Like Tree5Likes
Old 09-07-2005, 01:37 PM   #6166
Lite weight diff halfs #31062
Lite weight assembly #31128
walterhenderson is offline   Reply With Quote
Old 09-07-2005, 03:00 PM   #6167
johnbull's Avatar
Originally Posted by RCknight
do you have any pics of how you worked the steering. Also were you able to fix the bump steer issue you said you were having?
Got some pics at last.
First is a pic of both cars. You can see how much lower the rear diff case sits on the car on the right. Compare the case with the arm mounts to see the difference.
Second pic is steering detail, using mainly Yokomo parts.
Third pic is a side view. You can see how low it all is from this view. The motor is about the highest item in the whole car, and that is actually lower than normal too. 100 tooth spur just doesn't come out the bottom.
We ran the car today. The track was very dusty but we still made some respectable times. Certainly quicker than all others running there today.
We ran 6 packs, simply getting the car back on it's Malta set up after our trip to the Ko Gp, where we had to make a number of changes.
The main difference with this car, compared to the normal one is that because of the much lower C of G it runs much flatter - less roll. It therefore needs less camber change so your roll centre is up slightly - closer to the C of G, which is ideal.
There is still a bit of bump steer, but that's an easy one; just a matter of playing with steering arm angles (shimming).
Team Associated TC4-bmi-tc4s-004.jpg   Team Associated TC4-tc4-1-steering-005.jpg   Team Associated TC4-low-cg-tc4-007.jpg
johnbull is offline   Reply With Quote
Old 09-07-2005, 03:20 PM   #6168
PaZ
PaZ's Avatar
walterhenderson- cheers!
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 09-07-2005, 04:03 PM   #6169
macvolcom's Avatar
Send a message via AIM to macvolcom
Can someone post a pic of their beveled battery slots?
Matt
macvolcom is offline   Reply With Quote
Old 09-07-2005, 04:40 PM   #6170
TheCoolCanFanMan's Avatar
Hi
To all that have that have kindly purchased Cool-Can-Fan's for their cars. We now have a NEW L K website
Cheers Malc (The-Cool-Can-Fan-Man)
www.coolcanfan.com
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 09-07-2005, 08:58 PM   #6171
rcracenut's Avatar
Trader Rating: 52 (96%+)
I know IRS and Hardcore make aluminum outdrives for the TC3/TC4. Is there anyone else? What is the best one to use on a 19 turn motor?
rcracenut is offline   Reply With Quote
Old 09-07-2005, 09:16 PM   #6172
Skip109's Avatar
Hey Chuck
I will be at the track ALL DAY tomorow with the plastic diffs and I will let you know how they work.
Skip109 is offline   Reply With Quote
Old 09-08-2005, 03:04 AM   #6173
RCknight's Avatar
Default Johnbull do you see the...
lower cg as good mod for smooth carpet? Thats all I race. What about the steering rack mod, is there anyway to use the old tc3 rack without having to cut into the upper deck? Thanks for the info...
RCknight is offline   Reply With Quote
Old 09-08-2005, 03:14 AM   #6174
RC_Woody's Avatar
Default shaft drive vs belt drive
I'm sure this has been discussed before and maybe this isn't the right place, but...
what are the pro's and Con's of the shaft vs the belt drive.
I have heard that belt drive will you a little more top speed,
whats the advantage of the shaft drive? better acceleration?
I'm a newb just trying to figure out what car I want to purchase, so I reseaching all the differen't types out there. I'm going to mainly Carpet Race this winter and was thinking about the TC4... and the Xray and the RDX.... you get the idea, decisions, decisions....
Woody
RC_Woody is offline   Reply With Quote
Old 09-08-2005, 03:42 AM   #6175
Woody
Hi,
Shaft cars seems to be more agressive due to the more direct power input compared to a belt drive!
The acceleration is due this a little faster.
Top speed is higher on a belt drive.
Bye!
840918001 is offline   Reply With Quote
Old 09-08-2005, 04:27 AM   #6176
imr
imr's Avatar
Originally Posted by imr
Another question: in the manual there is written that the tc4 comes with 3 rear toe in.
The rear arm mount is 2.5.
Does this mean there is already 0.5 toe in in the rear hub carrier or is there an error in the manual?
My guess is the manual is wrong and the kit comes in 2.5 rear toe in.
or.......?
Anyone?
imr is offline   Reply With Quote
Old 09-08-2005, 04:35 AM   #6177
Shaft Vs Belt
The concensous seems to be.
Shaft lower rolling resistance = more efficient = quicker therefore better for Stock and 19T
But - Shafts introduce gyroscopic effects that apparently have detrimental properties under acceleration and can effect ultimate grip, hence with the very low turn Mods now in use it is said that Belt drives generate more grip and the that the loss in efficiency is negated by the extra power of the motoer.
exint2 is offline   Reply With Quote
Old 09-08-2005, 04:58 AM   #6178
Rick Worth's Avatar
That sounded real proffesional till you spelled motor wrong. R.W.
Rick Worth is offline   Reply With Quote
Old 09-08-2005, 05:48 AM   #6179
xDeeDubYax's Avatar
- DaveW
xDeeDubYax is offline   Reply With Quote
Old 09-08-2005, 06:11 AM   #6180
Hmmm and you spell "professional" how exactly!!!
anyway Motoer is a rare English dialect spelling ....... and if you believe that!
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
beyondthepack
