Like Tree42Likes
Old 08-06-2005, 05:06 PM   #5896
MikeDeadly's Avatar
Location: San Marcos/San Antonio, Tx but chillin in Orlando, FL for now.
Send a message via AIM to MikeDeadly
My carbon tub chassis rocks when i put it on a flat table. Does this mean its tweaked? and im talking about a noticable rock too, at least a 3mm difference from corner to corner. i called ae and they said id have to send it in to see if it really is tweaked but im pretty sure it is... any suggestions on what to do??
Mike
MikeDeadly is offline   Reply With Quote
Old 08-06-2005, 09:17 PM   #5897
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
My regular plastic tub does the same thing. I just adjust the tweak out of it the best I can using a tweak board. My ride height ends up being a little off on one or two corners (maybe a 1.5 mm difference lowest to highest), but as a rookie its not enough for me to feel yet. Let me know how sending it in to ae works out. I am so Anal Retentive that I would love to have everything "zero" out. You might also check some new chassis at your lhs if available to see if they suffer the same problem.
Old 08-06-2005, 09:19 PM   #5898
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
For you guys running spools what are you doing not to eat front gears? My TC3 with a spool for some reason never ate gears no matter what I would touch. Anyone have the part number for gear for spools only?
Does the TC4 have some sort of alignment problem that the TC3 didn't have?
ST Racing Concepts (STRC)
Old 08-06-2005, 10:08 PM   #5899
macvolcom's Avatar
Send a message via AIM to macvolcom
TPhalen, will the new TC4 come out some time this coming up week?
macvolcom is offline   Reply With Quote
Old 08-07-2005, 11:57 AM   #5900
ooliganRC's Avatar
Send a message via MSN to ooliganRC
Hiya, just ditched the old TC3 for a TC4 team kit
Run mainly outdoor purpose built tracks
Got any ideas for a base set up for tight bumpy asphalt tracks for a 19T
if poss email me a setup sheet plz
Corally RDX PHi, Novak Brushless, Futaba 3GR, KO Propo 2413, E-Power 4500, Full Throttle Motorsports.
"You aint going fast enough, if you aint Full Throttle"
Currently slow due to : Bad thumbs and no motors :P
ooliganRC is offline   Reply With Quote
Old 08-07-2005, 01:26 PM   #5901
imr
imr's Avatar
AE has pushed the FT TC4 date to mid-August 2005
imr is offline   Reply With Quote
Old 08-07-2005, 06:54 PM   #5902
fathead's Avatar
I use a spool in my TC4 and it has had well over 20 runs and I haven't stripped a gear yet, the crown gear does have some wear on it but nothing too bad.
What I did is buy a pack of shims, Assoc. make a small pack for the NTC3 that has about 10 of the big diff shims in it and used those to shim the front diff up nice and snug and I also use a small amount of the stealth grease on the gears.
Slavich Design
fathead is offline   Reply With Quote
Old 08-07-2005, 09:41 PM   #5903
BlackKat's Avatar
Well,
My first day on the car....Tried the Juho Levenen "Basement" setup and...it sucked.
I ended up removing EVERY shim on the car, including the ones under the pivot blocks & shortening the wheelbase to the shortest possible setting on both F&R to make the car driveable. I'm still a few tenths off my old XRay Evo2 long-arm's lap times but I didn't bring a front diff with me (My track doesn't really have enough grip to run a one-way in this car) and I didn't break any knuckles! I think with a front diff and some TLC this car can be pretty good
This car is more consistant than my TC3 ever was!
BlackKat is offline   Reply With Quote
Old 08-07-2005, 10:22 PM   #5904
macvolcom's Avatar
I know that, but I was figuring its pretty close to the middle of august next week.
Old 08-08-2005, 05:42 PM   #5905
tc3 racer sc's Avatar
Default tighten the rear up
what can i do to tighten the rear up i was running at a track this past weekend testing for a race nxt week the track is a indoor asphalt very smooth almost like carpet, i ran red fronts,4degree caster,blue rear springs, 2.o toe in rear shock2 hole on front tower cclose to bulk head, inner hole on arm, rear on tower 3 hole, outer on rear arm camber links in stock postion close to bulk head, need advice thxs
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 08-08-2005, 05:54 PM   #5906
fathead's Avatar
Depends, where is the rear loose? into or out of a corner?, mid corner?, on or off power?
Slavich Design
Old 08-08-2005, 06:01 PM   #5907
mostly in to corner / mid corner
Old 08-08-2005, 06:20 PM   #5908
wyd
Tech Legend
wyd's Avatar
Your car was loose at Frederick? Wow that track has more traction than velcro with glue on it!!!!!!!!!!!!!! It has carpet like traction.
I'm running Gold front springs and blue rears with 40wt and #2 pistons at C. Shocks all the way out on the front tower and in one on the rear tower. 2.0 rear toe in block and have lots of traction.
Old 08-08-2005, 06:24 PM   #5909
fathead's Avatar
Try moving the bottom of the front shock to the outer hole.
Also try putting a shim under the rear front arm-mount to give the front some anti-dive
Slavich Design
Old 08-08-2005, 09:38 PM   #5910
BlackKat's Avatar
Soften up the front end. I'd say drop a front spring rate. If your running red, try a gold
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
BJR
