braces, when you thread the ballstuds in place, it makes hairline cracks in the plastic... little white lines that are hard to see. I have never had one break, but have seen others break. To remove more plastic might make the issue worse... i guess youll have to try it and see.
- DaveW
Old 09-29-2005, 03:39 PM   #6495
SMcpot's Avatar
Trader Rating: 22 (100%+)
If anyone's looking for a mint Team TC4 (only raced once), please check out my post in the For Sale forum
http://rctech.net/forum/showthread.php?t=85637
SMcpot is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
