Team Associated TC4
#6436
Originally Posted by Skip109
The rolls are sitting on the track what do you think your are hiding?
even with my nunchuck skillz I am no match for you/
very observant young grasshopper
#6437
Originally Posted by xDeeDubYax
MARK: The black foam Yok supplies changes the bound/rebound of the bladder. In my use, i found the black bladder foam installed in all four reduced traction overall on asphalt, and reduced steering on carpet. I liked the bladder caps best without the foam insert. On my AE shocks i tried both with and without the foam around the bobbin, and the only difference i noticed was the shocks were easier to bleed and rebuild without the foam on the bobbin.
- DaveW
- DaveW
and
What if we maintain the foam and use the bladder and yokomo caps? or maintain the foan and just use the yoke caps?
#6438
Originally Posted by imr
setup advice asked.
I run on carpet with sorex28 on a tight track.
The car feels very good at this moment, the only problem I have is when I go into the turn at the end of the straight at full speed, the rear is that little unstable.
Not very much, but enough to loose the rear sometimes.
19t motor
front copper spring
rear gold spring
40 wt around
1,5° camber front
1,75° camber rear
0° toe in/out front
3° toe in rear
4° caster
no one-way or spool.
camber links as in the manual.
Please setup tips with the standard pieces, so no ultra design changes.
Thanks alot!
19t motor
front copper spring
rear gold spring
40 wt around
1,5° camber front
1,75° camber rear
0° toe in/out front
3° toe in rear
4° caster
Thanks alot!
#6439
A oneway on carpet? I thought that was a big no no.
#6440
New FTTC4
Hey Guys, just got a great birthday gift of a new FTTC4, what a great wife I have.
Any way how much sanding or file do I need to do and to what?
Is there some things I need to do in my build that the directions do not say?
The kit carpet set up is kind of close to Mike B's winning Snow Birds. Will
Mike's set up work on med to high grip carpet with the FTTC4?
Thanks for the answers.
God Bless
God Bless
#6441
#6442
Who is running the TC4 in the 2005 International Indoor Championships @ Las Vegas besides Baker? I am curious how the car and driver finished in that race.
#6443
Jsaves: As with any carbon chassis. File the battery slots to get battery to sit lower, and also keep them from gettin cut by the carbon. Take some sand paper and sand the slot where the tape will go. Try to make this a round as possible where the tape will be going through the chassis. If not, the tape will be cut in the event of a crash.
#6444
FT TC4 & BMI TC4 Performance Comparison
Hi, I do not intend to start any flame war here or anything, this is purely an inquiry. For those who have had the BMI TC4 and got the chance to own the new FT TC4, any similarities/differences in handling? Which car is more dialed/spot on (considering both chassis have the same settings)? They new TC4 looks really nice and I was wondering if it also has high praises in the handling department. I used to run a BMI TC4 and I really liked it alot, I had to give it up for a JRXS and now, when the TC4 came out, I don't mind owning a shaft car again. Any info will be greatly appreciated.
#6445
Similar problem with the Parma bumper
Originally Posted by andrewdoherty
Alright If youve followed my last few posts trying to figure out my tire coning problems youre gunna love this . . .I think I finally figured it out. It wasn't my camber and it wasn't my set up (although in the process I did get a set up I like much better. Thanks Bob Barry) I replaced the stock bumper with a p-dub bumper and I have put it through its paces. I have "used" the bumper so much that it has compresed (what can I say . . .I am a rookie). With the steering turned 100% either way just the outside third of the foam rubs the foam bumper. I didn't notice because I ran rubber tires with the p-dub bumper one time and there was already wear marks on the bumper. You may have to simulate this on your car to get what happened. Thanks for all the thoughtful replys. I am hoping to gain some corner speed once I remove the bumper. I also am hoping to gain some speed with this new set up. I will keep y'all posted.
Andrew
Andrew
Ira
#6447
I was trying to find that out myself on how it did but not getting much info.
#6448
Originally Posted by RED-LINE M03
Does anybody know how the new FT TC4 did in Vegas?????
They had the audio playing over the web @ my local hobby shop.
But I was to busy racing on Saturday to listen in.
Thanks,
E
Thanks,
E
Not sure about anyone else.
#6449
anyone have a pic of Barrys car or anyone else on the team? Maybe from the vegas race?
