Like Tree1Likes
Old 04-11-2005, 02:14 AM   #3901
JDM_DOHC_SiR's Avatar
Trader Rating: 30 (100%+)
Default Re: Anyone have a Team Bomber....
Originally posted by RCknight
CF TC4 shaft yet?
Yep.. got it 2 day ago
pertty light.. about the same as the Square shaft... but not as light as the new Yokomo TC4 shaft
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 04-11-2005, 02:25 AM   #3902
Fatboy Joe's Avatar
Originally posted by kewdawg
You want your drivetrain to be bind-free. Shim so everythings spins smoothly. the drivetrain needs to have a slight amount of play to achieve this. Shimming your gears tight will slow your car greatly and overwork your motor.
hi kewdawg, I have a question regarding the shimming and amount of play in the gears, won't the gears be prone to stripping when they have "some play" in between them? I run a spool just have the stock shims on both sides and sometimes strip my gears when I fly-off and land on all fours while at full throttle...or the effect would be if there is a bit of "play", then there is more room for the gears to slip intead of strip? Let me know what you think
Fatboy Joe is offline   Reply With Quote
Old 04-11-2005, 05:39 PM   #3903
kenny's Avatar
Hello guys
I just ordered a TC4 and have a question. How do I determine the FDR? Is it the same as the TC3 [(spur/pinion)*2.5]?
Or is the gear ratio different for the TC4? I heard they changed it from 2.5:1 to 3.0:1. Is this true?
Thanks in advance,
Kenny
kenny is offline   Reply With Quote
Old 04-11-2005, 05:49 PM   #3904
tc4kid191's Avatar
Send a message via AIM to tc4kid191
i beleave they changed it you could check the site @ rc10.com
tc4kid191 is offline   Reply With Quote
Old 04-11-2005, 06:02 PM   #3905
fathead's Avatar
Originally posted by kenny
Hello guys
Thanks in advance,
Kenny
I has not changed, the diffs are interchangable between the TC4 & TC3
Slavich Design
fathead is offline   Reply With Quote
Old 04-11-2005, 06:06 PM   #3906
kenny's Avatar
OK guys thanks. I used to have a TC3 and had found the ideal pinion/spur combo for an MVP where I run. I sold the TC3 a couple years ago but still have my notes with different FDRs and how I liked it. I just ordered a TC4 + MVP motor so I will just use the same gearing and be good to go
Old 04-11-2005, 06:58 PM   #3907
Trader Rating: 67 (100%+)
Originally posted by JDM_DOHC_SiR
They are making a Spool Right now ..and it will use the same thick teflon blades too
-Dave
Where can i order those too sweet
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 04-11-2005, 07:47 PM   #3908
SMcpot's Avatar
Trader Rating: 22 (100%+)
Smile
Sorry if the reply to this has been posted before, but what are you guys using to shim up the arms on the TC4? Even the graphite arms seem way sloppier than those on my FT TC3.
SMcpot is offline   Reply With Quote
Old 04-11-2005, 08:18 PM   #3909
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
Yeah, it's pretty sad that even the graphite kit doesn't fix that play. I use and extra motor washer to get rid of the play. Make sure the arm doesn't bind when adding even more washers. If there is play inside the hinge pin pivot ball, simply replace it or what I heard to do is use a piece of the plastic bag that comes with any Team Associated parts and put it inside.
Paul.
Paul_TC4 is offline   Reply With Quote
Old 04-12-2005, 10:07 AM   #3910
Default Overheating problem!
Hi Guys,
I'm still having problems with my motors overheating in my TC4, I've tried everything you can think of, I checked every single bearing and tried different gearing and motors...but no result
Can someone help me please I really don't know what to do
Have you expereienced some overheating probs with this car?
Any help would be very welcome!
Thanks!
Tbevofreak is offline   Reply With Quote
Old 04-12-2005, 10:11 AM   #3911
Define overheating. To the touch or do you know the actual temp?
Without a motor in it, will it free spin?
What pinion and spur do you have on it?
Are you racing it or driveway play?
What type of connectors (if any) do you use between the motor and speed control?
How long are you running it to get to the overheat problem?
What motor are you running?
Do all motors overheat?
JWATT is offline   Reply With Quote
Old 04-12-2005, 11:21 AM   #3912
JWATT-Thank you for trying to help, the motors can hardly be touched more than 2 secs and I'm using the duct/fan kit, this is after 3/4mins and happends with all my motors (V2's, Ti, Corally) I use different turns: 12t, 8t, 7t and I can assure you my gearing is correct I checked with the guys at the track, I use to have a TB evo 3 and I used the same gearing and had NO heat probs so I know its something to do with the car
My drivetrain is perfectly free it spins for 4-5sec, I don't use any connectors everything is soldered
I hope I gave you all the info you wanted, this is really annoying and I'm starting to go crazy!
Again, thank you I hope you'll try and help more!
Old 04-12-2005, 11:24 AM   #3913
utieh's Avatar
Did you try a different ESC setting or just another ESC??
utieh is offline   Reply With Quote
Old 04-12-2005, 11:25 AM   #3914
AM03GT's Avatar
the guys suggesting the gearing, are they running a TC4 as well? ...
here at socal i've got friends running 8x1's with no problems at all, oftentimes without fans...
edit: oops, didnt see that you mentioned a free spinning drivetrain...
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 04-12-2005, 11:47 AM   #3915
I tried 3 ESC, the one I was running now is a novak GTX and it gets slightly warm after a couple of mins, their must be something that's overworking the motor but I just can't find it
With the 8T I use 8.2/8.6/9.2 FDR different timing with no resutls
With the other motors I tried plenty of other gearings....always overheating...trust me its not a gearing prob
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
