Like Tree19Likes
Old 05-19-2005, 12:25 AM   #4621
S_fender's Avatar
Mike D,
I run the short camber link location on front and rear because i'fell the car is more stable and easy to drive on carpet.
Here is my setup in Le havre:
Front:
Std ballstud, no washers, outer
Circle shims= 0
Triangle shims= 0
Arm spacing = all washers on the rear.
0.55 anti-roll bar
2 caster block
1 white plastic washer for bump steer
Shock tower mounting position N 2 (1 is the outer)
Shock A-arm mounting position N 1 (1 is the outer)
Piston = 1
Oil = 60
Spring =Silver
Ride height 5.5 mm
Droop 5.5
camber 2
Toe 0
standard ballstud on steering rack and 0 washers
Oneway.
I put 1 washers (0.8 mm) on to have 190 mm
Rear:
Square shims= 2
X shims= 2
Arm spacing = all washers on the front.
shock tower mounting position N 2 (1 is the outer)
Rear upright = Inner position (Std)
Piston = 1
Oil = 50
Spring =Green
Ride height 6 mm
Droop 2
camber 2
Toe 3
Metal diff (Plastics are to hot)
Body = Protoform Status 1.0 + protoform plastic wing (190 mm)
Tires SOrex 32M, Insert = GM green (Or xenon, or much more)
Wheel = Orion Hard
Traction compound = Corally Tc2.
S_fender is offline   Reply With Quote
Old 05-19-2005, 04:58 AM   #4622
Thanks D_Ames!
Nitro-Boy is offline   Reply With Quote
Old 05-19-2005, 06:38 AM   #4623
S Fender,
Its good to know the car is working well for you, personally I find it very easy to drive and it reacts well to setup changes
I m having problems with my motors overheating because some of my bearings are bad so I m looking for a whole new set of bearings at a decent price
I think 3 Racing makes some cheap ones
Tbevofreak is offline   Reply With Quote
Old 05-19-2005, 07:24 AM   #4624
get some acer ceramic ones they are cheaper than ft teflon ones and are much better i put them in mine and they are silky smooth
cheers gaz
gaz8 is offline   Reply With Quote
Old 05-19-2005, 07:26 AM   #4625
I suggest not putting ceramics in the hubs, especially the rears. Of course if you never hit anything you might be ok.
Replace everything but the hub bearings with ceramics, in the hubs use some cheap bearings so the pain isn't so bad when replacing them. Ceramics are also more fragile ..
MartynD is offline   Reply With Quote
Old 05-19-2005, 07:59 AM   #4626
Speedyjay's Avatar
Originally posted by Nitro-Boy
1) Will the TC3 tuning guide work with the TC4 also, is most of it the same for tuning?
NO I have been told by many drivers (including factory drivers) to treat the TC4 as a completely different car. When the car first came out lots of people had headaches trying to make it work....because the TC3 setups dont work the same.
Treat the car like a brand new incarnation, not anouther TC3 mod
2) If you run 4 degree caster blocks, 0 circle shims, and 2 triangle shims (thus 2 anti-dive) does your caster come out to 2 degrees?
Yes they will cancel out
3) Is the rear X degrees not noted on any of the setup sheets? I see 2, 2.5, and 3 degrees are available but not noted to my knowledge. Whats the difference from a 2 degree to the 3 degree?
The kit comes with 3 degrees in the rear (I am assuming you are talking about rear toe in?) This gives a bit more traction in the rear end during a corner exit/entry.....
The less rear toe = less rear corner traction
4) On the setup sheets does 1 washer refers to the AE .031-.032 plastic washers or the aluminum .029-.030 washers? Or does .001-.002 make a difference?
Not to sure what you are talking about here (no set up sheet in front of me at the moment)... but rule of thumb is that the plastic spacers are used in the arms (wheel base) and the steel washers are used in the camber/steering links.
Anouther thing to note that is not noted in the manual is that the washers (steel) come in different thicknesses. You will see a gold/silver mix in the kit. Silver is thinner while gold is thicker, these are stacked inder the ball links. Id give you exact thicknesses, but again I dont have it in front of me this moment.
Hope that helps
Try to show up with your factory settings for Carpet/asphalt...then adjust in order...
1 tires
2 springs
3 camber (degree adjust)
4 ride height
5 toe in
Once you get those down then fine tune with Droop/ Roll center/ caster.
You'll find where the TC3 was a butcher knife, the TC4 becomes a scalpel
Speedyjay is offline   Reply With Quote
Old 05-19-2005, 02:58 PM   #4627
S_fender's Avatar
In my opinion, never use ceramic bearing it cost to much...
I've changed my tc3 bearings with bocca bearings Ultra seals... Very good. Less slop and very reliable..
Old 05-19-2005, 03:55 PM   #4628
Well if you don't use ceramics in the hubs, it saves alot of money. With ceramics in the diffs and drive shaft, they will likely last longer than the car, while saving weight and adding efficiency.
Old 05-20-2005, 12:51 AM   #4629
wothrottle's Avatar
I highly recommend AVID bearings, they are pretty good, great service and the price is unbeatable! try avidrc.com
wothrottle is offline   Reply With Quote
Old 05-20-2005, 01:25 PM   #4630
Default TC3/TC4 same bearings?
Do you know if the TC4 uses the same bearings as the TC3?
Cheers
Old 05-20-2005, 02:09 PM   #4631
tc4kid191's Avatar
Send a message via AIM to tc4kid191
Yes it does
tc4kid191 is offline   Reply With Quote
Old 05-20-2005, 02:11 PM   #4632
SMcpot's Avatar
Trader Rating: 22 (100%+)
Smile
It does
SMcpot is offline   Reply With Quote
Old 05-20-2005, 10:20 PM   #4633
Trader Rating: 68 (100%+)
Good luck to all associated guys at the REEDY,get ur dun baker
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 05-20-2005, 11:54 PM   #4634
RCknight's Avatar
Default Good luck...
Blackstock and Baker!!!!
RCknight is offline   Reply With Quote
Old 05-21-2005, 04:43 PM   #4635
gibbous's Avatar
Anyone see anything interesting at the AE booth at RCX?
gibbous is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
