Like Tree36Likes
Old 04-21-2005, 03:50 AM   #4156
johnbull's Avatar
Originally posted by JDM_DOHC_SiR
You have me Joe..... I"m at a total loss
-Dave
Ok here goes.
The chassis, wishbones and hubs and drive shafts are TC3.
The diffs are Schumacher Mi2.
The diff housings are Yokomo YR4 and the motor mount and layshaft mount are for Yokomo YR4 models, made by Fastrax - I think that one is the Type J motor mount, but I have turned it back to front to put the motor ahead of the spur gear.
The 2 layshaft pulleys are modified Losi XXXS items with an RW spur gear sandwiched in between.
The belts were an absolute headache. Rear is a Schumacher CAT and SST slim belt. Front is one of the many Yokomo YR4 variants. There are 3 or 4 lengths to choose from. I think the one I used is also J Type.
I'm now plotting out the steering and going through my boxes of "rubbish" to find suitable bits. It's quite fun.
johnbull is offline   Reply With Quote
Old 04-21-2005, 06:15 AM   #4157
Trader Rating: 22 (100%+)
Post
If you want to stiffen the chassis even more use a longer screw where the chassis brace screws into the chassis (I used 1" inch) this makes a big difference in rigidity.
Also try the 3 racing shock towers more rigid plus an extra mounting hole for tuning.
Saying this speaking to a sponsered Associated racer he was cutting the graphite brace (one finger say) to give the car more twist in the chassis left to right. His explination was the 415 & pro4 twist more than the TC4.
My opinnion make it rigid and let the suspension do the work twist or flex is to hard to control cosistently.
bjspinner is offline   Reply With Quote
Old 04-21-2005, 12:28 PM   #4158
i_got_m8_4_$85's Avatar
Send a message via AIM to i_got_m8_4_$85
Post
does anybody have pictuers of that forced air thing i do not understand where it mounts and how it works thanks.
i_got_m8_4_$85 is offline   Reply With Quote
Old 04-21-2005, 01:03 PM   #4159
Trader Rating: 116 (100%+)
I have heard rumors that Team Associated has been busy redesigning many of the TC4 parts. Anyone out there know if this is true and which parts are being looked at?
History points to this as the TC3 was released and about a year later, an upgrade factory team kit was released with several key changes (plastic diffs, droop screws, etc). Turned a great car into a world beater.
ewippler is offline   Reply With Quote
Old 04-21-2005, 01:40 PM   #4160
RCknight's Avatar
Default I just emailed them...
and I hope to get a response. I want to know if they are going to make a stiffer chassis for carpet, otherwise I'm jumping ship.
RCknight is offline   Reply With Quote
Old 04-21-2005, 01:48 PM   #4161
raving-monkey's Avatar
Send a message via MSN to raving-monkey
look under where your reciever and ESC are mounted..there are 2 triangle hole things and 2 screw holes in between the triangle holes.
the duct goes there....you mount your electrics on top of it.
the fan is screwed to this 'grill' and the grill is clamped uner the duct when you screw it down.
raving-monkey is offline   Reply With Quote
Old 04-21-2005, 02:09 PM   #4162
RCknight's Avatar
Default How much does inconsistent shock rebound
affect the handling? Would it be a real noticeable difference? I can never get AE shocks to all rebound the exact same.
Old 04-21-2005, 02:12 PM   #4163
Slight difference, maybe not, but any difference will make the car handle poorly. It's worth the time to get them equal.
JWATT is offline   Reply With Quote
Old 04-21-2005, 02:36 PM   #4164
To save headaches... just try and have the rebound as close as you can get in pairs. Front pair as close as you can get to each other and rear the same.
MartynD is offline   Reply With Quote
Old 04-21-2005, 02:50 PM   #4165
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
http://ebiz.netopia.com/competitionx...sis-Bottom.jpg
http://ebiz.netopia.com/competitionx...Fan-Duct-1.jpg
http://ebiz.netopia.com/competitionx...Fan-Duct-2.jpg
try these links for pics of the underside and fan to go along with the above description.
Old 04-21-2005, 02:58 PM   #4166
RCknight's Avatar
Default Anyone know the...
parts numbers for the bladder style Yokes shock caps? And, anyt other parts that I need to convert them?
I would like to go to a different shock brand. John Bull you say you use those Corally RXD shocks on your TC4? Why do you like them better than say the Yokes? Since your a Yoke fan.
I want to go to the new Losi JRX-S, but I'm not sure they will fit yet.
Old 04-21-2005, 03:14 PM   #4167
damn you..thats the pic i was looking for (the 2nd 2 on competition x)
RCKnight....why not just get trusty tamiya shocks? i loved mine....so easy to get them the same (rebound) and they were just soooo smooth..they are definatley finding their way to my car once i have some spare cash
Old 04-21-2005, 03:30 PM   #4168
The Associated shocks work great. Just buy the yok bladder caps and you won't have another problem. Speedtechrc sells them. they're a lot cheaper than Tamiya shocks
DOTMAN is offline   Reply With Quote
Old 04-21-2005, 03:57 PM   #4169
http://ebiz.netopia.com/competition...ssis-Bottom.jpg
http://ebiz.netopia.com/competition.../Fan-Duct-1.jpg
http://ebiz.netopia.com/competition.../Fan-Duct-2.jpg
thanks guys
Old 04-21-2005, 04:12 PM   #4170
RCknight's Avatar
Default HPI's shock are super smooth, but...
I can't have purple on a blue car.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
