Like Tree18Likes
Old 07-05-2005, 10:24 PM   #5386
fatbear's Avatar
Send a message via Yahoo to fatbear
Originally Posted by Trixter
Anyone able to answer this one?
Hard one to answer because you are talking about two different cars. The TC3 and the TC4 are very different cars even though to the layman they look the same. This was proved when the TC4 first came out and everybody found they had to change their setup completely between the TC3 and TC4.
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 07-06-2005, 12:52 AM   #5387
johnbull's Avatar
How about buying the TC4 BMI kit and the few other bits you need to convert totally to TC4. You will end up with a much better car.
I am presently converting a couple of TC3s to TC4 and you don't need many bits, and all are cheap. Now if you are going BMI then that's a step better again. It may be worth considering.
Parts that spring to mind are wisbones, hingepins and holders, steering parts, centre bearing holder and motor mount, and front bumper. The most expensive single part is the motor mount.
johnbull is offline   Reply With Quote
Old 07-06-2005, 05:28 AM   #5388
Trixter's Avatar
Thanks, I will look into re-vamping my TC3.
Slash 4X4, Bone stock and trying to keep it that way.
PRO MATCH BATTERIES.....THANKS JEFF !!
Trixter is offline   Reply With Quote
Old 07-06-2005, 06:56 AM   #5389
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
I had a BMI TC3 and I will be putting the BMI setup on my TC4 in a week or so. I always thought the TC4 was like the TC3 until 3 weeks ago I puled the trigger and bought a TC4. These two cars look similiar but thats about it. The new TC4 is so adjustable compared to the TC3. I couldn't beleave how different the cars where until I built my TC4. So far performance has been excellent on my TC4 with no complaints. The better gears cases also made my trans. smooth right from the beginning with no extra Dremeling to make it free. If I put ceramic bearings in it would spin even longer. Some minor shimming needed after a few runs but nothing I don't do on other brand cars.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 07-06-2005, 09:09 AM   #5390
These guys do an excellent CF driveshaft for about 22 delivered from Switzerland (took about 5 days) and you can pay by Paypal.
http://rcmaniax.ch/modules.php?name=...article&sid=10
exint2 is offline   Reply With Quote
Old 07-06-2005, 11:28 AM   #5391
Super Moderator
Trader Rating: 17 (100%+)
what are the benefits of running TC3 castor blocks? I bought my car used and I broke a 4 deg block, when I put on a new one I noticed that one side was flat along the bottom and the other side had a spot sticking out for a set screw. Is that the only difference? Im assuming that one was a tc3 block.
Tekno | BLOK | JConcepts | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 07-06-2005, 11:33 AM   #5392
TPhalen's Avatar
R/C Tech Charter Subscriber
The Caster Blocks will work for both cars. The only difference is that the TC3 blocks are not symmetrical on both sides of the block. You will notice a small 'hump' on one side of each block...this was used as a sort of 'stop' when steering in one direction. The new TC4 blocks are symmetrical on both sided of the block, allowing the same amount of throw to both sides.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 07-06-2005, 11:35 AM   #5393
Super Moderator
Am I correct in saying that the ones with the set screw on the bottom are for the TC3?
Old 07-06-2005, 12:19 PM   #5394
raving-monkey's Avatar
Send a message via MSN to raving-monkey
yeah they are tc3 ones.
raving-monkey is offline   Reply With Quote
Old 07-06-2005, 03:36 PM   #5395
Default Hello Mr. Phalen
Just wanted to say Hi and thank you for all of you help.
Coming Soon to an "A Main" Near You! (patent pending)
TCFOYOAZZ is offline   Reply With Quote
Old 07-06-2005, 05:01 PM   #5396
macvolcom's Avatar
Send a message via AIM to macvolcom
Does anyone know the true date, when the new TC4FT is coming out? I called several places today hobby people,ultimate hobbies,robs rc,so cal. Rob told me its shipping out the 15th of july, hobbypeople told me "this friday" , So Cal said " I donno " and same with ultimate. So my big question is when is it coming out? TPhalen whould you know?????
Matt
macvolcom is offline   Reply With Quote
Old 07-06-2005, 05:06 PM   #5397
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Matt
But I guess the real question is "when" is the conversion kit getting released
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-06-2005, 05:51 PM   #5398
well i will soon be BMI equiped so i won't be buying the conversion of the kit...and i will buy Jasons shock towers isntead of AE ones
anyway, i'll take a look around UK store's websites and see when they are saying it will be released.
Old 07-06-2005, 05:53 PM   #5399
well they all seem to think late july...and obviously you guys are gonna get it a bit earlier....so 15th/20th july seems about right.
Old 07-06-2005, 06:41 PM   #5400
macvolcom's Avatar
I think its going to be around the 15th-20th. I dont know what this friday stuff is all about . I doubt its true. + the guy that pickt up the phone work in the airplaine section that told me they are getting it friday, HA what does he know.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
