Team Associated TC4
#4981
Whatever was stock. I don't remember right now (setup sheet is at home in the garage. . .oops) but I do know that I went back to stock and the car was much more tunable.
((I had started out with a "hooked" setup from someone else and I just didn't like it. . .went back to stock and started over.)
#4982
Ok, just got me a TC4, is there any things i should pay extra attention to when i build it? any small tricks? have been racing the TC3 in the past and do miss it, so the tc4 was a natural choice
only thing i have ordered for it so far is the yokomo shock caps.
#4983
Well guys my first run with the TC4 was this weekend. I must say coming from a belt car (Mi2) this was quite a change. I thought that the car was pretty good. My setup needs some work still but I felt faster and more confident than I did with my Mi2. After I do some more testing I will post a set up on here. I think the first thing I am going to try is 35 wt 2 pistons and silver springs all the way around. I have a feeling this car likes soft setups. I will keep you posted!
Bob
Bob
#4984
hardened hinge pins would be a good idea as standard are like buttersoft
lightened steel diff out drives and its ready to roll!!
cheers gaz
cheers gaz
#4985
Bob
Bob
-Dave
#4986
ive gone red front gold rear...on carpet with sorex 20r's..thats with 40wt F+R
it works really well..no lack of grip and still plenty of steering, i think i could go to red/red and it would still be fine.
saying that, even you US foamy guys seem to be running red/gold...i usually run yellow/purple on foams....maybe its just my driving style
#4987
Tech Legend
Trader Rating: 51 (100%+)
Bob
Bob
#4989
hey guys i was wondering if anybody had a front diff setup for low to medium grip asphalt or can tell me where to get a good one
#4990
Do any of the online hobbyshops have the FT TC4 yet?
#4991
i dont think its out till july
#4992
I ran on CS27's blue spring 60wt and 2 pistons all the way around. front shocks outside on arm and tower rear shocks second hole from outside on tower, outside on arm(i think i dont remember) no sway bars. diff in front. Camber Links were front 1 hole away from center with no washers, rear all the way in with 1 washer.
The car would probably be better with like 30 - 40 wt and maybe swaybars. Over all it was still pretty good with a slight push.
#4993
anyone hear anything about a conversion kit yet for the FT TC4?
#4994
Yes, but I've heard it won't be out till AFTER the FT kit comes out.
#4995
Tech Legend
