Like Tree19Likes
Old 07-30-2005, 03:25 PM   #5836
Originally Posted by brooksy
Hi Joe.the guy i bought it from races nitro TC3,so it could be 200mm not 190mm.many thanks for help.
I tried to swap my NTC3 1-way into my TC4 - it's too wide. I think the 1-way itself is the same but it looks like the difference is in the outdrives. I got a deal on a TC3 1-way so I didn't pursue it any further, but you might be able to just swap the outdrives.
Corner Weight is offline   Reply With Quote
Old 07-30-2005, 04:51 PM   #5837
Oasis's Avatar
Trader Rating: 36 (100%+)
Need more steering,That would be off power going into a turn.Set up I'm using now I got off the associated site,Juho Levanen's rubber tire carpet track.The problem I'm having is not enough turn in steering,if i dial in more steering it makes the very darty and still has the same problem..no turn in steering..help..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 07-30-2005, 05:14 PM   #5838
BlackKat's Avatar
Kat: What have you tried on your setup to give it more turn in so far? I'd start screwing around with caster first...Softening up the front in seems to give more turn in while stiffening the rear gives more rotation comming out (It took me nearly a year racing just to learn that )
Only two more years until I have freedom and can take some road trips to Oasis & catch up on lost time
I get my TC4 next week! Yay! If its anything like my TC3 I'm gonna love it
BlackKat is offline   Reply With Quote
Old 07-30-2005, 05:18 PM   #5839
BlackKat's Avatar
-XXXKat: Try toe-ing out the front arms (inboard toe-out) A wider front pivot-block than rear. Its a trick I used a couple times on the 415 and the Pro4 to get some more turn-in while maintaining stability.
Or...(I bet you tried this already...) Try unscrewing the rear droop screws
Brainwave! LOL
Old 07-30-2005, 09:16 PM   #5840
rcracenut's Avatar
Trader Rating: 52 (96%+)
Anybody know of who makes Titaniun driveshfts for the TC4? Also, what about a light weight center drive shaft? I need to lose some rotating mass.
rcracenut is offline   Reply With Quote
Old 07-31-2005, 11:38 AM   #5841
Thumbs up
Originally Posted by busman
the diff ring gear center is bigger inside where it slips oner the oneway center section and bolts on, the little outdrive cups that slip inside the oneway brg are larger on the heavyduty oneway, so there are two different oneway out drives that you can order, compare the ring gear with a standard differential gear, if the one that came on your oneway is sloppy big when you try to fit it on the diff, its a HD unit, if it's close to the same size as a standard diff gear it's a llight duty. good luck, hope I explained it well enough.
Have tried what you said and its the HD unit.So i will have to order up some new outdrives.Thanks to every one for the help on this matter.
brooksy is offline   Reply With Quote
Old 08-01-2005, 12:42 PM   #5842
Default TC3 to TC4 Chassis upgrade
All the other guys at my track have changed to the tc4, I'm the last tc3 running regularly. If you can't beat 'em join 'em, so what kit do I buy (I can't join the car of the week club) any input on witch one, 3Racing, Factory team, BMI, IRS,or what ever.
lumberjak is offline   Reply With Quote
Old 08-01-2005, 07:12 PM   #5843
bvoltz's Avatar
Trader Rating: 44 (100%+)
Default TC4 Differential question
I have read the instruction, but I have noticed that when you tighten the differential then back it off 1/2 turn, per the instructions, it does not seem to be very free. I'm a little new to this sport, so sorry if this is a dumb question.
At 3/4 to 1 turn it seems to be much freer.
The reason that I'm asking, is I broke the outdrives from a crash, and I have a spare that came with the car, but when I put it in the drivetrain was not as free as the one in the car.
