Like Tree38Likes
Old 06-15-2005, 10:03 AM   #4966
I'll have to try and shim the front, I was running on carpet until they pulled it up last week.
Understeer would be needed on entry because that's when it jerks the tire up. I thought it was all driver just steering too fast or too much steering but now I think it's setup
Nitro-Boy is offline   Reply With Quote
Old 06-15-2005, 12:09 PM   #4967
Can you adjust the wheelbase on this car like you can the TC3? My short wheelbase setup has always been fast on the TC3.
WingZero is offline   Reply With Quote
Old 06-15-2005, 12:13 PM   #4968
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
The TC4 wheelbase adjustment is a little different but ofcourse, the same concept as the TC3's wheelbase. It's more adjustable than the TC3's wheelbase. And, the TC4's wheelbase can be adjusted front and rear.
Paul_TC4 is offline   Reply With Quote
Old 06-15-2005, 12:32 PM   #4969
That's good to hear cause I just ordered two Team Kits. I figure that I will only have to upgrade when I feel the need to.
Old 06-16-2005, 06:59 AM   #4970
Hello,
I purchased the Lightened Steel Diff Outdrives for the TC4 and also the required parts, #6575, 6579, 6909. I am not sure how it all goes together. I have looked for a picture or a diagram on the Associated site but I can't seem to find any. I am mostly confused on the Thrust bolt and the black plastic washers that come with it. Also, do I use the spring from the original diff or any of the flat steel washers?
Thanks for the help.
Matt
mpetrich is offline   Reply With Quote
Old 06-16-2005, 07:10 AM   #4971
Found the pic in the TC3 manual.
Thanks,
Matt
Old 06-17-2005, 06:55 AM   #4972
dmatter's Avatar
About the only thing that I have bought lately that made me Happy was mmmmmmmmmmmmmm...........................A Bottle of Dynamite Body Cleaner. About $5.00 It works well on Scuffs and Brightens your Body Nicely and lasts a Long time! Kind of like a OLD Toyota Truck Cheap..Tough..and it will last you a long time..
dmatter is offline   Reply With Quote
Old 06-18-2005, 10:28 PM   #4973
Why do the Factory drivers run .120-.180 of washers on the steering rack & front upright?
Boomer,
You're running foams correct? I know everyone told me to add shims if I wanted to try rubbers...
So in the Front you're running:
.050" Circle
.075" & .025" Triangle
What shims are you running in the rear?
.075" & .025" Square & X?
Old 06-18-2005, 11:10 PM   #4974
tc3 racer sc's Avatar
which wheel base wrks the best i see alot of guys run on rear 2spacer ffwd 1 spacer in bck and in front 1spacer fwd and 2 spacer bck im still learning the car so bare with me and also stock location help too
tc3 racer sc is offline   Reply With Quote
Old 06-19-2005, 12:32 AM   #4975
Default How long will the FT TC4 last?
Hi Guys,
How long do you think the FT TC4 will last until a new model comes ?
Jus curious, will AE adopt the same policy like the TC3 ... upgrade till it is no longer competitive?
Or Will they change cars every so often like the Japanese makers?
Cheers!!
marzin is offline   Reply With Quote
Old 06-19-2005, 12:46 AM   #4976
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Ohh boy..years and years.When AE comes out with a new design for their R/C's they don't change it.
Look how long old the TC3 is and look how old the RC10GT is.
Sean
Team Duratrax is offline   Reply With Quote
Old 06-19-2005, 01:47 AM   #4977
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I think it will be around for some time. Associated has always been great and designing a car that is competitive for years to come. They have never been into the car of the week club. Other companies keep bringing new models or variations but in all reality they are not really any faster or too much better than their previous model.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-19-2005, 06:58 AM   #4978
Oasis's Avatar
Trader Rating: 36 (100%+)
I'm not so sure on that one(new car every 6 months)If thunder tiger did buy Associated I'm sure we will see some changes.And on the TC3 being no longer competitive..It's still a fast car..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 06-19-2005, 11:26 AM   #4979
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
It's to reduce bump steer and to fine-tune their ackerman to the way they want it.
I run rubber - and stock shims all around. I do have 3 washers under the camber-ballstuds - makes the arms more parallel and doesn't create as much negative camber on full compression. I also have two washers under the steering link at the knuckle - kills almost all bump steer.
I'm running the 2deg block in the rear.
Boomer,
.050" Circle
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 06-19-2005, 05:22 PM   #4980
Thanks that makes sense!
What shims are you running under your front and rear blocks?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
