Like Tree60Likes
Old 09-26-2005, 02:17 PM   #6451
RandomFellow's Avatar
Originally Posted by Jsaves
Hey Guys, just got a great birthday gift of a new FTTC4, what a great wife I have.
Any way how much sanding or file do I need to do and to what?
Is there some things I need to do in my build that the directions do not say?
The kit carpet set up is kind of close to Mike B's winning Snow Birds. Will
Mike's set up work on med to high grip carpet with the FTTC4?
Thanks for the answers.
God Bless
The latest XRC has a complete article of building tips for the FT TC4.
RandomFellow is offline   Reply With Quote
Old 09-26-2005, 02:52 PM   #6452
dawgmeat's Avatar
Default Leaky Shock
I've built the shock as per the instructions and only race the car twice and the shocks are leaking , now I've owned a 415 so the TFR shocks are what I consider tha best in the bunsiness. I love my FT TC4 and I'm willing to tuff it out with upgrades.
1.Aluminum shock caps $12.00
2.Hard shock bodies $20.00 2 each
3.unobtainum shafts $12.00 2 each
or
1.TRF shocks $65.00
2.Yokomo shock retainers so I can use TC4 springs
$10.00
Can I some one help me out?
dawgmeat is offline   Reply With Quote
Old 09-26-2005, 03:14 PM   #6453
Trader Rating: 18 (100%+)
or
1.TRF shocks $65.00
$10.00
Just buy Yokomo part# YS-8D Yokomo bladder shock caps and you are done. If you want some extra tuning parts buy some Rayspeed bladders for your shocks. Buy the "Hard Anodozed" shock bodies when you are looking for some "bling". The blue shock bodies work fine. Don't forget to take the volume compensating foam off of the bobbin when you put the bladder caps on.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 09-26-2005, 03:49 PM   #6454
dawgmeat's Avatar
thanks
Old 09-26-2005, 04:22 PM   #6455
or
1.TRF shocks $65.00
$10.00
I run the best shocker in the business on my FT TC4 which is the Tamiya shocker and all iv done is add the BOTTOM of the TC4 shocker to give it little bit more length.This also lets me use standard associated springs.
Nick Simpson is offline   Reply With Quote
Old 09-26-2005, 06:44 PM   #6456
Jsaves's Avatar
Default Thanks
Thanks Random Fellow and J_P for the helpful info.
God Bless
Jsaves is offline   Reply With Quote
Old 09-26-2005, 11:18 PM   #6457
Diggity's Avatar
Trader Rating: 29 (100%+)
Default TC4 Conversion Kit!!
Hello to everyone, This is Damon from Diggity Designs. Our webpage has been updated and will continue to be in the comeing months so check it out. If you are looking for a killer conversion kit for your TC3 or TC4 then check out our XLR8 conversion kit. Its all tricked out with graphite and aluminum, The car is perfectly balanced with 4 and 2 battery set-up, very tunable for different racers so check it out. Very Low center of gravity, new suspension geometry, new arms, etc.. Its basicly a new car.. It has been very fast in Michigan and Arizona!! Let me know if you have any suggestions, thanks.
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.teamscreamracing.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
Old 09-27-2005, 02:08 AM   #6458
180sx's Avatar
so i cantr just put TRF shocks on a standard tc4?
180sx is offline   Reply With Quote
Old 09-27-2005, 03:54 AM   #6459
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default High Quality Video Mod Touring Car
F.Y.I.
High Quality Video ( Mod Touring Car )
It's about half way down enjoy! It will say click here.
It also has video's of Barry Baker(FT TC4),and Nicholas Lee (TC4) @ the Asian Reedy races.
http://www.precisionrc.com/
RED-LINE M03 is offline   Reply With Quote
Old 09-27-2005, 09:11 AM   #6460
dawgmeat's Avatar
Default Graphite shafts
No one seem to sell the Team bomber or RCmanix shafts any more, I will play top dollar if someone is looking to sale
Old 09-27-2005, 10:03 AM   #6461
Trader Rating: 21 (100%+)
Default Rear Toe
Got a question(probably one of many before I'm thru).Just starting to build my FTTC4,the instructions call for the X-3.0 block,The problem is the one in the kit is the X-2.5.Anyone know if this is a mistake or a running change?Thanks.
lotus1 is offline   Reply With Quote
Old 09-27-2005, 10:25 AM   #6462
lem2's Avatar
Was looking for those also. Will end just end up with the Yokomo Graphite Shaft for the TC4! At least its color blue.
lem2 is offline   Reply With Quote
Old 09-27-2005, 10:56 AM   #6463
The TRF kits come with new ball studs that fit the TRF ends. The screw threads are just a bit larger than the stock TC4 parts. However, I have installed them with just a bit of extra effort with no ill effects (like cracked suspension arms ;-). Once you install these ball studs, you likely cannot go back to the stock ball studs without replacing the suspension arms and shock towers (since the holes are now enlarged). So long as you are committed to the TRF shocks, though, this seems to work just fine.
Ira
iblumberg is offline   Reply With Quote
Old 09-27-2005, 11:03 AM   #6464
The Teacher's Avatar
Trader Rating: 48 (100%+)
dawgmeat, what's wrong with using the graphite shaft from the TC3?
The Teacher is offline   Reply With Quote
Old 09-27-2005, 11:18 AM   #6465
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
The TC3 and TC4 drive shafts are a little different and take some work to make them fit.
ST Racing Concepts (STRC)
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
