Old 04-12-2005, 11:52 AM   #3916
not trying to change the subject but, i can't get my tc4 to steer straight. i tried the steering trim on the radio, no luck, i adjusted the camber to no luck. what other suggestions do you have? i am new and still learning a thing or two.
chris
chrisw is offline   Reply With Quote
Old 04-12-2005, 12:07 PM   #3917
Tbevofreak: Do you have a diode on the motor? Might try replacing it.
chrisw : Be sure all wheel bearings are free.
Hope this helps.
JWATT is offline   Reply With Quote
Old 04-12-2005, 01:33 PM   #3918
SMcpot's Avatar
Trader Rating: 22 (100%+)
Smile
I'll give that a shot, Paul........thanks.
I love the car, but the cost to make it lighter, stiffer, and less sloppy is quickly adding up
SMcpot is offline   Reply With Quote
Old 04-12-2005, 08:01 PM   #3919
RDR
RDR's Avatar
Default Overheatin!
I was overheatin my Stock motor @ my last race 250F, droped a couple teeth on the pinion, and it was a good temp after that, right aroung 150F. (26 tooth to a 23 tooth pinion, 72 tooth spur)(Trinity Monster Stock Pro)
Doug
RDR is offline   Reply With Quote
Old 04-12-2005, 08:03 PM   #3920
RDR
RDR's Avatar
Oh ya, and a Novak GT7 ESC.
Doug
Old 04-12-2005, 08:06 PM   #3921
gene465's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to gene465
How was the speed? I run a 72/27 with my 19T and it gets warm but not excessively. Any binding anywhere? Gear mesh set right? That seems a bit small! What ESC you running? Diode?
gene465 is offline   Reply With Quote
Old 04-12-2005, 08:11 PM   #3922
chris
My TC4 also has this problem, I hear a expert driver said I may be over tight the battery plate to hold down the battery then tweak the chassis can't turn back. Furthermore, make sure your battery free movement in the chassis after hold down the battery plate. I hope it help, if you try this or other method can solve the problem pls send me a message to let me know. Many Thanks
Loman
Loman is offline   Reply With Quote
Old 04-12-2005, 08:16 PM   #3923
RDR
RDR's Avatar
Sorry that was a 24 tooth pinion not a 23 speed was still decent.
Doug
Old 04-13-2005, 06:27 PM   #3924
tony montana's Avatar
Trader Rating: 65 (100%+)
Hey guys I still havent ran my tc4 yet, but I have a couple of quick questions. First, has anyone had any problems getting the shims on the diff outdrives? Any two any one have a decent asphalt setup for a medium bite track flowing track for rubber tires. Also what seems to be the hot rubber tire lately and insert.
K.C. Guy
tony montana is offline   Reply With Quote
Old 04-13-2005, 06:59 PM   #3925
tc4kid191's Avatar
Send a message via AIM to tc4kid191
i dont run off road but if you have plastic outdrives the shims will be hard to get on
tc4kid191 is offline   Reply With Quote
Old 04-13-2005, 07:19 PM   #3926
SCIDA's Avatar
Look at the Team Associated website. Go with either J.R. Mitch's or Juho's asphalt set up. Both would be good to start with . Try them both to see which works better for you.
SCIDA is offline   Reply With Quote
Old 04-13-2005, 07:39 PM   #3927
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
The shim on the diff outdrive are a little tough to get on. Here's a tip: Place the shim on the bearing and then push the outdrive in the bearing. The shim should be pushed all the way in due to the bearing pushing it.
I wouldn't even install the plasic outdrives. I run strictly on carpet and even with a stock motor, the left dogbone kept falling out.
Paul_TC4 is offline   Reply With Quote
Old 04-13-2005, 08:03 PM   #3928
Plastic outdrives are fine with stock and 19T in the rear, the front will be problematic. I recommend any of the aluminum or metal outdrives for the front.
MartynD is offline   Reply With Quote
Old 04-13-2005, 08:08 PM   #3929
so what kind of outdrives should I get irs or another brand. Thanks for the help
K.C. Guy
Old 04-13-2005, 09:18 PM   #3930
Jack Smash's Avatar
Trader Rating: 28 (100%+)
I've decided to sell my TC4. I have been running AE stuff since '86 and it's time to try something new. Check it out here
Nearly Factory Team Tc4
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
