Like Tree59Likes
Old 03-30-2005, 11:42 PM   #3826
I think raise is right. The ball studs are attached to the chassis and don't move when you add spacers to the arm mounts. If you lower the arms mounts, the distance between the ballstud and the arm mounts increases. Same thing if you raise the ball studs
DOTMAN is offline   Reply With Quote
Old 03-30-2005, 11:49 PM   #3827
fathead's Avatar
Originally posted by fathead
In that same section the first sentence says "You can raise(I think this should say lower) the front or rear roll centre by lowering the arm mounts, or raising the inner ballstud" now I see your confusion
I hope that clears it up a bit.
Thankyou DOTMAN I didn't pick that mistake up I have edited my post above as well
Slavich Design
fathead is offline   Reply With Quote
Old 03-30-2005, 11:52 PM   #3828
D_Ames's Avatar
Send a message via AIM to D_Ames
This is the text from page 15 of the TC4 manual
"Also, you can raise or lower the mounts for maximum roll-center adjustability. Simply raise the mounts in equal increments under both mounts and you can raise the roll center"
also from the same page in the section 'Ballstud Height & camber Location'
"A lower roll center will put more weight on the tires during cornering, and increases traction to that end of the car"
Exactly!!!! that was what was confusing me.
The other thing is...if lowering the roll center (removing shims) gives you more traction then why are most carpet setups using less shims than asphalt setups? I thought you wanted to have less traction on carpet.
sorry for my confusion
D_Ames is offline   Reply With Quote
Old 03-30-2005, 11:55 PM   #3829
D_Ames's Avatar
OK, now I'm really confused???? I'm thinking lowering the arm mounts RAISES the roll center!!
Where the hell is Tony when I need him
Old 03-31-2005, 12:01 AM   #3830
fathead's Avatar
I was quite confused by this as well untill I tried it.
When i thought about it, I think it has to do with the really small diameter foam tyres that we use on carpet as apposed to the much bigger diameter rubber tyres used outdoors.
With the small dia. foams on when you look at the way the bottom arms are angled they are angled down (on my car) much less than they would be with rubber tyres on when the same ride height is used, this is effectively raising the roll centre for the foam tyre setup.
So we take shims out to lower the roll centre down to get it back close to where it was on the rubber setup.
Slavich Design
Old 03-31-2005, 12:09 AM   #3831
fathead's Avatar
DOTMAN was talking about my post before i edited it, It is right now.
Lowering the arm mounts or raising the inner ballstuds will lower the roll centre
Slavich Design
Old 03-31-2005, 12:31 AM   #3832
D_Ames's Avatar
I see....thanks
Old 03-31-2005, 06:06 AM   #3833
Default Johnbull
Yes we only use the V2 endbell for practice. It's Corally Pro Series Black modifieds all the way on race days, and yes they are dynamite.
Thank you for taking time to answer!
I'm glad to know you like your corally motors, they don't seem to be so popular in the US and I was wondering why as they are so great and often used by drivers here in Europe and France
One last thing and I'll stop bothering you, how many runs do you get when using the V2 endbell with the 8T compared to the normal one?
Cheers!
Will
Tbevofreak is offline   Reply With Quote
Old 03-31-2005, 06:27 AM   #3834
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Default Re: Johnbull
Cheers!
Will
i'll also to be interested to know the answer to that.
i will be running an 8t at the nationals this year and it will be interesting to see how many runs i would get between skims/rebrushing.
raving-monkey is offline   Reply With Quote
Old 04-02-2005, 09:24 AM   #3835
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
Can someone post pictures and explain all of the mods they are doing to their TC4. I am talking about custom mods like milling on the chassis. And also can JIM_DOHC_SIR please post the optimal weight saving milling options and how much weight they save again please.
tc3stocker is offline   Reply With Quote
Old 04-02-2005, 09:32 AM   #3836
Wicked's Avatar
Hey guys,
Can someone tell me if they're any MAJOR differences between the tc4 rtr and tc4 team?
just from looking I can tell they're the shocks, and cvds. BUt is the parts made from different material? Meaning the xxx-s rtr was plastic and the G+ was ghaphite. Is that the same sorta thing here?
Main reason I want to know is that I can't find a tc4 team in Canada anywere but I did find a rtr out west. I have a xxx-s and mi2 now and I usally mod the crap out of them so allot of the stock parts get thrown in a baggie anyways. So unless there is something I am not seeing I may end up buying a rtr.
Jason
Baja 5B Flux, Baja 5T, HPI Savage Flux XL, Brushless Erevo, Summit, X Maxx, Arrma Big Rock, Tamiya Bruiser, & Hi lux, Slash, Skully,
Blade 200qx, Inductrix 200, Nano qx2 fpv, Cx, Proto X SLT
Wicked is offline   Reply With Quote
Old 04-02-2005, 11:51 AM   #3837
Jack Smash's Avatar
Trader Rating: 29 (100%+)
I did the battery strap mod and posted pics
Team Associated TC4
Very last post on the bottom of that page and a few on the next. Click on the attachment.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 04-02-2005, 11:59 AM   #3838
pitshop's Avatar
Trader Rating: 56 (98%+)
The RTR's are NOT made in the USA
so there will be other subtle differences in material quality. It is an awesome RTR, but if you are looking to race its best to go straight to the Team kit... anyway, you really want those threaded shocks
PIT SHOP 153-D Araneta Avenue
Q.C. opposite PNB between SM Sta Mesa and So En
tel (632)716-6553 fax (632)714-0550
YOU CAN CALL 09174632746 OR 09175331943
please like us on FB - PITSHOP RC
pitshop is offline   Reply With Quote
Old 04-02-2005, 01:35 PM   #3839
Wicked's Avatar
Hey thanks pitshop.
I would go with the team but I can't find any up here. I called the hobby shops I deal with and none of them had one except for the rtr. I am going to be putting a bmi on it with in the first few weeks and I will probably be getting a few other also. But yea it would be nice to get those shocks.
Old 04-04-2005, 06:21 PM   #3840
MikeDeadly's Avatar
Location: San Marcos/San Antonio, Tx but chillin in Orlando, FL for now.
Send a message via AIM to MikeDeadly
Does anyone know the weight difference between the blue aluminum shaft and the old carbon shafts that came with the TC3? Im considering switching my TC4 to the carbon shaft from my old TC3 and Id like to know just how much weight will be saved.....
And does any one else run the carbon shaft??
--Mike
MikeDeadly is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
