Like Tree19Likes
Old 09-12-2005, 02:01 AM   #6226
Barracuda Man's Avatar
Originally Posted by Eddog123
the track i run on is roughly 50x100 ft. ,, im using that same motor that you mentioned.
Try final drive of 6.5:1
Barracuda Man is offline   Reply With Quote
Old 09-12-2005, 03:29 AM   #6227
imr
imr's Avatar
indeed johnbull.
I have almost finished my ft tc4 and no slop.
What worries me more is that it seems there are about 24 screw to loosen to change spur gear?
Maybe (and hopefully I'm wrong) I have overlooked something?
You have to loosen the top deck.
Correct me if I'm wrong.
imr is offline   Reply With Quote
Old 09-12-2005, 05:40 AM   #6228
johnbull's Avatar
On our BMI model you have to take the top deck out first too.
But I can't see any other way it can be done if you want a top deck.
johnbull is offline   Reply With Quote
Old 09-12-2005, 07:01 AM   #6229
xDeeDubYax's Avatar
Yep, there is a slew of screws to remove for a spur change. There is no easy way. The front diff cover has easy access, but the rear doesnt. Im assuming they made the top plate as they did to add some strength to the rear area over the motor mount. Putting a motor in the car isnt the easiest task either. Magnetizing your ballend wrench, and using steel motor screws will help some. Honestly, i think the FT is the best offer AE has given us to date. A P-DUB bumper on the front was my only addition, and is well worth the purchase.
- DaveW
xDeeDubYax is offline   Reply With Quote
Old 09-12-2005, 07:26 AM   #6230
lem2's Avatar
The FT-TC4 arrived in our shores yesterday!!! All of them is sold out!! Glad I have one on reserve for me!! Getting it on Thursday!!
xDeeDubYax: thanks for the reply!! I still have to dismantle some stuff from my warpspeed and but the bling stuff on the TC4!! I guess good chassis prep will take me a few days!
lem2 is offline   Reply With Quote
Old 09-12-2005, 07:47 AM   #6231
xDeeDubYax's Avatar
Slow on the bench, fast on the track! Taking time on the chassis is the next best thing to practice.
- DaveW
Old 09-12-2005, 08:25 AM   #6232
The Teacher's Avatar
Trader Rating: 47 (100%+)
DaveW, what diffs are you running LW steel/plastic/alloy??? Also, are the allow toe in blocks the same as the original TC4???
The Teacher is offline   Reply With Quote
Old 09-12-2005, 08:37 AM   #6233
xDeeDubYax's Avatar
TEACH: Wassup man. Im personally running a LW steel front diff for weight/steering, and a LW plastic one in the rear. Yes the alloy mounts are the same, but they give you the X2.5 and square for the rear of the car in the kit. Some people like the wider rear with less toe. I prefer the circle and X3.0 for the rear.
- DaveW
Old 09-12-2005, 10:40 AM   #6234
DougC's Avatar
R/C Tech Charter Subscriber
Foams on a TC4 Factory Team and a dilemma.....
Hey guy's, this may be a stupid question but I've got to ask; do 28mm foams bolt right on the Factory Team TC4 without having to modify the suspension? I've got an FK05 right now and quite frankly I don't like the fact that you have to hack on the rear arms in order to keep the tires from rubbing on the shock ends. It just seems kind of cheesy to have to cut on a high end car in order to get your tires to fit. You can simply move the bottoms to the inner mounting hole but that just takes away one of your tuning options. I've got the opportunity to buy a Factory Team at a really good price and Id really like to buy it. I just don't know what to do as I've already got a small fortune invested in Xray spare parts. Thanks for any help.
DougC is offline   Reply With Quote
Old 09-12-2005, 10:47 AM   #6235
xDeeDubYax's Avatar
DOUG: The 28mm foams do bolt right on the car with no mods. I built a friends FK'05, and the same thing you are talking about turned me off about the car. Along with the motor hangin out for all to hack.
The FTTC4 can rub the front lower shock cup mounted on the outermost hole, when running 28mm foams, when the steering is at full lock. But honestly, if you have that much steering throw dialed into your car, youre scrubbin corner speed.
- DaveW
Old 09-12-2005, 12:18 PM   #6236
MikeDeadly's Avatar
Location: San Marcos/San Antonio, Tx but chillin in Orlando, FL for now.
Send a message via AIM to MikeDeadly
Hey Dee,
with the circle block and the x3.0 in the rear, that maintains the 2 degrees of toe right? thanks
Mike
MikeDeadly is offline   Reply With Quote
Old 09-12-2005, 12:38 PM   #6237
RCknight's Avatar
Default Anyone interested...
I have a new BMI 3mm chassis for sale with new style motor mount. Check out this thread in the for sale forum.
RCknight is offline   Reply With Quote
Old 09-12-2005, 12:58 PM   #6238
imr
imr's Avatar
Just wondering:
Would it affect the stiffness if I drill 2 holes in the top deck, just behind the spur gear.
That way I could have access to the 2 screws that are hidden by the top deck and are needed to unscrew for opening the rear gearbox, so I could leave the topdeck on if I need acces to the rear diff.
Old 09-12-2005, 01:03 PM   #6239
frog racing's Avatar
Send a message via AIM to frog racing
Originally Posted by imr
Just wondering:
That should not be a big problem. I do not think you will see a difference in the stiffness.
K
Frogracer -
8IGHT-E 4.0 KIT: 1/8 4WD ELECTRIC BUGGY
Tekin RX8, Tekin 1900kv
Hitec HSB-9370T
www.whf-texas.org
frog racing is offline   Reply With Quote
Old 09-12-2005, 01:09 PM   #6240
I've heard that there are problems with the kit. What does everybody think? Thanks.
Stroker Ace is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
