Like Tree26Likes
Old 10-06-2004, 12:59 AM   #406
donoman's Avatar
Send a message via Yahoo to donoman
I saw a local driver with one today, he is blazing fast with it and said it was much better than his TC3. But this guy could probably still TQ and win races if he was driving a buggy on the track.
donoman is offline   Reply With Quote
Old 10-06-2004, 04:24 AM   #407
ml
ml's Avatar
Send a message via AIM to ml Send a message via Yahoo to ml Send a message via Skype™ to ml
Default Re: Mike why do you say it's...
Originally posted by Nightbreed
easier to tweak? It's nearly the same chassis.
By easier to tweak, I mean that after setting the tweak with a tweak board, the car drives evenly on the track. With the TC3, there were times I would need to adjust the tweak slightly off level on the tweak board to get the car to drive evenly on the track. Of course, that was likely due to me not having the lowered roll center adjustments exactly even, but that is not a problem with the TC4.
-Mike
ml is offline   Reply With Quote
Old 10-06-2004, 06:34 AM   #408
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
ml- when you guys are setting the tweak on this car, which method have you been using. You said "setting tweak with a tweak board" does that mean using something like the MIP station, or setting it on a flat board and using the xacto. You would think that if you got it right one way then it would check using the other method as well, but I know with the TC3 it rarely happened. So which way has been checking out good for you? Thanks for the time on here, I know Mike B. and Barry get really busy as I'm sure you do as well, so it helps to have another source for some reliable feedback.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 10-06-2004, 10:21 AM   #409
What's up Mr. Lufaso?? How have you been? Good Luck at the classic wish I was going....my crew backed out on me... I'll see you soon, at least by Cleveland. I've had a few weeks with the car on carpet if you want to bounce ideas around email me. edesros168@aol.com
Eric Desrosiers (Old) is offline   Reply With Quote
Old 10-06-2004, 10:37 AM   #410
ml
ml's Avatar
Lightbulb
Brandon,
I usually just lurk on here to avoid starting any flamewars. Mike B. and Barry B. are the experts and the guys to ask the best way to setup the car.
I don't claim to know the best way to set the tweak on the car. I'll describe how I set the tweak using a Niftech tweak board. Feel free (anyone) to send me a suggestion on a better method. First make sure the tires sizes are close to even. Check to make sure the shock springs are the same length (these do vary!). Make sure the shock to beginning of ball cup is the same length. Set the ride height to 5 mm at each corner. Remove the wheels and set the droop (equal right to left) to whatever is appropriate for the roll center setup, tire size, etc.. Reinstall the wheels and have all equipment installed like the car will be raced. Ensure tweak board is level in all directions. Place the rear tires on the solid portion of the tweak board, with the front chassis flat on the part of the tweak board that rotates. Adjust the shock setting to obtain an even tweak for the rear. Now place the front tires on the solid portion of the tweak board, and rear part of the chassis on the part that rotates, then adjust the tweak for the front. After the front and rear are adjusted separately, place all four wheels on the tweakboard. The tweak should be very near level. Perform any slight adjustment if it is necessary, but don't make all the adjustment in a single shock, spread it out evenly over the 4 shocks. Be sure to press evenly on the center of the suspension after each step and adjustment to make sure there is no bias and to settle the suspension. I record the distance between the collar and shock hex.
In my opinion, it doesn't matter at all what the tweak board shows, it's how it handles on the track. After following the above steps drive the car on the track in practice. If the car doesn't handle evenly on the track, then adjust all four shock collars until it steers evenly left and right. After getting the car to handle evenly, put the car back on the tweak station with all 4 wheels. I measure/estimate how much the bubble is off center and write it down. I do the same thing for the front and rear, with the chassis resting on the tweak plate, recording the values for the tweak offset on the tweak board. I remeasure the shock collar to hex distances. Now I have a setting that will allow me to purposely adjust the car so that although it is not tweaked according to the tweak board, it handles evenly on the track.
I have not tried adjusting the tweak by the X-acto blade method, but it seems to me it would be very critical to have identical droop settings.
/lunch break over
P.S. Eric, too bad you can't make it to the Classic. Missed you at the Portland Nats too. And it's Dr. Lufaso - Just kidding, I'm giving you a hard time. See you at Cleveland.
Old 10-06-2004, 12:19 PM   #411
evok's Avatar
I just saw the Tc4 for the first time on the track... damn it looked good!
It looked a lot more stabil than the "old" tc3, and easy to drive. It was even faster than Teemu.L with his MI2 driving on his home track...
Can't wait to get my own
evok is offline   Reply With Quote
Old 10-06-2004, 12:56 PM   #412
Thanks for the reply. I always thought when using the tweak board, if you had the front end on the rotating part, you adjusted the front collars, and when the rear tires were on rotating part, you adjusted the rear collars. Not to say that it wouldn't work though, obviously your car is always very fast. I thought you only adjusted the opposite collar when using the blade method. I tried the blade method a couple times, but even with identical droop it would NEVER work when the ride height was the same everywhere, and to get the rear tires to lift the same, the rear droop was all cocked up, even with an even set of rebounding fresh shocks.
Old 10-06-2004, 04:30 PM   #413
JimmyMac's Avatar
Tweek? What's that? haha... I never adjust it.. hehe
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 10-06-2004, 04:39 PM   #414
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
the only time i adjust the tweak is when the car handels funky
Javen13 is offline   Reply With Quote
Old 10-06-2004, 05:56 PM   #415
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
I've always set front tweak with the rear shocks and vice versa...
Speedo is offline   Reply With Quote
Old 10-06-2004, 06:17 PM   #416
ml
ml's Avatar
Thanks for the reply. I always thought when using the tweak board, if you had the front end on the rotating part, you adjusted the front collars, and when the rear tires were on rotating part, you adjusted the rear collars....
When I'm adjusting the front tweak, the rear part of the chassis is resting on the rotating part. Only the front two tires are touching anything (the solid part of the tweak board), so I adjust the two front collars. I know what you are talking about, that way works if the chassis is resting on the solid part and the tires on the rotating part (the opposite way of what I described previously). Try it both ways, it should give the same result. I hope this explanation hasn't made anyone more .
Old 10-06-2004, 06:21 PM   #417
imprsme's Avatar
Trader Rating: 72 (99%+)
Mike- How is the turn out at MIMI'S? I am trying to talk some of these guys into coming up. Also are they still hosting the Trinity race there? If so when is that?
BTW- Is Vanilla Ice's "HOLE" still there?
imprsme is offline   Reply With Quote
Old 10-06-2004, 06:28 PM   #418
Default I hope Losi's new shocks will work on...
the TC4. I just don't care for the AE shock design. It takes too much time getting them to rebound the same. In the last 17 years I have been in RC, AE still has not changed the shock design much.
Nightbreed is offline   Reply With Quote
Old 10-06-2004, 09:24 PM   #419
JimmyMac's Avatar
Just get some Yokomo Shock caps/bladders. They are direct fit on the AE shocks.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 10-06-2004, 09:38 PM   #420
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Or Tamiya ones
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
