Like Tree33Likes
Old 06-28-2005, 10:33 AM   #5161
well i bought the blue ft blocks and the ft hinge pin set and that didnt work just use some nylon washers and sand them on some silicon carbide sanding paper on a flat surface to size
the hinge pins are a definate hop up though well i think so anyway
cheers gaz
andsettin try looking in the bmi discusions thread or pm protc3
gaz8 is offline   Reply With Quote
Old 06-28-2005, 10:38 AM   #5162
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by Art Garfunkel
eXpress Motorsports (Team Driver) LAME
protc3,
Just continue making your second rate aftermarket chassis….OKAY!
TPhalen,
Don’t waist your time with this fool. He is obviously upset because he cant turn a profit.
Art I can see truely no nothing pertaining to this thread. I can see your a credit to this forum. and website.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-28-2005, 10:51 AM   #5163
Art Garfunkel's Avatar
I said I was done so just calm down
Art Garfunkel is offline   Reply With Quote
Old 06-28-2005, 10:57 AM   #5164
johnbull's Avatar
Originally Posted by rayhuang
For the fore-aft slop-I used different thickness motor shims. Its always good to have the brass and aluminum shims around.
That's an old trick. Isn't it amazing, even though we are on opposite sides of the World, we both have the same bright ideas.
I reckon I have more motor washers on suspension arms than I have on motors. And not just TC4's I can assure you.
In fact I think I've yet to discover a car without slop somewhere.
johnbull is offline   Reply With Quote
Old 06-28-2005, 11:03 AM   #5165
wyd
Tech Legend
wyd's Avatar
The most slop I have on my new TC4 is the steering rack. I have plenty of slop their so I guess I will be shimmimg it alot of buy another wrack to see if the results are the same.
Old 06-28-2005, 11:23 AM   #5166
NVisible's Avatar
i have heard the 3Racing steering rack can get rid of that slop
NVisible is offline   Reply With Quote
Old 06-28-2005, 11:25 AM   #5167
raving-monkey's Avatar
Send a message via MSN to raving-monkey
the most slop i have is in the plastic suspension blocks..the hingepins and them little balls actually move inside the blocks so alu blocks all round (i only have the 1 right at the back) are on my list.
raving-monkey is offline   Reply With Quote
Old 06-28-2005, 11:56 AM   #5168
wyd
Tech Legend
wyd's Avatar
I will have to look into one of those.
Old 06-28-2005, 12:07 PM   #5169
Soviet's Avatar
The biggest problem with the TC4 is that some people who buy them are "builders" and not "modelers."
Who gives a damn if a car has a little "slop." Back in the day before idiots gladly paid $400 in order to practically have the car built for them (Ahem Xray ) they actually had a CUT things, sand them and shim them as well...OH NO!!! Not that!!! Hard work that requires a little craftsmanship!!! How horrible!!!!!!!
Next thing you know people are gonna be complaining that the cars don't come out of the box pre-built by "pro" drivers and pre-setup for their home track. Of course if I was to sell cars like that and charged $800 for them, I'm sure some moron would buy them.
It's a HOBBY people, learn how to do more than just turn an allen wrench.
Love,
Sean XOXO
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 06-28-2005, 12:17 PM   #5170
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Raving money, place a thin plastic bag between the block and the ball and then push the ball in and trim the excess plastic. This should take up that slop.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 06-28-2005, 12:17 PM   #5171
NVisible's Avatar
hrm, i didnt see much complaining and crying about slop, i just read some questions & suggestions about how to fix the problem.
Back in my day we had to widdle our own RC cars out of a slab of wood, and had to create our own ICs to make it run. If you lost a thumb or an eyeball, that was part of the fun! Thats how it was and we liked it, WE LOVED IT [/grumpy old man]
Old 06-28-2005, 12:36 PM   #5172
Soviet's Avatar
It's just a point.
Also, if people simply expect their cars to fall together without any work, I'll call them lazy.
-Me
Old 06-28-2005, 12:41 PM   #5173
Soviet's Avatar
Another funny thought though:
You only feel "slop" when you're moving parts with your hands. Once you place the model on the ground doesn't gravity take care of any precieved "slop?" While I understand that you want as "slopless" a steering system as possible, whats so bad about the suspension if it's all equal?
*note - when talking about "slop" I'm refering to about .1 - .5mm worth of free play.
Just a couple of questions to pick brains with...
-Me
Old 06-28-2005, 12:54 PM   #5174
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Default me too
I'm with soviet here. I am more concerned with symetry (sp) than having a slop-less car. Same with my set-up. I would rather have a car that was identical side-side & front-rear that was a little off from my ideal numbers (spring rates, oil viscosities, cambers degrees, etc) than to have a car with one side spot on my numbers and the other side a little off. I never give up trying to get my car perfectly slop free though. It makes me think Im gunna be faster, and thats can be all I need to actual be faster sometimes. : )
Old 06-28-2005, 01:05 PM   #5175
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
TPhalen- it's all good. Hate you can't make it.
John Bull- actually you're right- nobody here is fast with a TC4, but I know it's a super fast car and fully capable of being just as fast as anything out there. I was just trying to talk some smack and get some people to come to our race. It's going to be awesome. We LOVE good competition and we already have some fast guys coming... just not sure if any are AETC drivers.
Keep up the good work AE, and everyone remember; it's not about which car, motor, blah blah blah, it's about the fun, friends and promoting this hobby which is growing quite fast in these parts!!
Happy Racing,
Jason
BigDogRacing is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
