Like Tree19Likes
Old 10-08-2004, 05:18 PM   #451
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
Phalen, what is the part # for the ball studs, all of them on the TC4 with the new hex style head, including the ones on the hubs, caster blocks, shock towers, and also how much do you think they would cost, and also how many are in each package, I can't seem to find this info
tc3stocker is offline   Reply With Quote
Old 10-08-2004, 05:44 PM   #452
Default I noticed something about the
chassis. There are cut outs for new fan thingy, but there is not enough surface area to tape my speed control down securely. Ugg......
Will the flying fish of today, someday be a bird? Maybe a fish is just a fish.
Nightbreed is offline   Reply With Quote
Old 10-08-2004, 05:52 PM   #453
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Nightbreed- Depending on how much your LHS discounts from MSRP, you could look into a set of ceramics or something like Boca ultra seals for the price that AE will retail the whole set for. But then again, some LHS's do better than others. Something to think about.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 10-08-2004, 05:59 PM   #454
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: I noticed something about the
Shoe Goo works wonders ..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 10-08-2004, 06:03 PM   #455
Default Ya...
I have thought about a set of Acer ceramics, but I have read good and bad things about them. Some said the seals fall out, and some said Acer told them to clean out the grease to get them to free up. I don't think so for $100. So I thought I would go with AE bearings since I know they are good. I would like a good teflon sealded bearing like AE's but in a high quality ceramic. I don't know of any company that sells them yet. Any suggestions? Are the Niftech teflon sealed any good? I want something with a good seal for carpet racing. I can always degrease them.
Old 10-08-2004, 06:08 PM   #456
Default Re: Re: I noticed something about the
-Dave
Old 10-08-2004, 07:56 PM   #457
tc3stocker's Avatar
that is 1,532! uses for the all so wonderful Shoe Goo wonder glue
Old 10-08-2004, 08:05 PM   #458
JimmyMac's Avatar
I think I found a slight problem with the new TC4 side braces/camber link mounts. When in place, they do not let you remove the diff from the lower case unless if you mod the brace. At least this is what I have found.... I dunno...
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 10-08-2004, 08:09 PM   #459
Default Another...
ugg.
Old 10-09-2004, 12:59 AM   #460
It doesn`t look to be that much of a problem...nothing that a nice file or a few seconds with a dremel can`t fix
-Dave
Old 10-09-2004, 05:57 PM   #461
Default TPhalen...
how about a team factory hinged battery strap? One that is hinged on the one end and the one end screwed down. Just an idea.
Old 10-09-2004, 07:40 PM   #462
JimmyMac's Avatar
It's not a problem, about 10 seconds on the dremel and now the diffs clear the brace. All ya have to do is cut a bevel or angle into the brace that sits right above the diff. Perhaps a quick simple revision to the TC4 brace would cure this... hehe
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 10-09-2004, 09:37 PM   #463
Default Kilruf...
Is that both the front and back diffs? How much did you have to take off? I hope they mill out the battery slots for reduced weight. Cough...Cough....
Old 10-09-2004, 11:50 PM   #464
KilRuf..did you get yours yet.???
Old 10-10-2004, 01:11 AM   #465
jzone's Avatar
Drumel off about 3mm. in length from the most inside hole at a 45* angle. This should be able to clear the diff and also clear protruding drive pins out of the drive cups, when you're using the IRS bones w' the pin cushions.
Jesse Galang
Northwest R/C Club - VP
OverGeared Racing OG
Team Associated | Reedy | Orca
jzone is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
