Like Tree19Likes
Old 09-19-2005, 10:21 AM   #6316
Super Moderator
Trader Rating: 17 (100%+)
Hey Dave, just a suggestion but try to run the losi hubs with the rear arms and not the front. One improvement that I noticed from the TC3 to the TC4 is that the cvd's are no longer swept towards the middle of the car. This has got to free up the transmission. I did have the front arms on the same way as you then because I looked down and said, wow these cvds are way forward again.
Tekno | BLOK | JConcepts | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 09-19-2005, 10:22 AM   #6317
lem2's Avatar
Originally Posted by xDeeDubYax
A pic of the whole car to show the angle of the front arms on the rear of the car. Yes, those are steel screws, i wanted the car to be up to weight, so i added a little bit of strength in the process.
- DaveW
DaveW,
Nice car, cleanly built. My question is, what is the benefit of of using the front arms in the rear?
I also have a losi rear hub but I lost the small spacers that go in the rear hub hinge pin, what is a good substitue for that?
ALmost done with the car!!!
Lem
lem2 is offline   Reply With Quote
Old 09-19-2005, 10:28 AM   #6318
Super Moderator
Next question is how do I know if they are zero offset. They only said Zero deg. on the package. they seemed kind of balloon shaped at area surrounding the hinge pin. I know I had to file off quite a bit on the outside surface just to get the holes lined up correctly.
Old 09-19-2005, 10:28 AM   #6319
Trader Rating: 194 (99%+)
Why are you guys playing with using Losi hubs and castor blocks and using front arms on the rear? Are the big guns doing this? What are the handling advantages?
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 09-19-2005, 10:33 AM   #6320
Super Moderator
using the losi blocks mounts the ball stud vertical and allows more roll center adjustments. Im not 100% on the arm choice. It was something that DW tried and I said I would try it out and give him feedback. This is how you get faster. Get a partner and start experimenting.
Old 09-19-2005, 10:43 AM   #6321
lem2's Avatar
Thanks for the reply! I have yet to try my TC4. I was able to salvage the light weight inputs shafts, alum spur gear holder, knuckle arm and some other goodies in my old WarpSpeed chassis. I'm also using 6 dgeree c hybs from losi, since AE does not have a 6 degree hubs!
Here are some pictures of my TC4 in progress/
Pic 1: my shameful wiring
Pic 2: the rear end, with irs bones with pin cushions, I also shaved the rear part of the diff case for a smotther effect.
Old 09-19-2005, 10:47 AM   #6322
xDeeDubYax's Avatar
BOB: Yeah, my 3/4 used to be built with the regular rear arms, and yes, the dogbones are swept towards the centerline of the car... very similar to the front. That was the biggest improvement on the handling of the car. The efficiency of the driveline wasnt the issue for me, its already freer than any belt car ive seen, it was the cars lack of squat on power, w/o having to soften the rear shocks dramatically, or other changes. I wanted the front and rear to feel similar in weight transferred input, off and on throttle. With the rear arms on the car, most guys run the hubs forward, for a short wheelbase, and even place a shim behind the arm to move it further forward. While this is still about 1/32" closer to the rear of the car than running the front arms, it does not transfer the weight like the front arms. With the front arms, the axle is moved forward, not the arm, the arm pivot point remaining the same on the chassis, but changing at wheel location. The shim for hub wheelbase placement is removed, for less chance of slop. This does require a bit of different thinking for setup, than a traditional AE design. But the car IS planted, and alot smoother through transition when set up this way. It gives you a wider range of rear traction to adjust from, without hitting that rear diff scorching barrier. Like i said in that e-mail... just something i thought you might like to try...
LEM: Thanx. There are a ton of places to get plastic shims, but i get Losi part #5050. Easy to find, and the package comes with several choices in thickness. Good luck with the car!
- DaveW
xDeeDubYax is offline   Reply With Quote
Old 09-19-2005, 10:50 AM   #6323
Super Moderator
Oh don't worry I will try it I just had questions while assembling it
Old 09-19-2005, 10:54 AM   #6324
TPhalen's Avatar
R/C Tech Charter Subscriber
Actually, lem2, we DO sell 6 deg Caster Blocks....part #31018. FYI.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 09-19-2005, 11:00 AM   #6325
xDeeDubYax's Avatar
BOB: Zero degree is the toe, zero offset is the obvious one, the area that holds the bearing is much longer than the zero offset hub, its really easy to see. The toe is a bit harder, unless you mark your parts after package removal. the balloon shape means you have an "updated" set of rear hubs, the older ones used to be flat in those areas, my guess is Losi added plastic there to give strength around the pin area. If you look at that pic, the Losi hub i am using has that same ballooned area on the backside, the front i removed with a dremel sanding drum, and then finished it with a solid sanding block, and 180 grit sandpaper, to keep it flat and somewhat "factory".
DODGEGUY: The addition of Losi hubs front and rear started way back when the XXX-S hit, because the parts were, and i hate to say it, more durable. ASC front hubs were known to strip where the ballstud and the kingpin went in, and the geometry was really close to the stock stuff. The rear hubs were added as a tuning option, and yes, i have seen them on alot of "pros" cars in the past. To my understanding though, AE of late has gotten stricter on this issue, and requires the Team to run the car with AE goodies.
- DaveW
Old 09-19-2005, 11:06 AM   #6326
stiltskin's Avatar
Trader Rating: 102 (100%+)
DeeDubYa,
I just noticed on your picture that you were missing one rear tire. What effect did this have on your handling? and were you running this setup when you were lapping me last week?
stiltskin is offline   Reply With Quote
Old 09-19-2005, 12:19 PM   #6327
xDeeDubYax's Avatar
Smart arse... . No Tony, i actually had all FOUR tires on the car! Where were you this past sunday? If you told me on the phone previously, i aplogize, this insomnia thing sucks. See ya saturday?? Racing, hopefully...
- DaveW
Old 09-19-2005, 06:37 PM   #6328
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default TC 4 GOD
DAVE W. (XDEEDUBYAX) IS THE TC4 GOD !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
THANKS FOR ALL OF YOUR TIME AND EFFORT I'M PRETTY SURE I SPEAK FOR ALL ON THIS FORUM.
GIVE "D" SOME PROPS HE UNDERSTANDS WHAT THIS HOBBY IS ALL ABOUT.
LATER,
E
RED-LINE M03 is offline   Reply With Quote
Old 09-19-2005, 06:48 PM   #6329
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Has anyone had any problems with thier tires coning under unexpected circumstances? I have tried 2, 2.5 and 3 degrees of camber all around and I get smaller diameters on the outsides than on the insides on the front tires no matter what after one run. The rears have no such problem. I have set the camber using the older integy guages and an old fashioned RPM guage with freshly cut tires. I have been truing down to 59 mm and the outsides end up around 56.5 after 1 or 2 qualifiers. I have changed three different brands of tires with different compounds and have been rotating side to side after every run. I am using this set up exactly aside from the camber changes. Any ideas? This is getting expensive!!
http://www.mikeshobbyshop.com/
click set up sheets. Then choose TC4. Its the only one there.
Old 09-19-2005, 06:59 PM   #6330
RCknight's Avatar
Yea, mine have been coning some, but I think it's setup error on my part. I'm in the process of tring a higher roll center front/rear.
RCknight is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
