Like Tree19Likes
Old 06-28-2005, 01:16 PM   #5176
TPhalen's Avatar
R/C Tech Charter Subscriber
Originally Posted by NVisible
If you lost a thumb or an eyeball, that was part of the fun! Thats how it was and we liked it, WE LOVED IT [/grumpy old man]
Now THAT'S funny!
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 06-28-2005, 01:53 PM   #5177
Sleighty's Avatar
If everything had no 'slop' wouldnt it bind? Surely it has to have a little
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 06-28-2005, 02:21 PM   #5178
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Back in the aluminum tub RC-10 days, there were certain times when we would increase the slop in the suspension. On a real high bite track it would help the car rotate (probably helped increase roll steer).
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 06-28-2005, 02:29 PM   #5179
I always set my 10L up with some steering slop for on-road racing. Made it easier to drive!
JWATT is offline   Reply With Quote
Old 06-28-2005, 03:28 PM   #5180
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
For the steering rack, you can sand down the ends of the posts just a touch (like 1/64th) and that gets rid of much of the slop.
That's really the only slop that I didn't like.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 06-28-2005, 05:25 PM   #5181
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
That might be what I'm looking for. Only the right mounting side is loose or sloppy compared to the left. I'm going to work on it later this week.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-28-2005, 05:29 PM   #5182
trx1's Avatar
Send a message via Yahoo to trx1
Arrow
wonder if those chrome rims are out seperately
trx1 is offline   Reply With Quote
Old 06-28-2005, 07:22 PM   #5183
The Evicerator
Originally Posted by Art Garfunkel
I said I was done so just calm down
Hey Art,
How do you like your 'taters?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 06-28-2005, 08:13 PM   #5184
RCknight's Avatar
Default The steering rack slop....
comes from both sets of bushings. You can shim the larger ones on the chassis, but it's the smaller ones on the rack that are too small. I tried to fit it by sanding down alittle plastic and adding shims, but there is still play. Get out your digital caliper and check it. Tolerances are bad. These are the things I would like to see AE fix. The T.F. version it has the same rack. I would think on a TEAM FACTORY AE would fix this problem.
RCknight is offline   Reply With Quote
Old 06-28-2005, 09:02 PM   #5185
Oasis's Avatar
Trader Rating: 36 (100%+)
Art..909 in da house..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 06-28-2005, 09:02 PM   #5186
RandomFellow's Avatar
Originally Posted by TPhalen
Ya, I do. Again, just because ONE person calls, that does not mean we are going to drop everything and research a problem. Maybe you DID do it wrong, maybe not. Once we get numerous calls, there might actually be a problem. At that time, we ask consumers that have the problem to send the parts in...we inspect them, and the make a decision based on the results.
TPhalen,
Just wondering why it is that when AE changes a part, it doesn't announce it so that everyone can know that there is a better part available. For example, when changes were made to the diff cases, why wasn't there a little announcement on the AE website? I just wish we were all a little better informed as CUSTOMERS.
I love the TC4, but there are problems (steering knuckles, rack arms, etc.). That's OK; I know AE will fix them. I just want to know when the parts are revised so that I can upgrade my car.
RandomFellow is offline   Reply With Quote
Old 06-28-2005, 10:24 PM   #5187
i_got_m8_4_$85's Avatar
Send a message via AIM to i_got_m8_4_$85
http://www.speedtechrc.com/store/ebp...nid=236&id=963
are these the right bladder shock caps for the tc4 and are they worth it?, or should i just go tamiya or jrxs ones?
thanks
i_got_m8_4_$85 is offline   Reply With Quote
Old 06-29-2005, 04:55 AM   #5188
Car seems to be carrying a lot better corner speed and not wearing out the foams as bad. I actually picked up an extra lap in three of my sessions last night, new best! Although now I have two more quick questions:
1) How far should the shocks extend when fully compressed? Mine are extending equally but they extend all the way out. I thought they were only supposed to extend out a little bit?
2) One-Ways; What's everyones thought on Foam/High-Bite Asphalt (Fairly tight track but Stock Motor) running a one-way? I've also heard you can just put the one-way bearing in the rear of the car to eliminate some of the classic issues with braking etc? Anyone ever heard of this?
Thanks Everyone!
Nitro-Boy is offline   Reply With Quote
Old 06-29-2005, 06:07 AM   #5189
wyd
Tech Legend
wyd's Avatar
Nitro Boy for the shocks it depends how much oil you are putting in them. I know when I did mine and did what the manual shows mine came out a little less than 1/2 but if I did put more oil in the cap and did everything else the same the shock whaft would come out alot farther since I had more oil in the shocks.
Old 06-29-2005, 06:10 AM   #5190
wyd
Tech Legend
wyd's Avatar
thanks
Those will work for you.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
