Like Tree1Likes
Old 07-15-2005, 06:09 PM   #5611
raving-monkey's Avatar
Send a message via MSN to raving-monkey
i once used the 2nd one in from the outside on the front...that was only when i ran foams on carpet though.
raving-monkey is offline   Reply With Quote
Old 07-16-2005, 07:24 AM   #5612
1shnot's Avatar
Default please help.... can't make 5mins
few info's
-8x1 vantage motor (timming 24d)
-60mm foam front and rear
-3300 batts
-gt7 profile #4
now the gear....
-72spur with (tried) 21 22 23 pinion
now the track..
-150 ft. x 52 ft. NEWLY paved asphalt track
please help It seems to dump at 4min20 sec....
maybe motor timing?
please help!!!!!!!!!
1shnot is offline   Reply With Quote
Old 07-16-2005, 07:32 AM   #5613
Trixter's Avatar
I know this sounds old fashion but you might have to go even lower on your pinion. Take your car our in the street and try this. Measure off the distance of your longest straightaway (from your track) on the street. Then run your car through that measured distance and listen to the motor if it has topped out about 2/3 of the diatance then you are close. I know your car is real fast with those large pinions but that speed isn't needed for the size of track you run.
Slash 4X4, Bone stock and trying to keep it that way.
PRO MATCH BATTERIES.....THANKS JEFF !!
Trixter is offline   Reply With Quote
Old 07-16-2005, 07:46 AM   #5614
Oh sure, I just order my chassis and now Jason talks about a new motor mount.
Actually that looks good. As soon as they're ready I want one!
jiml is offline   Reply With Quote
Old 07-16-2005, 08:27 AM   #5615
ahsikes's Avatar
Trader Rating: 17 (100%+)
is it here yet?
just saw tower hobbies now changed from mid july to "on order"
called my LHS and they allowed me to place the order today.
ahsikes is offline   Reply With Quote
Old 07-16-2005, 08:27 AM   #5616
ahsikes's Avatar
im sure not necessary but talking about FTTC4
Old 07-16-2005, 06:38 PM   #5617
protc3's Avatar
i will be making the motor mount fit the existing BMI Chassis
as for the dumping issue,when you run mod you need to be smoothe with the throttle and conserve power.being smoothe is the key.im not sure what setting 4 is on the speedo but if it set for mod i would just try not to constantly be on and off the throttle.a big mistake i see some people do is run mod with the same throttle habbits as stock or 19 turn.i would also lower the timing on the motor.20 or 21 tooth pinion sounds pretty close.hope this helps.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-16-2005, 09:20 PM   #5618
ahsikes's Avatar
what is the largest spur you can put on the car in 64 pitch?
thanks.
Old 07-17-2005, 08:00 AM   #5619
tc4kid191's Avatar
Send a message via AIM to tc4kid191
The stock chassis or the BMI
tc4kid191 is offline   Reply With Quote
Old 07-17-2005, 01:28 PM   #5620
RCknight's Avatar
Default The biggest pinion....
I can use would be a 37 and still have an easy time getting proper gear mesh.
RCknight is offline   Reply With Quote
Old 07-17-2005, 03:40 PM   #5621
NVisible's Avatar
im sure this has been asked about 50 times on this thread, but i'll ask again anyway
What have you guys done to free up the drivetrain on your TC4? i tried mine out and its not very free at all. This being my first shaft car, im at a loss as to what to do to make it better.
Help me RCTech.net, youre my only hope
NVisible is offline   Reply With Quote
Old 07-17-2005, 04:30 PM   #5622
RCknight's Avatar
Default You can degrease your bearings in the drivetrain....
and lube them with light oil. I wouldn't do the wheel axles bearings though. The drivetrain comes pretty free out of the box. No real need to do anything to it. Another thing to do is make sure the diff and bevel gears mesh the same everytime you rebuild them. Mark two diff gear teeth with a marker and one tooth on the bevel gear. Make sure you line them back up when you reassemble.
Old 07-17-2005, 06:39 PM   #5623
ahsikes's Avatar
I just bulit a new team kit with team bearings. keep in mind if you do it this way and are drving on a very dusty/sandy surface the bearings will not last.
I take out one side of both front and rear diff bearings (the shield) I face that inward so the outside is still somewhat proteceted. i bougt a sonic jewelry cleaner (9.00) and filled it with motor spray and cleaned all bearings except the diff bearings(small ones). i add one drop of bearing lube to each bearing.
i then take a dremel and lightly i say this cause after four tc3's i still took a little too much off my tc4.
dremel where the two large diff bearings ride top and bottom case halves.
then dremel where the small bearings ride. this reduces the pinch when the halves close.
with the "cheaper" bearings and the tires on my car and after todays runs the car still spins for over 30 seconds after giving the tires a spin.
Old 07-17-2005, 07:42 PM   #5624
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Question on spools, one ways, and tire wear. If all things are equal will a spool wear front tires harder than a one way would?
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 07-17-2005, 08:45 PM   #5625
Soviet's Avatar
Yes...
A spool will ALWAYS wear the outside tire more than a one-way.
Remember, a one-way simply allows the front wheels to free-wheel during deceleration. It still retains differential action.
Conversely, a spool is always locked and never functions as a differential (a la inside wheel slower than outside.)
food for thought.
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
