Team Associated TC4
#6301
I don't know what speedtech shaft you are talking about, could you give us a hyperlink.
#6303
Look under
Hop-ups then go to Team Bomber under TC4.
Website is;
www.speedtechrc.com
Please, let me know if they have any in stock.
Website is;
www.speedtechrc.com
#6305
Hey,
I'm still running a stock Team TC4 and I want to run some foam mod (10x1). Will I melt the stock plastic diffs?
#6306
Originally Posted by BlackKat
Hey,
#6308
Outdrive breakage? Did you hit anything?
Another question. Anyone have a low-bite spool or diff setup (rubber tires)
#6309
hey DW, I was going to try your suggestion with the front arms on the back but when putting everything together I wasnt happy with the way everything ligned up. I also noticed that the XXXs hubs need a lot of filing to work. I still have to break out the dremel and take care of them. Im going to try that carpet setup that I sent over to you next time out. I won't be able to get out for a bit probably not until November.
#6310
Diff
Was wanting some advice on diffs.
What options are available to fit a TC4.
Brands
strength
etc
etc
Are the TC3 diffs the same.
Brands
strength
etc
etc
#6311
Originally Posted by dodgeguy
Man! The FT car seems really nice. But it has a very bad point I think. I can not fit my Airtronics 94257 servo into the car. It hits the spine plate.
This really sucks!!!!
OK. I did get the servo to fit with cuting the servo ear to clear the drive shaft.
#6312
Originally Posted by protouring
does anybody make a carbon fiber center shaft? Or one that is a little lighter
thanks
thanks
www.yokomousa.com
scroll down on this page, 2nd to the last item!!!
http://www.yokomousa.com/newproducts...es/npr0405.htm
#6313
BOB: If you have the Losi rear hubs that arent offset, the only filing that needs to be done is the plastic boss that is there for the setscrew. I know when you try and line it up, it looks like there isnt enough room for it all w/o alot of work, and the bracing at the front of the arm looks like it will hit the hub with full suspension travel, but it wont. I included a pic of my car for clarification. It sucks you wont get to run for that long... i look forward to every day i can wheel. Keep us updated on your findings. : )
- DaveW
- DaveW
#6314
For those of you looking for a lighter mainshaft, swap the TC4 drive cups for TC3 drivecups, dig in your parts box and pull out the old school TC3 carbon mainshaft... its a direct bolt-on... i still have three of the shafts in my personal stash.
- DaveW
- DaveW
#6315
A pic of the whole car to show the angle of the front arms on the rear of the car. Yes, those are steel screws, i wanted the car to be up to weight, so i added a little bit of strength in the process.
- DaveW
- DaveW
