Team Associated TC4
#4531
Originally posted by raving-monkey
abd why would you want to run green springs on grippy asphalt?
BOOMER. We haven't got that far with trying things yet, but yes, it's one of the things I plan to try in the future. The thing is that we find the car extremely well balanced with the same settings front and rear - springs, oil, shock angles, etc.
#4533
arms
Originally posted by Taz_S
I getting a use tc4, i want to know what the 1st thing i should get for backups?
#4534
First off get the RPM front bumper and the lightweight or IRS front diff assembly. That's just to actually drive the car without problems. Parts wise, get some 0 deg. Losi rear hubs.
#4536
i'd say a set of polished hinge pins are a must...the std ones are so weak and bend easily.
for spares, get a pair of front wishbones, pair of rears...set of rear hubs + front steering blocks (came in same packet)....i never broke any castor blocks but get some 4 degree ones to play around with
#4537
Just get every Factory Team part . I have had nothing break.I have alot of the AE hopups.I drive my TC4 every monday, thursday and I crash into little bumpers and thing alot, and no problem .
#4539
Location: San Marcos/San Antonio, Tx but chillin in Orlando, FL for now.
How much do the IRS pincushions slow down the wear on the IRS spool? I used the spool for one weekend and it showed a bit more wear than i thought it would, and im hoping to use the cushions to alleviate this.
--Mike
--Mike
#4540
Well I can't comment on the IRS pincushions, but a friend ran the IRS outdrives with the stock bones and wore the outdrives out in less than 3 weeks.
I believe after that he changed to IRS composite dogbones,
#4541
Hello guys I should be getting my car today and I need a setup for stock and for 19 turn both outdoor with CS-27's as a spec tire. Any help would be greatly appreciated.
Bob
[email protected]
Bob
[email protected]
#4542
where can I get the pdub bumper?????
#4543
Bob
[email protected]
Bob
[email protected]
TC4
Charles
#4544
#4545
--Mike
--Mike
