Like Tree18Likes
Old 07-06-2005, 07:34 PM   #5401
The Evicerator
Default VERY DISAPPOINTED!
Things were really exciting in here a week or so ago...everyone was all energized and very into this thread...what happened???
Tony?
Torrence?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 07-06-2005, 07:41 PM   #5402
i_got_m8_4_$85's Avatar
Send a message via AIM to i_got_m8_4_$85
[QUOTE=raving-monkey]well i will soon be BMI equiped so i won't be buying the conversion of the kit...and i will buy Jasons shock towers isntead of AE ones
[QUOTE]
im doing the same thing
i_got_m8_4_$85 is offline   Reply With Quote
Old 07-07-2005, 12:10 AM   #5403
johnbull's Avatar
Tony?
Torrence?
Now, now, Steve !!!!!
johnbull is offline   Reply With Quote
Old 07-07-2005, 07:46 AM   #5404
Originally Posted by exint2
These guys do an excellent CF driveshaft for about 22 delivered from Switzerland (took about 5 days) and you can pay by Paypal.
http://rcmaniax.ch/modules.php?name=...article&sid=10
From the rcmaniax page.
"News: the end of our popular carbon drive shaft
We just made the last batch of our legendary carbon drive shafts for TC3 / TC4 / Pro4 and Yokomo today!
Due to more and more belt driven cars we decided not longer producing the shafts.
We have some in stock right now - first come first serve!
We're actually producing other parts - so watch out our page for new stuff!
If you're interested in producing these great shafts please let us know (we can provide drawings, assembly manuals....)"
andsetinn is offline   Reply With Quote
Old 07-07-2005, 08:06 AM   #5405
TPhalen's Avatar
R/C Tech Charter Subscriber
We don't actually have a definite 'set' date yet....all I can say is it's coming along and should be out fairly soon.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 07-07-2005, 08:14 AM   #5406
Super Moderator
Trader Rating: 17 (100%+)
I have a setup question, I am currently running the 3 deg toe in block on the rear and plan on going to 2 deg. I have seen that people are using the 3 deg block with one of the front blocks in the rear. I was told this gives you 2 deg and widens up the car. Is this correct? Why would you want to widen up the rear? what advantages/disadvantages would that have. and why not the front too?
Tekno | BLOK | JConcepts | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 07-07-2005, 08:32 AM   #5407
TCFOYOAZZ is offline   Reply With Quote
Old 07-07-2005, 08:46 AM   #5408
raving-monkey's Avatar
Send a message via MSN to raving-monkey
i can't see why it would widen up the rear but anyway.....
2 degree rear toe will make the car less stable opposed to 3 deg toe...but if you make the rear end a little wider then it will make it more stable (as the car will have a larger footprint)
i don't see why anyone would want to make it wider because it would be illegal..not sure about US but over here we have boxes that our car must fit into (minus the shell..only the wheels have to fit in) and the box is 190mm wide..if i made my car wider it wouldnt fit (i have about 2mm left on the fronty and about 1mm left on the rear)
raving-monkey is offline   Reply With Quote
Old 07-07-2005, 08:55 AM   #5409
Super Moderator
I understand the differences in the actual toe in. I just wasnt sure why guys are running the wider rear. from what I was told is you replace the Square block with front Circle block and use that with the 3 deg X block. One of the local AE team guys told me to try this and the car I bought had it on there as well.
Old 07-07-2005, 09:03 AM   #5410
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
It does widen the rear of the car up because you are changing the toe in amount from the front rear block and not the rear rear block like you usually would. When you change the cars toe in from 3, to 2 degrees using the marked blocks(2 degree block) in the rear rear of the car, you actually narrow the rear, because the pins are allowed to move in toward the center of the car, decreasing the rear width slightly. This can make the car unstable and harder to drive. If you change the toe in, to 2 degrees using the front rear block, this allows the pins to move out from the center of the chassis giving you a wider rear width, yet still giving you 2 degrees of toe in. THis would make the car turn better under acceleration but will not make it unstable as you have gained some rear track width.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 07-07-2005, 10:00 AM   #5411
Super Moderator
Thanks for the clarification Stephen. I will definitely go back to it.
Old 07-07-2005, 10:13 AM   #5412
Moderator
No problem Bob.
SMC Racing
Old 07-07-2005, 10:17 AM   #5413
Super Moderator
Where are you at with your rubber tire setup? I just picked the car up and Billy Spence gave me a good starting point but I know that Im still a bit off of keeping up with Williams and Cuffs. Could you email me with yours?
robert.barry@cendantssg.com
Old 07-07-2005, 10:38 AM   #5414
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I want to use the yokomo shock caps for my assoc shocks. I just can't get the parts. I am looking for yokomo part # ys-8d. I've looked at several online hobby retailers and they are all out or only have one set on hand. I believe they are sold in pairs so I need two packages for a total of four caps and bladders. I would rather not pay double shipping to get one set from two different shops. Any ideas on who has these in stock? Thanks guys.
Old 07-07-2005, 10:49 AM   #5415
tried speedtechrc.com ? last time i was on his site, he had them in stock.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
