Like Tree36Likes
Old 07-22-2005, 12:48 AM   #5731
A Ilievski's Avatar
Trader Rating: 39 (100%+)
hi guys im looking into getting a tc4 possibly but what are the pros and cons about this car
thanx alex
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 07-22-2005, 12:48 AM   #5732
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Default blade
I think this is what you're talking about. the white "U" shaped deals are called blades. They are alternatives to dog bone pins.
On another note I answered my own question from earlier. I had forgot to set my droop. That was why my front "tie rods" were rubbing. They are still pretty close but don't rub when the suspension is settled and at rest. We'll see how it goes at the track. Boy do I feel dumb!!
Old 07-22-2005, 12:52 AM   #5733
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
thanx alex
Pros'
Good performing car out of the box.
Cons'
It's kind of heavy...... but then there is the FTTC4 tha should be out sometime in Aug that is much lighter
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-22-2005, 12:56 AM   #5734
Dave-
You posted a while back about a version 2 speedway pal diff coming out in about a month. Does that mean they will be done making them in a month or that they will be available in the US in a month, or does it mean be patient and something new will be out in some multiple of a month?
Old 07-22-2005, 12:59 AM   #5735
Originally Posted by andrewdoherty
Dave-
You posted a while back about a version 2 speedway pal diff coming out in about a onth. Does that mean they will be done making them in a month or that they will be available in the US in a month, or does it mean be patient and something new will be out in some multiple of a month?
They final version "should" be out in Japan in a Month...... . .....
should be out in the states a couple of weeks later... if they make more than 100.....
-Dave
Old 07-22-2005, 01:20 AM   #5736
A Ilievski's Avatar
is the ft tc4 the carbon fibre version if so i really like it
Alex Ilievski
Old 07-22-2005, 01:29 AM   #5737
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
It is a very good car out of the box for the price, but eventually things do wear out pretty quickly. It depends how often you race, but I was running it 2-3 times a week and after 2 months it was just awful. Because the hubs are made of weak plastic, the speed of the driveshafts and bearings inside them wear away the bits holding the bearings in place, quickly. This gives lots of steering slop, often resulting in having to "drive" it down the straight to keep it in a straight line. Yes the hubs can be replaced, but be prepared to do it often. Another problem I found was tweak (surprising with a tub chassis), but what was worse was after clipping a kerb, it wouldn't run in a straight line, and the trims were suddenly all off I found this was down to the shock collars adjusting themselves through vibrations, so I was coming of with uneven ride height. This was easily solved by putting a small drop of superglue inside the collar and screwing it back on, making it a lot harder to turn. If the FT version eliminates the wear problems, it should be an awesome car.
Ali Graham is offline   Reply With Quote
Old 07-22-2005, 01:31 AM   #5738
Ali Graham's Avatar
yes it is the carbon fibre version
http://www.cmldistribution.co.uk/pro...pe=CAR&id=1623
Old 07-22-2005, 01:37 AM   #5739
Default Doh!!
Idiot move # 2. I have been trying to track down a way to order the yokomo shock caps recently. It seemes everyone was out of stock. After lots of helpful advice (including someone who wisely suggested going straight to Yokomo) I decided to give up. Well I have found them. At, . . . wait for it . . .www.yokomousa.com. Apparently I overlooked their shop section when I first looked and went straight to search. Well now that you all know what in ignoramus I am, I can only get smarter. Just thought I'd share this small victory!!
Old 07-22-2005, 03:07 AM   #5740
Originally Posted by RCknight
I blew out both the front and rear plastic diffs tonight. AE diffs are bad and it seems they need rebuilt every 2-3 weeks in stock racing??? I build them according to the instructions so it's not me. The plastic ones expand under the heat and the steel ones are are heavy.
I've run the standard diff in the rear now for 6 months (Stock and 19T) and it is showing hardly any wear at all.
Up front I successfully ran the std diff for 4-5 meetings UNTIL I decided to really tighten the diff up. - then I blew 2 in 3 races! - I went out and bought the IRS alloy ones and no trouble since.
Basically without the "give" of a relatively loose Diff the plastic units are no good on the front.
exint2 is offline   Reply With Quote
Old 07-22-2005, 03:39 AM   #5741
Ali Graham's Avatar
Only matinence I found the plastic diffs needed was greasing and regularly re-tightening as they got loosen very quickly.
Old 07-22-2005, 03:56 AM   #5742
AKARA's Avatar
Did anyone try the graphite chassis set from 3Racing yet? Looks pretty nice and a good price too. Just wondering because if it has good reviews, I'll try it out.
AKARA is offline   Reply With Quote
Old 07-22-2005, 05:57 AM   #5743
Ali Graham:
Sounds like the o-rings are not in the shock collars to stop them from "self adjusting"
JWATT is offline   Reply With Quote
Old 07-22-2005, 08:52 AM   #5744
SpeedTech's Avatar
We should be receiving the 3 Racing chassis very soon, and I'll try and post more detailed pictures, also let you guys know the quality of the graphite and aluminum used. From experience, 3 Racing's product has been very good quality. Here's a picture of the conversion kit for those that are not familiar with 3Racing.
Also we will have a few Speed Way Pal hop-ups next week for the TC4 as well
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 07-22-2005, 11:08 AM   #5745
AKARA's Avatar
Thanks Steve. What is going to be the est-price? ebay.com is $83.99 with free shipping. looks like a pretty good deal! Joey Ellis
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
