Old 03-30-2005, 12:52 PM   #3811
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Originally posted by fjm9898
does anyone know if the tc4 stearing rack fits on the tc3?
there is a link somewhere with a tutorial on how to fit the ntc3 rack to the tc3...and they are basically the same so just fit the ntc3 one.
raving-monkey is offline   Reply With Quote
Old 03-30-2005, 01:16 PM   #3812
Jack Smash's Avatar
Trader Rating: 28 (100%+)
Default Re: Anti Roll Bars
Originally posted by RDR
What does everyone think run with one or no, racing on carpet, with foam tires purple springs in front, copper in the rear, 50wt oil all around.
Doug
Are you having a problem with traction rolling with that setup? It looks a little light on the front oil. especially without a front bar.
Basically, an anti-roll bar reduces traction at whatever end of the car you put it on without making the car scrubb speed.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 03-30-2005, 01:23 PM   #3813
Fredda's Avatar
Originally posted by johnbull
I would have thought that with Scandinavian drivers taking 3 Euro championships in a row with TC3 and TC4, you just might have convinced yourself.
Perhaps when X Ray win a Euro you'll convert to a TC4.
Yeah i think the car is good on asphalt with rubber tires but i have only driven it on carpet with sorex 28 and it didnīt suit my driving style ! and there is still snow around here but the spring is here now so i looking forward to the outdoor season with the xray !!!!!
Fredda is offline   Reply With Quote
Old 03-30-2005, 02:52 PM   #3814
johnbull's Avatar
Default Re: Johnbull
Originally posted by Tbevofreak
Hy!
I saw on your TC4 pics that you were running a 8T corally Gold with a V2 endbell
I have many corally black motors an really love them, they're the best I have but why do you run the V2 enbell?
Is it when you practice or do you like the extra effiency (runtime) the V2 enbell provides?
I hope you don't mind me asking this!
Thanks!
Right first time.
Yes we only use the V2 endbell for practice. It's Corally Pro Series Black modifieds all the way on race days, and yes they are dynamite.
johnbull is offline   Reply With Quote
Old 03-30-2005, 05:23 PM   #3815
fjm9898's Avatar
what diff should i use in the front, regular, one way, or solid?
i am running on carpet, stock, rubber tires and i have a sway bar in the front
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 03-30-2005, 07:24 PM   #3816
Ortiz's Avatar
link to Rubber Tire on Ozite setup...
http://www.teamassociated.com/racerh...ups_onroad.htm
Ortiz is offline   Reply With Quote
Old 03-30-2005, 07:30 PM   #3817
Jack Smash's Avatar
fjm, one-way
This one should be a good starting point.
http://www.teamassociated.com/racerh...ement_2004.pdf
Old 03-30-2005, 07:47 PM   #3818
fjm9898's Avatar
yes but they use a oneway with a mod, i am runnicg stock
Old 03-30-2005, 07:55 PM   #3819
Ortiz's Avatar
it should just be a starting point. If it feels to crazy throw in a diff and see how if feels. But that setup should work for stock as well.
Old 03-30-2005, 08:25 PM   #3820
Jack Smash's Avatar
Youll probably want to set the throttle trim so it creeps a little when at neutral, this will reduce some of the drag brake and keep it from trying to lock up the rear.
I do this no matter what front drive i am runnig cuz i hate drag brake.
Old 03-30-2005, 09:17 PM   #3821
D_Ames's Avatar
Send a message via AIM to D_Ames
OK....If I add more shims to the arm mounts is that raising or lowering the roll center?
Does lowering the roll center give you more or less traction? The AE manual is contradictive.
D_Ames is offline   Reply With Quote
Old 03-30-2005, 09:43 PM   #3822
fathead's Avatar
It raises the roll centre when you raise the inside of the lower arms, which decreases the roll moment which gives you less grip.
I must admit I had to read the TC4 manual a few times to make sense of it, it is quite confusing but is correct.
Slavich Design
fathead is offline   Reply With Quote
Old 03-30-2005, 09:46 PM   #3823
fathead's Avatar
deleted - stupid forums
Slavich Design
Old 03-30-2005, 10:48 PM   #3824
D_Ames's Avatar
Not to offend but somehow that seems backwards.
Old 03-30-2005, 11:29 PM   #3825
fathead's Avatar
This is the text from page 15 of the TC4 manual
"Also, you can raise or lower the mounts for maximum roll-center adjustability. Simply raise the mounts in equal increments under both mounts and you can raise the roll center"
also from the same page in the section 'Ballstud Height & camber Location'
"A lower roll center will put more weight on the tires during cornering, and increases traction to that end of the car"
In that same section the first sentence says "You can raise(I think this should say lower) the front or rear roll centre by lowering the arm mounts, or raising the inner ballstud" now I see your confusion
I hope that clears it up a bit.
Slavich Design
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
