Like Tree6Likes
Old 09-15-2005, 04:18 PM   #6271
rc-jammer's Avatar
Have you got the bolt and T-Nut the right wat around, if u havn't u have probably tightened it and the t-nut has lost its little wings and so can spin under load
rc-jammer is offline   Reply With Quote
Old 09-15-2005, 04:33 PM   #6272
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
Ahh, Yes I have it installed that right way. And all the parts and installed correctly. NOTHING is worn since I've replaced the essential items. And it's tightened. Thanks for your help though.
Paul_TC4 is offline   Reply With Quote
Old 09-15-2005, 05:11 PM   #6273
xDeeDubYax's Avatar
PAULTC4: Did you use the included diff grease when building your diff? Some guys have been known to use something else, and if it is teflon based, it WILL slip no matter what you do. Other than that, if the T-nut and spring are the right way, and the proper bearings are in the middle of the diff, and you are using the proper grease, then the only other options are, the diff rings/balls are out of spec, or you just didnt tighten it enough. Did you sand down (polish) your diff rings, like alot of oval drivers do? They are tight in tolerance, and really cant be sanded too much, or you will have the problem you stated. Remember, a diff HAS to have friction to work. The lube is NOT used in the diff simply for ring and ball protection. The compound facilitates the function of the diff. If you have calipers, measure the thickness of the diff rings, when compared to new ones out of the package... i hate to say this but i have had varying thickness diff rings come new in the same package. Good luck...
- DaveW
xDeeDubYax is offline   Reply With Quote
Old 09-15-2005, 05:59 PM   #6274
Paul, change the diff spring. I had exactly the same problem.
jiml is offline   Reply With Quote
Old 09-15-2005, 06:57 PM   #6275
Paul_TC4's Avatar
Thanks for the insight guys. I'll take both posts into consideration.
Old 09-15-2005, 09:33 PM   #6276
Any advise guys,
TC4 Team, or TC3 Factory Team both the same price.
Which one should I buy?
LS1powered is offline   Reply With Quote
Old 09-15-2005, 09:48 PM   #6277
Super Moderator
Trader Rating: 17 (100%+)
dont waste your time, either get the FTTC4 or get the BMI TC4.
Tekno | BLOK | JConcepts | RRP | BOOM RC
Bob Barry is offline   Reply With Quote
Old 09-16-2005, 08:06 AM   #6278
S_fender's Avatar
Just got my FT TC4 today and i've read all the instruction manual. On page 16 there is no length for the center turnbuckle but only "SO".... but i can't find anything for this on the different setup that are available.
Have you information on this lenght ??
S_fender is offline   Reply With Quote
Old 09-16-2005, 08:12 AM   #6279
Originally Posted by LS1powered
Any advise guys,
What are your plans for the car? Driveway racing, club racing, or what?
JWATT is offline   Reply With Quote
Old 09-16-2005, 08:49 AM   #6280
dawgmeat's Avatar
Default carpet set-up
Rcmadness is a small free flowing layout 50x30, some where around there,, the fast guys took out the middle graphite plate and ran soft springs, well just look at the pics
Team Associated TC4-picture-714.jpg   Team Associated TC4-picture-715.jpg   Team Associated TC4-picture-716.jpg   Team Associated TC4-picture-717.jpg
dawgmeat is online now   Reply With Quote
Old 09-16-2005, 08:51 AM   #6281
dawgmeat's Avatar
more
Old 09-17-2005, 05:09 AM   #6282
Jeel's Avatar
Trader Rating: 16 (100%+)
dawgmeat,
You racing the vegas warmup at Madness tonight?
Jeel is offline   Reply With Quote
Old 09-17-2005, 06:44 AM   #6283
dawgmeat's Avatar
Originally Posted by Jeel
dawgmeat,
Nah, I'll have my son that nite, doing thye daddy thing
Old 09-17-2005, 07:18 AM   #6284
Trader Rating: 193 (99%+)
Does AE make a battery brace for the Factory Team kit? Or any other manufactor?
Also does any one know of links to a set up for the FT? AE's website is a little out dated in regards to set up info.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 09-17-2005, 09:12 AM   #6285
lem2's Avatar
Default Taking it slow.....
Finished sanding and sealing the CF plates.
Done with the diffs, decided to stay with the steel diffs, I compared it to the old metal diffs and it is considerable lighter by feel!
Finished installing the hinge pin mounts and arms!
Glad to know that the Losi 6degree C-hubs fit just fine in the arms! (in case I will use a spool)
QUESTION:
1) the new diffs come with bearings already instead of bushings, is there any difference if I use the bushing on one of the composite diffs as a spare?
2) In my old steel diff, i wanted to get the squat diff bearings there, but the problem is the pin holding the nut is broken and I can't get the diff loose. PS:the part holding the nut is made of brass not plastic. How can I remove it?
Any set up with a spool on a TC4?
lem2 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
