Old 03-18-2005, 11:19 AM   #3691
raving-monkey's Avatar
Send a message via MSN to raving-monkey
oh right...no not a problem with that, first ive heard of it.
raving-monkey is offline   Reply With Quote
Old 03-18-2005, 11:55 AM   #3692
I haven't had any problem with that, but put a dab of thread locker on it and you should be fine.
Corner Weight is offline   Reply With Quote
Old 03-19-2005, 07:22 AM   #3693
Can anyone here please email a empty set-upsheet to albinnorrman@hotmail.com
The ones on AEs site doesnt work for me
Morrissey is offline   Reply With Quote
Old 03-19-2005, 08:36 AM   #3694
CRASH's Avatar
Trader Rating: 26 (100%+)
Be sure you have the newst version of Adobe Acrobat.
Copy on the way,
Later,
CRASH is offline   Reply With Quote
Old 03-21-2005, 01:43 AM   #3695
johnbull's Avatar
Three weeks ago I wrote here saying what a great weekend we had on our TC3's last outing. Son Josh won all 3 finals just as he pleased.
We tested the TC4 a couple of times shortly after andit didn't take long to convince Josh that it was even quicker and simply better in every way.
So yesterday we ran the TC4 for the first time at the 7th round of our Nationals, and, yes you've guessed - it was the quickest car there by a country mile.
But we didn't win all 3 finals. At the start of the first Josh just pulled away as though there was no opposition. By lap 5 he was already lapping, and T boned an errant back marker and damaged the motor. It was a good and encouraging start, but the retirement meant he would start race 2 from the back of the grid.
Race 2 got under way. Third by lap 3. Second by lap 5. Took the lead for keeps on lap 7 of 22. New lap record in the process too.
Race 3 was a start to finish win.
So you could say the TC4 has taken on where the TC3 left off.
What a car !!!
johnbull is offline   Reply With Quote
Old 03-21-2005, 01:46 AM   #3696
Thanks a lot CRASH
Old 03-21-2005, 05:39 AM   #3697
Formula1fan's Avatar
Any one have a set up for asphalt and foam tires?
Formula1fan is offline   Reply With Quote
Old 03-21-2005, 01:21 PM   #3698
MikeDeadly's Avatar
Location: San Marcos/San Antonio, Tx but chillin in Orlando, FL for now.
Send a message via AIM to MikeDeadly
In looking at all the asphalt set ups I see that most are using a spool. On asphalt what are the performance characteristics of the diff, the spool, and the one-way?? What will each one do to the performance of the car?
And will any damage occur to the diff if I tighten it down enough to act as a spool (i have the lightened steel outdrives btw)?
--Mike
MikeDeadly is offline   Reply With Quote
Old 03-21-2005, 02:19 PM   #3699
Jack Smash's Avatar
Trader Rating: 28 (100%+)
Diff= Car works good under braking, the most understeerish of the 3. Low to med Traction tracks, tight tracks
Spool = Car works good under braking. Car needs different setup to get steering into corner. Great on power steering. Med Traction, tight to more flowing.
OneWay = Car can get very loose under braking. Lots of off power steering. Great on power steering. Med to high traction, open flowing tracks.
To build a Spool, use a set of diff rings to trace out and cut some out of a Parts bag header card. Use in place of diff rings. I take the large diff balls out and use an old thrust assy. Then crank 'er down.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 03-21-2005, 02:42 PM   #3700
brad shearer's Avatar
Jack smash what do you run for gears in a tc4.i just got one
brad shearer is offline   Reply With Quote
Old 03-21-2005, 02:52 PM   #3701
jag88's Avatar
This might be a better place to ask..... has anyone put a TC3 rack into the TC4 ? I understand that it's suppose to really help the car.
Thanks.
jag88 is offline   Reply With Quote
Old 03-21-2005, 02:58 PM   #3702
Jack Smash's Avatar
I have been running a Kimbrough 100tooth spur and anywhere from a 26 to 31 pinion. I have some old Trinity Magic Pinions. I have heard that www.precisionracingsystems.com is who used to make them for Trinity and is now doing it for themselves.
Thanks.
I have never heard of this. I have played around with ackerman shims on the TC4 rack and my favorite for carpet was 2 small shims. I'll measure the thickness when I get home. I am about to start my asphalt testing.
Old 03-21-2005, 02:59 PM   #3703
MikeDeadly's Avatar
Jack,
would it still be ok to do this with the steel outdrives? Or should I use the plastic ones instead?
And when you say the large diff balls are you meaning the ones that are seated in the large ring gear or in the thrust assembly?
--Mike
Old 03-21-2005, 03:06 PM   #3704
Jack Smash's Avatar
I dont think the plastic ones will last as a spool, they barely last as a diff
Oh yeah, spools are hard on front end parts since there is no give in the drive train up there. If you think your gonna smack a board, try to be off power when you hit.
The steel parts are the best to use for a spool and the large balls are the ones in the gear itself. Hope this helps.
Old 03-21-2005, 03:07 PM   #3705
MikeDeadly's Avatar
Thank you........
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
