Like Tree31Likes
Old 10-18-2004, 08:44 PM   #631
Default started to build mine and...
all I have left are the shocks. Who ever is in charge of quality control should be fired! Hinge pin too long and I had to cut it shorter, silver ball stud hexes were not deep enough and I could not get the hex head into it, and no treadlock included. Frustrating to say the least and I won't have it up and going. Not much room in the cvd end and diff. Other than that the car is better than the TC3 and I did not have to sand anything. I would feel bad for any new person in the hobby putting together their first TC. I can't wait to get it to the track.
Nightbreed is offline   Reply With Quote
Old 10-18-2004, 09:32 PM   #632
bubbles's Avatar
That is odd. My manual had the shocks as the first bag, and first step to building the car... I noticed there was one ball stud with metal burrs still in the hex, but hammaring the stud onto the hex driver with a wheel wrench handle solved my problem...
bubbles is offline   Reply With Quote
Old 10-18-2004, 10:35 PM   #633
Kyew's Avatar
Originally posted by Charlie O
Did anyone that built the car yet feel that the material is graphite! i swear when i was cutting off excess pieces of the A-arms, & chassis braces it sure seemed like graphite to me, looks like it to,i even took the excess parts trees and tried to break them when they did, they snapped like graphite, if not then it is some damn good work with plastic!
heh heh. it's not graphite. just weigh your TC4 and you'll know............
all we have to decide is what to do with the time that is given to us.......
Kyew is offline   Reply With Quote
Old 10-18-2004, 10:39 PM   #634
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by bubbles
I have to admit, I LOVE the CVD bones. I ran four runs on my car with a One-Way, and I had no problems. On my TC3, I could barly make one run with aluminium CVD bones and not bend them. The drive shaft is also VERY solid, it doesn't seem like it will ever bend! The suspension blocks look extreemly durable, and provied smooth, free suspension action. In short, I love my TC4!
Good news
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 10-19-2004, 01:34 AM   #635
I cant believe Associated diddn't include the swaybar mount, so people could "at least" have a way to run the car with their TC-3 swaybars.........Hmmm.....should be real fun to drive in modified without them....... Does anyone know if they're available seperatly yet?...if so....where?........thanks in advance
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 10-19-2004, 02:03 AM   #636
what hex drivers will i need to buy to put this car together? will the front one ways and spool from the tc3 work on the tc4.
Cheers,
Mossie
Mossie is offline   Reply With Quote
Old 10-19-2004, 03:34 AM   #637
Cheers,
Mossie
THe Spool and One way will work from the TC3..and the hex driver sizes you will need are the following..
.050
2mm
1/16
3/32
-Dave
Old 10-19-2004, 08:03 AM   #638
Hey guys, do you need to dremel down any parts to create enough clearance for foams?
TPJ International
071crazy is offline   Reply With Quote
Old 10-19-2004, 08:17 AM   #639
51
51's Avatar
You may need to grind down the spindles, but I'm not sure. The best person to ask would be Blackstock on his thread...
51 is offline   Reply With Quote
Old 10-19-2004, 08:33 AM   #640
28 mm foams will rub the shocks in the front when u turn...i had some tamiya wheel shims, and used those to shim the wheels out some, and it seems to work, only problem is, ur makin a setup change right away....never knowing what it would be without the shims, well, i wont. one shim per wheel worked, and i think they were 1mm shims
as far as tools for the car go, i used the losi standard allen set, and nut driver set...that worked fine for me, along with help from the associated plastic tools
punkboy is offline   Reply With Quote
Old 10-19-2004, 08:37 AM   #641
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
So you selling that Pro4 you have!!!
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 10-19-2004, 08:38 AM   #642
haha
no
Old 10-19-2004, 09:09 AM   #643
Charlie O's Avatar
Default Re: started to build mine and...
The hinge pins for the rear are longer than the ones in the front you just put them on wrong like i did!
Charlie O is offline   Reply With Quote
Old 10-19-2004, 02:40 PM   #644
Default That may be the case Charlie...
but I'm to lazy to check for sure. Did anyone shim up the car? I think there is too much slop in the axles, arms and wheel hubs. Did anyone elses kit come with axle shims? Mine did not. So far, I put one shim in the wheel axles, I could not deal with it. I really like how free the drive train comes. I ran it for a few seconds and it spins very, very nice. I had to cut some of the ear off both sides of my KO servo and I had to dremel the chassis to make my good servo saver work. Just heads up if you have a KO servo. Anyone know when the TF parts are coming?
Old 10-19-2004, 02:43 PM   #645
Default Re: That may be the case Charlie...
Anyone know when the FT parts are coming?
November some time ...??? I think
-Dave
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Joe Maxey