PVC pipes are hell on car
I'm asking if this normal?
bvoltz is offline   Reply With Quote
Old 08-01-2005, 07:42 PM   #5844
busman's Avatar
NIFTECH makes great parts, go to website, "call them" on the phone, great people to deal with, top notch stuff, have used their parts on 1/12 scale and NTC3 titanium drive shaft. have bought misc. TC3 drivetrain parts, great diff parts, anyhow give them a call. BUY USA!!!!!!!
But, Is it farther to Seattle or by Bus??????
Be obsequious as opposed to obtuse
The more Government expands, The more Freedom contracts!!
busman is offline   Reply With Quote
Old 08-01-2005, 08:31 PM   #5845
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I posted this on teh stock motor forum, but then as I thiought about it it seemes to fit the tc4 forum also. SO if you think youve got de ja vu, now you know why.
Guys I am not sure what do do at this point with my stock motor. I bought it new and "pro-tuned" from a reliable tuner nearby (Go Lightspeed!!) and have been running it in my TC4 for about 20-30 runs. Some 5 min racing, some 5 min practice runs, but all in the tc4. I have pulled it apart after every four runs, cleaned the com using q-tips and motor cleaner and then polished/cleaned it with the green comm stick. I have never gotten motor spray on the brushes, and they're not burnt. I have been gearing on the conservative side and my motor can temps around 170 after a five min run. I have the dual fan set-up that blows on the end bell so the endbell comes off the track around 135. I also run a motor spray saturated q-tip through the brush hoods after every four runs and lube the bushings (royal oil) after those four runs, sometimes two. I figured the comm was badly due for a cut, so I took some pre and post diameters from the comm. I was getting a very consistant .294" and .293" all the way around, and top to bottom. So I cut it, just shaving as little as I could to get it all the same color. I checked again and got .293" everywhere. OK, enought nerd data. I have the EXACT same set of brushes in this motor it came with. The serrations are gone, but they're not short by any means. What do I do now?
A. Run the motor at low volts for 300 secs to seat the old brushes to the new comm surface
B. Suck it up and spend money on new brushes and seat them at low volts for 300 sec.
C. Something else
Consider that the race immediately preceding teh comm cut I ran my best and fastest racve ever and won the rookie stock a-main in my club race. I mention this to highlight that I am looking for an economical way to keep it in at least as good condition as it was right before I cut teh comm. I mean, c'mon; I race rookie. I dont need a screamer, just a reliable motor. I'd rather spend the $$ on practice fees to get better
WHew!! What a book!!
Thanks for any and all comments
Andrew Doherty
Old 08-01-2005, 10:06 PM   #5846
RCknight's Avatar
Default lumberjak...
I would go with the team kit and get a BMI chassis. The BMI has some very nice design details that help with tunning. In my opinion, there is no other choice.
RCknight is offline   Reply With Quote
Old 08-01-2005, 10:07 PM   #5847
RCknight's Avatar
Default Anyone know if the Sqaure...
delrin outdrives are any good for the TC4? Do they hold up well in mod?
Old 08-01-2005, 10:18 PM   #5848
Indy800's Avatar
I guess this question is for Tony P.Have you guys tried to get rid of the steering slop in the ft edition?If so will it be available for the people that have the reg tub chassis?
thanks
AL
Indy800 is offline   Reply With Quote
Old 08-02-2005, 06:19 AM   #5849
For mod, I like the lightened steel outdrives better. My diffs have help up very well after the switch.
Matt
mpetrich is offline   Reply With Quote
Old 08-02-2005, 06:43 AM   #5850
RCknight, thanks for your input. But the question was, what chassis kit is best to convert my tc3 to tc4 specs. Sorry for the confusion, it just seems redundant to buy a whole new car just to strip that for a drivetrain I already have. Also, ( I'm not bashing anyones products ,but,) BMI is hard to get any info. on (price, pictures, avalabilaty) the websight makes no mention of this car. The factory team is unavalible at this time (again, no info.), IRS is just a fantom product ( no info, but everyone's heard about it) 3Racing is readily avalable on Ebay.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
