Like Tree6Likes
Old 06-27-2005, 07:58 PM   #5131
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Hey Phalen, why don't you quit startin crap on the internet and come take your whoopin like a man on July 30-31???
Our Beat the Heat Race is July 30-31 in Memphis TN. IT's electric and nitro on-road run on a pretty good size nitro track. All the fast guys are running 19t and mod since the track is a nitro type flowing layout. We're kinda reserving stock for the novice and sportsman guys.
We have racers coming from Texas to uhh... up north somewhere..lol
Schedule-
Fri evening- set up track
Sat- practice and 3 rounds of qualifying
Sat night- cookout and cold beverages (BYOB)
Sun- short practice, quick 4th round (if time permits) then single mains. Expert nitro sedan runs 30 minute A main.
Personally I doubt any non-factory racers will come whip me at my home track, but we'll have to see...
BTW- that goes for all you Associated chumps!!! Come taker your Xray whoopin like a man!!!!
Hey Tony, tell the boys to hook us up with some cool swag this year. It's looking like BTH05 will be about twice as big as it has been the last few years.
Thanks!!!
Jason
note- you guys chill. I know how you might feel from both sides, but none of this will sell cars or kits. You're just making more racers sell their TC3,4 and buy Xrays... which they were gonna do anyway after they get their Memphis Xray butt whoopin !!!! LMAO!!!!!
Happy Racing guys!!!
Link to MSRA forums and the BTH05 thread
BigDogRacing is offline   Reply With Quote
Old 06-27-2005, 08:17 PM   #5132
RCknight's Avatar
Default T. Deguzman....I think Jason's talking about the stock TC4 chassis..
Originally Posted by T. Deguzman
How can you have 'specificly placed' something and be 'not really sure where it ends up' ?
Again with the comparisons to a car you don't have in your possesion. What makes you think that our chassis is narrowed only on the battery side?
Is this BMI's style of engineering? Using conjectures and speculation?
on the servo placement and chassis width.
RCknight is offline   Reply With Quote
Old 06-27-2005, 09:49 PM   #5133
Oasis's Avatar
Trader Rating: 36 (100%+)
Big Dog.. ..Anyone have a carpet setup for stock with rubber tires??
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 06-27-2005, 10:31 PM   #5134
Klaus Daimler's Avatar
So then, was the TC4 engineered to be that much overweight? It is by the numbers right (pretty easy to use empirical data to predetermine the part weight given the density of the plastic, the volume of the part, and the approximate fill density)? Was it engineered to have that much slop in the suspension components? I'm pretty sure I added an unequal amount of shims on both sides to get it even from side to side. Runs great... but lets save the engineering speaches for something besides low volume toy cars.
Klaus Daimler is offline   Reply With Quote
Old 06-27-2005, 10:31 PM   #5135
Art Garfunkel's Avatar
Originally Posted by protc3
hey art,then dont buy one!!your oppinion is about as ignorant as the picture you posted.
Yeah, well, that's like, your opinion, man!
You..you.. human paraquat!
SHOMER SHABBOS!
Keep up the great work you .. you fobbing elf-skinned fat-kidneyed flap-dragon!
Art Garfunkel is offline   Reply With Quote
Old 06-28-2005, 12:13 AM   #5136
very true about the slop in the hinge pin/wishbones area. even the steering posts that hold the rack in place were to long and as a result left much slop.i just had a friend mic them up and cut them to size at work, its sweet now!
i found there was a lot of slop with the wheels too,like from the wheel to the hub this also required shimming or them ft hexes with the slot for the axle pin milled slightly deeper so you can nip them up tighter against the hub but not to tight as to cause friction.
anyway im totally chuffed with my tc4 even if it did require abit home tuning
(british style).
its a fast car, to fast for me as im not that good a driver as its my first year at it.
i raced my car at 6 meetings and finished 19 out of 50 in the 19t class.
i had many teething problems but im happy how things turned out
ive found that the thing that was hindering me most was my ko helios
i just didnt have a clue how to set it so i could gain more control over the car
it was way to sensitive and fast,
and it seems so much easier now its set up better,
cheers gaz
gaz8 is offline   Reply With Quote
Old 06-28-2005, 12:55 AM   #5137
UNSTABLE's Avatar
This thread's better than the "ask someone who doesn't know" thread .
Some R.C. stuff.
UNSTABLE is offline   Reply With Quote
Old 06-28-2005, 01:11 AM   #5138
pitshop's Avatar
Trader Rating: 56 (98%+)
Originally Posted by TPhalen
Great. Problem solved.
Next time read my response about how we don't just 'give away free stuff to everyone that calls'. See if Ford or Dell or Motorola gives away free stuff without doing some research on the problem first.
I'm totally with AE on this one.
When the TC4 first came out, some of our clients had diff problems...
We did have access to a machine shop so we fixed the gears ourselves.
However, I did tell AE about it; NOT asking for replacement or anything...
but a week later, a ton of gears lands at my door...
free replacement
AE has THE BEST CUSTOMER SERVICE... (well them and Novak )
PIT SHOP 153-D Araneta Avenue
Q.C. opposite PNB between SM Sta Mesa and So En
tel (632)716-6553 fax (632)714-0550
YOU CAN CALL 09174632746 OR 09175331943
please like us on FB - PITSHOP RC
pitshop is offline   Reply With Quote
Old 06-28-2005, 01:12 AM   #5139
RCknight's Avatar
Default Looking at the Team factory TC4...
I do like the idea of having aluminum camber link braces. I wouldn't want to use a nut under the CF upper deck. I still think two camber locations could be removed like the Pro 4. Looking at the design, I like how AE used the aluminum camber link as the spacer. Only thing though, they could have lowered the upper deck even more, but they bolted it higher than the top of the brace. Why not recess it and make it at least level with the top of it. I think the upper deck will be 2.5mm higher than the BMI chassis. Personally, I would have rather had it even lower, even if I could not get the diff cases out without removing the upper deck. I know it's not that important, but the RDX must have the lowest deck of any car out. It can't be a bad thing? Just nit picking.
Old 06-28-2005, 01:16 AM   #5140
RCknight's Avatar
free replacement
I'm still waiting for turn over at my hobby shop so I can get some. Along with carbon arms. Bad thing, it will be a few years.
Old 06-28-2005, 01:31 AM   #5141
fathead's Avatar
Here is my guess on the top plate, being a little bit higher I imagine it makes it a little bit easier to get at stuff and fit and also it will make the car a little bit stiffer especially longitudinally
Slavich Design
fathead is offline   Reply With Quote
Old 06-28-2005, 04:04 AM   #5142
protc3's Avatar
very well spoken art,now im starting to wonder if you were the guy in the picture
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 06-28-2005, 04:17 AM   #5143
JDM_DOHC_SiR's Avatar
Trader Rating: 30 (100%+)
Default Man what happened???
I don`t read this thread for one day and everybody is at each others necks..??? WOW....?? What ever happened to talking about stuff if you have a problem with a post over a PM..?? ...
I hope everyone can come to some sort of understanding
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-28-2005, 06:40 AM   #5144
tc4kid191's Avatar
Send a message via AIM to tc4kid191
-Dave
same here
tc4kid191 is offline   Reply With Quote
Old 06-28-2005, 07:56 AM   #5145
Oasis's Avatar
Yep thats what i like in a thread..constant bitching and no "real" help.. The other is people who dont own the car yet feel that they need to "enlighten" me on my(what they"think")poor choice..
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
