Like Tree36Likes
Old 09-19-2005, 07:45 PM   #6331
lem2's Avatar
Originally Posted by TPhalen
Actually, lem2, we DO sell 6 deg Caster Blocks....part #31018. FYI.
TPhalen,
Got it!! Just called the our LHS and it will arrive by next week.
Does AE plan to make a battery hold down plate for the FT-TC4?
Thank you! Can't wait to run my TC4! Lem
lem2 is offline   Reply With Quote
Old 09-19-2005, 08:25 PM   #6332
Super Moderator
Trader Rating: 17 (100%+)
Andrew hold your car up and compress the shock. See how much camber change you are getting. It sounds like you are either wayyyy off in setup and your over driving the car or something is binding up and causing the suspension to remain completly extended. Check your droop and shocks as well. Make sure that nothing is preventing your shocks from compressing. If the car went into the turns hard enough and the shocks were not compressing you could "wheel it" through but it will not be fast and it will cause all kinds of tire issues. I would really stop and look for something totally off the wall and stupid. If all else fails pull the shocks off and just go over the suspension with out them on there. maybe even try switching the front and rear shocks just to see if it helps the problem.
Hope I can give ya at least an Idea as to whats wrong.
Bob
Tekno | JConcepts | ProTek RC | BOOMrc
Bob Barry is online now   Reply With Quote
Old 09-20-2005, 05:39 AM   #6333
xDeeDubYax's Avatar
ANDREW: Do what Bob said, make sure everything is kosher. After looking at the setup, i would make a few changes. You have the suspension mounts as low as they can go, and still have anti-dive, but the camber link is trying to give you a ton of camber change. On the inside of the front camber link, use a black ballstud, no shims, inside hole closest to the shock tower. Change the black ballstud on the top of the steering knuckle/caster block to a silver ballstud, try a 5 minute run on flat tires with -2 degrees of camber, and see how it is. You should be able to add .030 under the silver ballstud for more adjustment, on the steering knuckle/caster block with Jaco tires, and the ballcup not rub the rim. You will have to experiment if you use different rims and ballcups. This should help some, let us know.
- DaveW
REDLINEM03: Your check is in the mail!
xDeeDubYax is offline   Reply With Quote
Old 09-20-2005, 05:57 AM   #6334
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by RED-LINE M03
DAVE W. (XDEEDUBYAX) IS THE TC4 GOD !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
THANKS FOR ALL OF YOUR TIME AND EFFORT I'M PRETTY SURE I SPEAK FOR ALL ON THIS FORUM.
GIVE "D" SOME PROPS HE UNDERSTANDS WHAT THIS HOBBY IS ALL ABOUT.
LATER,
E
You have no idea!!! I have personnally seen him drive his TC4 into a burning building and recover 7 stranded families. Dave W. Rocks!!!
Seriously though, I have doubts about some of the advice given on these forums. A lot of guys post on here that seem to know what they're talking about. I'll definitely support the DW for president campaign. He knows his RC cars.
stiltskin is offline   Reply With Quote
Old 09-20-2005, 06:09 AM   #6335
Super Moderator
Yeah I think Dave knows a thing or two. Hey Dave did you ever talk to John? If not I would wait til at least next week...Vegas starts tomorrow.
Old 09-20-2005, 06:12 AM   #6336
xDeeDubYax's Avatar
STILTSKIN: Annnnd your check is in the mail! At this rate ill need to mortgage the house to pay you fockers. They need a smiley that is laying down on his chest, beating the screen with his fists, and laughing hilariously. WAIT... whos that on the grassy knoll?? No assasinations... please.
- DaveW
Old 09-20-2005, 06:14 AM   #6337
Any ideas on the weight of this car, box stock with no electronics.
Homer Allman is offline   Reply With Quote
Old 09-20-2005, 06:17 AM   #6338
Super Moderator
Homey how ya doin!!!!! you thinking of getting a touring car? Kinda hard to take the 6 foot jump in front of the drivers stand with a TC4
Old 09-20-2005, 06:31 AM   #6339
Good thanks Bob. How about you. I may run some over the winter. I'm just weighing my options right now.
Old 09-20-2005, 06:41 AM   #6340
Super Moderator
Homer its a great car. If you can find yourself a tub car then consider getting the BMI kit. Both are top notch. You won't be dissapointed. I personally already had a tub car and I run for Jason over at BMI so obviously I leaned towards his car. DW on here runs the FT car and really has alot of good ideas and feed back. He pays attention to the details....thats important. I hear that Express is going to be having a race before the Carpet Nats down in North Carolina. That should be in Feb but no date yet officially. Any chance we will see you there?
Old 09-20-2005, 07:37 AM   #6341
lem2's Avatar
Default 3Racing Parts
Finally getting my 3 Racing parts in a few days!
Traded this:
http://www.rctech.net/forum/showthr...165#post1820165
for the Knuckle Arms/Rear Hub and Steering Assembly!
Now I have to dissassemble the car when it arrives! Woooohoooo!!!!!
Old 09-20-2005, 07:48 AM   #6342
TPhalen's Avatar
R/C Tech Charter Subscriber
Originally Posted by lem2
TPhalen,
Yes, there will be a battery strap option....part #31126. It will come with 2 standoffs, a strap and (I think) our thumbscrew setup.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 09-20-2005, 07:51 AM   #6343
Trader Rating: 194 (99%+)
When will the battery strap be released? Can I go to my LHS and order one?
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 09-20-2005, 09:29 AM   #6344
Super Moderator
So Tony whos got the hot carpet setup in the early going? I am curious to see how the boys all do in Vegas. And Im not sure if I ever complimented you or AE but very stand up thing you guys did for the Hurricane raffle.
Old 09-20-2005, 11:52 AM   #6345
TPhalen's Avatar
Quick note: just checked and the battery strap will NOT come with the thumbscrew setup....still capheads and body clips.
dodgeguy: Should be available in the next couple weeks. It was a last minute thing that was, well, last minute.
Bob: We have a couple hot setups (we think) for that race....all the boys are on their way out there! Hopefully we will have the same luck we did at the Reedy Race!
Tony Phalen
RCDriver.com
CompetitionX.com
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
