Like Tree59Likes
Old 05-06-2005, 09:45 PM   #4471
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by gene465
Dave were those the 3Dr steering knuckles on your car? Thanks Gene
Square makes them Gene...
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 05-08-2005, 01:03 AM   #4472
losi jon's Avatar
ttoooooooooooooooooooooppppp
losi jon is offline   Reply With Quote
Old 05-08-2005, 01:25 AM   #4473
jzone's Avatar
Hey guys,
i'm going to race at theReedy Race in 3weeks and am looking for some setups with use of a spool in the front. Honestly never ran one. I wanna compare some of the testing I've done with it so far.
Any info would help. Thanks
Jess
Jesse Galang
Northwest R/C Club - VP
OverGeared Racing OG
Team Associated | Reedy | Orca
jzone is offline   Reply With Quote
Old 05-08-2005, 01:38 AM   #4474
RCknight's Avatar
Default Is there a website for those...
Pal aluminum outdrives? I wanted to check them out.
RCknight is offline   Reply With Quote
Old 05-08-2005, 01:49 AM   #4475
Originally posted by jzone
Hey guys,
Jess
Hi Jess.. I`ll be there too.
what class..?? 19T or Mod.?
if it`s 19T.. I have been working on a set up with a spool that is working pretty well..... Here`s what I have so far...give it a try out and give feed back after you have tried it out...maybe we can both try to get a dialed set up by then
-Dave
Front
Blue spring
40W oil
#2 piston
outer hole on sus arm
one hole in from outside on shock tower
4 deg hub
#2 shim under front triangle & circle block
black swaybar
IRS spool
1 deg camber
1 deg toe out
6 for droop on AE gauge
upper camber link rod on inner hole with 1 silver washer
outer hole on steering knuckle with 1 silver shim under ballstud
Rear
Silver spring
35W oil
#2 piston
one hole in fron outside on shock tower
innner hole on rear hub
2.5 deg toe in
#3 shim under square & X block
1 deg camber
4 for droop on AE gauge
upper camber link rod on inner hole with no shims and black ballstud
black swaybar
Tires RP30
Body Rayspeed Accord or Yokomo type E
this set up has very good turn in and is fairly easy to drive
try it out and tell me what you think... or if there is anthing that you think would make it better
Old 05-08-2005, 01:57 AM   #4476
Default Re: Is there a website for those...
Old 05-08-2005, 02:01 AM   #4477
RCknight's Avatar
Default I don't know, I may have to give in....
Dave. :LOL: They do look nice. May have to wait though. Hey does that Team Bomber cf shaft run true?
Old 05-08-2005, 02:03 AM   #4478
RCknight's Avatar
Default You say they are stronger than the IRS
ones Dave? What about the plastic ends, any problem with clearances in the outdrive at certain ride heights?
Old 05-08-2005, 02:05 AM   #4479
Default Re: I don't know, I may have to give in....
Sure does... the new Yokomo one is a slight bet lighter.. but a gram or 2 but the Bomber is much stronger... it`s a much better choice for mod where the Yokomo shaft would be better suited for 19T and up
-Dave
Old 05-08-2005, 02:08 AM   #4480
Default Re: You say they are stronger than the IRS
Nope none what so ever.. this diff was well thought out a lod of R&D went into it... trust me I was one of the test mules no clearance issues at all
-Dave
Old 05-08-2005, 02:23 AM   #4481
RCknight's Avatar
Default Yea...but you race on super huge flowing...
tracks and you never hit the walls Dave! What kind of test is that!
Old 05-08-2005, 02:33 AM   #4482
Default Re: Yea...but you race on super huge flowing...
Never hit walls..??? what about 2x4`s and most of the tracks that I`m at are med in size and are quite technical ... the Only super huge tracks that I know of are Yatabe Arena.... & Kawaba R/C Plaza..
but this is the local track for me
Old 05-08-2005, 03:40 AM   #4483
Entropy's Avatar
Default Re: OK... here it is
Originally posted by JDM_DOHC_SiR
Finally finished up the rebuild of my Orange TC4.. she`s all ready for Reedy now
-Dave
Hi Dave
Any reason for the front input cup to be alloy and the rear one to be stock?
Entropy is offline   Reply With Quote
Old 05-08-2005, 04:12 AM   #4484
Default Re: Re: OK... here it is
Originally posted by Entropy
Hi Dave
The front alloy cup is a one piece alloy shaft + drive cup..so it spins very true and saves weight at the same time...the rear one I kept stock because.. in a crash the rear one tends to take a beating.. and when you use the rear alloy cup it bends the rear alloy input cup...so the stock one works just fine
-Dave
Old 05-08-2005, 05:14 AM   #4485
Charles Godwin's Avatar
Here's a pic of my TC4
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
