Like Tree26Likes
Old 05-02-2005, 03:15 AM   #4366
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Originally posted by MartynD
Sure it will.
10 Amps... will be fine for any charger so long as you charge at under 10 Amps +)
You can likely run 2 Pulsar 2's charging at 5 Amps on the N-power
thing is, a charger charging at 5 amp won't actually draw 5 amp from the PSU....you could run 2 6 amp chargers on a 10 amp PSU and it would be fine.
i've run 2 chargers charging at 2 amp, novak smart tray, a beefy 12v soldering iron off my 20amp PSU, then a mate hooked upto it charging at 5amp and did anything happen? nope, not a thing...just got a bit warmer than it usually does.
raving-monkey is offline   Reply With Quote
Old 05-02-2005, 05:40 AM   #4367
gene465's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to gene465
Default Re: Tire truer
Originally posted by RDR
Lookin for a decent tire truer anyone know what a good brand is to buy???
Doug
Doug,
I just picked up an Integy tire truer and while I have only cut 2 sets of foams with it, it works just fine and it was fairly inexpensive. Might want to look at it!
Finally got to run my TC4 and have to admit the car ran great! Especially after the first heat and I swapped out the rubber for the foams It was practically dialed a few more tweaks and I will be good to go. Ran my fastest lap to date and gained time on my lap avg. Love the one way just need a bit more practice getting used to it! Awsome car!
gene465 is offline   Reply With Quote
Old 05-02-2005, 06:32 AM   #4368
i found when i switched from rubber to foam my car was awesome....
the tc4 appears to be a foam car..might has always sucked on rubber
Old 05-02-2005, 01:09 PM   #4369
Mark G's Avatar
Send a message via AIM to Mark G
ppl toled me that the tc4 wanst ass good on foam. but relly good on rubber
Mark G is offline   Reply With Quote
Old 05-02-2005, 02:15 PM   #4370
gene465's Avatar
I guess it really just boils down to track and set-up on whether it's foams or rubber. I still use rubber on my Barracuda and T-Spec so it's probably just the set-up!
Old 05-02-2005, 03:37 PM   #4371
RDR
RDR's Avatar
Default Foam Tires
So what do you guys run for foam tires on pavement??
Front/Brand/Shore/Color?
Rear/Brand/Shore/Color?
I have some Take off 27's on the way.
Doug
Is that the automatic tire truer from integy Gene465???
RDR is offline   Reply With Quote
Old 05-02-2005, 03:39 PM   #4372
Trader Rating: 68 (100%+)
Anyone have a carpet setup for low bite ozite?
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 05-02-2005, 04:29 PM   #4373
gene465's Avatar
Default Re: Foam Tires
Is that the automatic tire truer from integy Gene465??? [/B][/QUOTE]
No not the auto one try this link: http://integy.automated-shops.com/cg...56105282091.e3 It's Manual but works well. You can find them cheaper as well.
As far as foams I have been using the Jato Nitro shoes 26MM 40 Shore front 30MM 35 shore rear or Think it's trinity or TRC F3 Shore front R3 Rear. Hooks up pretty good on our large asphalt track. As it gets hotter will probably go up in shore rating for better wear. Gene
Old 05-02-2005, 05:47 PM   #4374
Trader Rating: 14 (100%+)
wicked
where did you buy your pdub bumper from?
chrisw is offline   Reply With Quote
Old 05-02-2005, 05:49 PM   #4375
RDR
RDR's Avatar
Ya, I wanted to know the same thing about the PDub bumper, Gene465 I've never seen that truer before looks pretty sweet, and is a resonable price!
Old 05-02-2005, 05:52 PM   #4376
RCknight's Avatar
Default I bought a set of graphite arms....
and they must have been the old ones. I wasted $25 dollars and they are sloppy. Sure wish there was a way to tell the difference between the improved ones and the old ones.
Any news on when AE going to release the FT version?
RCknight is offline   Reply With Quote
Old 05-02-2005, 05:55 PM   #4377
I thought there was no problems with the graphite arms, the problem was with the original composite ones, which were changed to a mold which looked identical to the graphite/carbon arms.
MartynD is offline   Reply With Quote
Old 05-02-2005, 06:20 PM   #4378
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
To tell the difference in the arms, I've noticed that the holes where the lower portion of the shocks go in are differerent.
I'm just about done putting all the Carbon parts on my car. I noticed that the front arms have slop but the rear are just about perfect. The reason? I think it's because I have the (X) Aluminum mount on.
Paul_TC4 is offline   Reply With Quote
Old 05-03-2005, 01:10 PM   #4379
Wicked's Avatar
Hey guys,
Does anyone know if I can use the deans pro 2's with the gp 3300s?
Baja 5B Flux, Baja 5T, HPI Savage Flux XL, Brushless Erevo, Summit, X Maxx, Arrma Big Rock, Tamiya Bruiser, & Hi lux, Slash, Skully,
Blade 200qx, Inductrix 200, Nano qx2 fpv, Cx, Proto X SLT
Wicked is offline   Reply With Quote
Old 05-03-2005, 03:44 PM   #4380
tc4kid191's Avatar
Send a message via AIM to tc4kid191
You could but they are not designed for the 3300
here is the site:http://www.wsdeans.com/products/bars/index.html
tc4kid191 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
