Like Tree26Likes
Old 06-02-2005, 09:07 AM   #4801
NVisible's Avatar
Originally Posted by gaz8
i have just built my bmi tc4
its a real nice quality chassis i think bmi got this just right it weighs 20 grams less than my graphite tub and is a lot stiffer here is a few pics
very nice there. 3Racing towers? Did those TRF Shocks fit right on, or was there some extras needed?
NVisible is offline   Reply With Quote
Old 06-02-2005, 09:19 AM   #4802
hi
yes your right those are 3 racing shock towers.there quite nice
the trf ms shoocks fitted straight on i just used 3 racing ti shock bushings at the top and tc4 ball cups at the bottom
they were much easier to build than the tc4 ones.
cheers gaz
gaz8 is offline   Reply With Quote
Old 06-02-2005, 10:21 AM   #4803
losi jon's Avatar
Originally Posted by TPhalen
Good shots, LZ. Looking closely at the 3rd one, I was wondering to myself what the heck I used to cut out those wheel wells???? Holy cow . Did I use any sort of sharp object or did I chew them out...
Sheesh.
ummm Tony..i didnt want to mention it,glad you did
I thought you let your dog give it a good chew
losi jon is offline   Reply With Quote
Old 06-02-2005, 11:53 PM   #4804
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
I definitely see teeth marks. . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 06-03-2005, 01:07 AM   #4805
johnbull's Avatar
Hey Tony. Looking at the pic, I see you're no spring chicken.
No offence meant of course, but join the gang.
johnbull is offline   Reply With Quote
Old 06-03-2005, 06:00 AM   #4806
D_Ames's Avatar
Send a message via AIM to D_Ames
D_Ames is offline   Reply With Quote
Old 06-03-2005, 06:22 AM   #4807
D_Ames's Avatar
AAAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHAAAAAAAAAAAAA A!!!!
Old 06-03-2005, 07:00 AM   #4808
losi jon's Avatar
Tony has been around the block,i have seen some old race footage with him in it kicking some arse out on the track..this guy could win any race at any time
Old 06-03-2005, 07:00 AM   #4809
Hi Guys,
I m really having a hard Time with my TC4 at the moment the ESC\Motor are overheating and cant find whats causing this...
My drivetrain is perfectly free, it spins for over 10 secs and I even changed 12 bearings that didnt even really needed to be changed, just to be sure...
If at least it was only the motor I could probably bear it but the ESC (GTX) overheats meaning something is puting stress on it I guess...
Could it be the diffs being to tight? or overtightened wheel nut? (I know its stupid)
How long can you touch the motor after a 5 min run? BTW, my gearing is fine and I tried loads of motors and gearing combo...with no result...
Some help would be greatly apreciated!!
Thanks Guys!!!
Tbevofreak is offline   Reply With Quote
Old 06-03-2005, 07:02 AM   #4810
Super Moderator
Trader Rating: 17 (100%+)
Gear Mesh, If it is too tight you will smoke motors, speedos, you name it. It happens. gotta have a little wiggle
Tekno | JConcepts | ProTek RC | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 06-03-2005, 07:08 AM   #4811
Tight diffs won't cause drive train drag. If you still spin after the wheels are on, it is probably not an overtightened wheel nut.
What motor and gear? Track size? Do you run a fan? Have you tried the motor in another car to see if it overheats?
JWATT is offline   Reply With Quote
Old 06-03-2005, 07:10 AM   #4812
Will the TC4 hold 3700's? 3800's?
Old 06-03-2005, 07:18 AM   #4813
Thanks guys,
My gear mesh if fine, I always leave a little woble
I run 12T 9T 8T, the last run I used a 9T geared at 8,4 FDR 8 degree timing, I have the AE duct\fan kit installed
Honestly, I tried loads of different motors and gearing and checked with other drivers, they cant find whats causing it...
I run on a high traction medium size track
Old 06-03-2005, 07:23 AM   #4814
Ask them to run your motor/gear for a test. Are you geared close to them for the same wind motor? Have you checked the bearings in the motor?
Old 06-03-2005, 07:47 AM   #4815
What are you using for hexes on the axles? If you are using the plastic for example and overtighten the wheelnut this could possibly cause binding.
Have you tried a different ESC?
I was runnin a 10T double at 8.9 fdr on a high bite medium sized track (different car) and it gets pretty warm but not hot.
If I run a 19T QM at 6.5 fdr you can hold your finger on the can for maybe 2 seconds....
MartynD is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
