Like Tree6Likes
Old 05-05-2005, 01:38 AM   #4411
idawina's Avatar
Default BEARINGS
what is everyones thoughts on the ball bearings that come with the team kit? should i upgrade them to go serious racing or will the stock ones rob speed? anyone know of good brand/place to get them from?
idawina is offline   Reply With Quote
Old 05-05-2005, 01:48 AM   #4412
RCknight's Avatar
Default PaulTC4...
I don't have any problems running my antenna through the stock graphite chassis. Are you having problems with glitches? I had some issues some time back, but it was speedo/receiver placement. I moved my speedo away from my receiver/servo and now I don't have any problems. If you have glitching, most likely it is something else. Try three layers of servo tape on your receiver or speedo. Try servo tape under your servo or move the power cap around. Maybe try some chassis protector on the sides of your chassis where the battery bars touch. Just a thought, but the antenna should not be a problem.
RCknight is offline   Reply With Quote
Old 05-05-2005, 02:05 AM   #4413
RCknight's Avatar
Default My apology to BMI...
the tub TC4 upper deck will not fit with a Square spur gear adaptor.
Old 05-05-2005, 02:08 AM   #4414
JDM_DOHC_SiR's Avatar
Trader Rating: 30 (100%+)
Default Re: My apology to BMI...
Why not..?? The Quare Spur gear adaptor.. puts the spur gear in the same location as the stock one...
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 05-05-2005, 02:17 AM   #4415
RCknight's Avatar
Default Well...I just figured maybe it was spur gear adaptor...
I didn't get a chance to check the stock one. Dave if you say it's the same then it's not the gear adaptor. Maybe it's the blue motor clamp. It may not the same as the black one.
Old 05-05-2005, 02:19 AM   #4416
Default Re: Well...I just figured maybe it was spur gear adaptor...
I didn't get a chance to check the stock one. Dave if you say it's the same then it's not the gear adaptor. Maybe it the blue motor clamp. It may not the same as the black one.
Can you take a pic' because it's kind of hard to help ...... since I have never seen the BMI top deck for the Tubs Chassis
-Dave
Old 05-05-2005, 02:28 AM   #4417
RCknight's Avatar
Default wife broke the D-camera....
but basically there's not enough room for the upper plate edge to fit in between the motor clamp and spur gear. If you look at it, there's not much room at all. The spacers/risers won't put it over the top of the motor clamp fins.
Old 05-05-2005, 02:32 AM   #4418
Default Re: wife broke the D-camera....
Do you know anyone that might loan a Digi camera to you for a few pic's
-Dave
Old 05-05-2005, 02:32 AM   #4419
RCknight's Avatar
Default too bad...
because it's nice, but it needs to work with the parts. I think not enough R&D.
Old 05-05-2005, 02:33 AM   #4420
RCknight's Avatar
Default I'll try to get one at
work tonight and take a pic.
Old 05-05-2005, 02:35 AM   #4421
Default Re: too bad...
because it's nice, but it needs work with the parts. I think not enough R&D.
...... ... Let me see if I can find a pic of the BMI top deck for the Tub chassis and maybe I can see where things might have gone wrong.... but untill that time have you tried to use the stock input shaft and spur gear adaptor and then tried to put the BMI top deck on??
-Dave
Old 05-05-2005, 02:43 AM   #4422
RCknight's Avatar
Default Won't leave the Square unit....it looks the same....
so I'm just hosed.
Old 05-05-2005, 05:09 AM   #4423
protc3's Avatar
if you run the top deck you will need to dremel a laittle bit of the first fin in order for it to fit.there is no possible way to snake it between the spur gear and the motor mount.i tried raising it but it stood to high and the screws wanted to bend.i spent alot of time on this and this was the only way i could make it functional.unfortunately the car is not made to run a top deck on the tub.if you lightly grind maybe 1/8 inch off the end of inside fin you should be good.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 05-05-2005, 05:43 AM   #4424
Default Re: BEARINGS
You can replace the bearings with ceramics, though I wouldn't suggest replacing the wheel hub bearings if you have a tendency to hit things. I replaced so many hub bearings its not funny, so I'd say stay with cheap for the hub bearings and replace the diff and input shaft bearings with ceramics.
Boca and Acer sell ceramics, I believe they are around $8 USD each.
MartynD is offline   Reply With Quote
Old 05-05-2005, 05:50 AM   #4425
Thumbs up OK... here it is
Finally finished up the rebuild of my Orange TC4.. she`s all ready for Reedy now
-Dave
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
