Like Tree43Likes
Old 08-02-2005, 01:22 PM   #5866
AM03GT's Avatar
Originally Posted by Stusdal
Anyone know where I can get a main shaft like the one on Pelle Mertin`s car?
http://forum.rscnet.org/attachment.p...hmentid=302376
thats the yokomo cf center shaft for the TC4.
in my personal experience it didn't hold up very well... ran it may 31st till 3 weeks ago when one of the dogbone ends starting spinning due to a broken pin.
running mostly 19T and stock...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 08-02-2005, 01:29 PM   #5867
RCknight's Avatar
Default I would like to get me an old
TC3 Team Bomber one. Is the Team TC4 one still avaiable from Team Bomber? The RC Maniax cf shaft looks nice.
RCknight is offline   Reply With Quote
Old 08-02-2005, 04:04 PM   #5868
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
The Team Bomber shaft is a much better shaft the Yokomo one is lighter by a gram or two... but the Bomber one is a brick S#!t house .... and is pinned in 2 spots at each end..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-02-2005, 04:09 PM   #5869
Originally Posted by protc3
TC4 kits are in stock.my website is going to be revamped shortly.i have had alot of complaints and i am looking to have it all cleared up shortly.the motor mount is ready for production now.i will be starting them as soon as i get an opening in my machines.probably toward the end of this week.
Good news Jason .... .hows about the color thing I PM'd you about...will you be able to do that to the motor mount too
-Dave
Old 08-02-2005, 04:28 PM   #5870
protc3's Avatar
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 08-02-2005, 04:40 PM   #5871
fatbear's Avatar
Send a message via Yahoo to fatbear
Jason, YGPM
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 08-03-2005, 12:26 AM   #5872
RCknight's Avatar
Default Dave have you tried those
Square delrin outdrives? Are they any good?
Old 08-03-2005, 01:03 AM   #5873
johnbull's Avatar
ROLL CENTRE SPACING. It's one of the things we have been playing with quite a bit lately. Running TC4 with BMI chassis we first ran with .5 shims all round as we had found best on the tub TC4. This was good.
Yesterday I tried lowering the rear RC by running the rear without shims. Result - lower roll centre at rear = more grip at rear = less steering. Next I'll be removing the front ones too, to see if I can get more steering and more grip. So far it's been best with 0.5 (that's 2 notch) shims all round.
There is of course another possibility. I am presently running 2.5 rear arm mounts. I couldleave the F and R spacing as it is and go to 2 degree mounts. this should loosen the rear - and give more straight line speed. Definately worth a try.
What impresses me most is how much these small changes effect the car's characteristics.
johnbull is offline   Reply With Quote
Old 08-03-2005, 03:00 AM   #5874
Stusdal's Avatar
Where could I buy this, any webshops in Hong Kong or there about?
Anybody seen or now somthing about when ass might be thinking about relesing a converting kit to the factory team?
Serpent || Sanwa || Hobbywing || GensACE || Sorex || Contact ||
*When you are not practicing, remember, someone somewhere is practicing, and when you meet him he will win*
Stusdal is offline   Reply With Quote
Old 08-03-2005, 05:27 AM   #5875
xDeeDubYax's Avatar
Andrew: 20 runs on a set of brushes is REALLY economical. Consider: most of us change them in 5 runs, if not less. It sounds like you are getting really good comm wear for that many runs, but i would say you could definitely afford 3.50 USD every 20 runs for brushes.
- DaveW
xDeeDubYax is offline   Reply With Quote
Old 08-03-2005, 05:50 AM   #5876
Super Moderator
Trader Rating: 17 (100%+)
John Bull before you make that drastic of a change, try using the 3.0 block with the circle front. It will give you 2.0 toe in but with the wide stance so you keep the stability. I have that on my car and really like it. As far as the spacers, thank you. Thats exactally what I wanted to know.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 08-03-2005, 08:35 AM   #5877
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
dedub-I know youre right. And I can afford to get the brushes, I just was thinking if its not necessary theres not much point. Long live uber economy!
Old 08-03-2005, 11:17 AM   #5878
macnkitty2002's Avatar
If i were to get the team kit, what hop-ups would you all recommend getting? i was thinking maybe the carbon component kit and two swaybar sets(for front and rear). is there anything else i should add?
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 08-03-2005, 11:17 AM   #5879
Default TC-4 parts on a TC-3
Ok lets try this again.
Will the caster blocks from the TC-4 fit the TC-3? I was hoping to try out the 6 degree blocks.
Thanks.
ccm399 is offline   Reply With Quote
Old 08-03-2005, 11:21 AM   #5880
Super Moderator
They should fit fine. I would get the Graphite kit, the sway bars, 4 deg blocks, Yok shock caps, Sqyare's lightweight spur adapter. If you can hold out for the FT kit then I would do that or maybe consider BMI kit
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
