Old 06-24-2005, 12:23 PM   #5011
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
Gaz, sounds good.
I was thinking of getting a BMI until how soon I realized that the FT TC4.
Paul_TC4 is offline   Reply With Quote
Old 06-24-2005, 12:28 PM   #5012
Super Moderator
Trader Rating: 17 (100%+)
Gaz, Jason is working on 3mm shock towers with alum mounts.
Tekno | JConcepts | RRP | LutzRC | BOOM RC
Bob Barry is offline   Reply With Quote
Old 06-24-2005, 12:29 PM   #5013
RCknight's Avatar
Default The Team F. chassis is going to be much stiffer....
than the BMI one. The BMI is about the same stiffness as the molded carbon one. So there is no gain in that department for carpet.
RCknight is offline   Reply With Quote
Old 06-24-2005, 12:33 PM   #5014
Super Moderator
I think the main differences in the BMI and the tub chassis is placement. I know that the BMI has stuff all moved around. I am still running the tub until Jason gets more in stock then I am switching.
Old 06-24-2005, 12:47 PM   #5015
RCknight's Avatar
Default Yes, I agree Bob Barry.
better placement, but I think with the flex you don't gain anything on carpet. A new design like the TFversion will help with flex and you can balance it easy with the new motor mount. I hope Jason will make a TF version of his chassis.
Old 06-24-2005, 02:25 PM   #5016
Trader Rating: 16 (100%+)
I'm afraid I'll have to disagree with you on that one. I have both and the BMI is definately stiffer. It also was more predictable on carpet.
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 06-24-2005, 04:35 PM   #5017
protc3's Avatar
RC Knight,
the FT chassis will not be as rigid as my kit due to the difference in the material.the component grade c/f is only rigid front to rear and is very flexible side to side.component grade C/F also has almost no memory meaning that it will hold a tweak.if you notice on my chassis kit you will see that it is pre drilled for a center stiffener that is actually functional.this is an option because it is not necesary unless you run on extremely high bite carpet.the placement of the batteries,motor and steering rack on my chassis is the strongest advantage over the FT.i assure you the FT is just a C/F version of your existing car.and as for me making a FT version,there would really be no point.the FT is almost an exact duplicate of what i released 6 months ago.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 06-24-2005, 04:45 PM   #5018
protc3's Avatar
and as for questioning the engineering at BMI,remeber,this is a fun thing for me.designing chassis kits is childsplay to our business.we design medical molds,machinery for automated micro circuit repair machinery,we took part in the fabrication of a satelite that went into orbit.AE im sure does there job but to say they are more qualified than our company is really not true.all of our chassis kits are designed to be an improvement over stock,if they are not they do not get released.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 06-24-2005, 07:58 PM   #5019
i_got_m8_4_$85's Avatar
Send a message via AIM to i_got_m8_4_$85
http://www.kthobbies.com/shop/produc...93a47dfaea8712
any one see this
i_got_m8_4_$85 is offline   Reply With Quote
Old 06-24-2005, 08:15 PM   #5020
RCknight's Avatar
Default TF not as ridged?
Well, I have not had one in my hands, but AE does say that you won't need an after market chassis for different track types. All those standoffs down the center should make a difference even if the CF is not as high grade. I guess we will all have to wait and see. Tony P. any comments?
I would be much happier and it would shut me up if you would make me my custom chassis.
Old 06-24-2005, 08:58 PM   #5021
protc3's Avatar
using standoffs down the center is not very effective.being that the upper and lower footprint or mounting surface is very narrow it has very little effect on the rigidity.now adding multiple standoffs just will increase the chance of tweak being that it does not have enough bracing surface.just look at the set up they used at the reedy race.no side standoffs to add flex.what happened to those usefull center standoffs?they do not do much.this is why i offer the wide center support that braces wider for more leverage and allows the brace to do its job without all the clutter.trust me on this,i started this whole wide bracing and center support bit about 3 years ago.i agree with you on the motor mount dude.it seems when i do something people want to see it like AE setup.when AE does what i did its now ok.i cant win.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 06-24-2005, 09:01 PM   #5022
Paul_TC4's Avatar
Hey Jason,
Could you tell us what are some differences in placement of things on your chassis rather than the TC4 tub? (i.e. battieris moved closer in to center)
I appreciated it, Later
Old 06-24-2005, 09:10 PM   #5023
protc3's Avatar
Paul TC4,you have a PM
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 06-24-2005, 09:40 PM   #5024
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Originally Posted by Bob Barry
Brian you wont be dissappointed!! Especially when you talk to Jason. He has a entire line of stuff coming out in the next few months for the car. We are going to West Chester tomorrow if you are up for it.
I hear that. Can't wait to see what Jason has up his sleeves. I always like my BMI TC3 and BMI Pro4. Both were great improvements over stock setups.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-24-2005, 10:45 PM   #5025
Taz_S's Avatar
Jason:
when are you going to update you website to show the tc4?
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
