Team Associated TC4
#3632
TC4 for sale... X-Ray T1 for me.
#3633
ran the tc4 on ashaplt for the first time
hello fellow tc4 racer i ran my car on asphalt this past weekend for the first time, now carpet season start to die dwn the car was handling well i ran the car with blue spring up front silver in bck 4 degree castor shock in stock postion 2.o in rear had the hard sway bar up front but took it off felt the car was not steering well once i done that the car had alot of steering im going to continue to improve on the car i think i should used a lighter sway bar and spacer what yall think
#3635
Originally posted by DOTMAN
Hey F1...do you hav.e Kevin's screen name handy
#3636
jhts got my first on road car!!! I am happy.
Questions for you guys...
how would i gear with a stock spur:
a monster stock
A P2K
An Epic binary stock
A Orion Core
thanks guys
a monster stock
A P2K
A Orion Core
thanks guys
#3637
I do not currently own a TC4, but am considering buying one as a foam carpet car. Is this a good car for foam? I have heard a lot of question marks around the chassis stiffness of the TC4. Do you have to buy an after-market BMI chassis for the TC4? What other tweaks need to be done to make this car work well?
Khal
Khal
#3638
Hi guys, I am looking to get a delrin spur gear for my TC4. I run a Reedy Quad Mag 19T motor on asphalt. What tooth spur do you recommend? I'm assuming I should go with a 64 pitch. Also, what brand of spur gear should I be looking to get, and what size pinion to match? Thanks a lot for everyones help in here.
#3639
Mot guys are running around a 6.10:1 ratio with Reedy 19turns around here. That would be a 100 tooth spur and a 41 tooth pinion. You might also want to get a few smaller pinions to accomodate for smaller tracks and different driving styles. Kimbrough and PRS make good spurs and PRS would be the only pinions I would buy right now. I can't get any other pinion as quiet as I can the PRS.
#3640
Gear ratios: I suggest you ask others at the track what they are running. Since we do not know what the layout/size of the track is, it is very hard for us to hit the right ratio. You would generally want the motor to top out at the end of the longest straight.
Hope this helps
Hope this helps
#3641
Originally posted by MartynD
Fathead, do those fit the TC4?
Looking through that site, that aluminum steering rack looks sweet.
there are for the tc3 so the rear bodymounts are in a differen't place but here you go
http://www.speedtechrc.com/store/ebp...?catmainid=339
#3642
Originally posted by raving-monkey
i just came accross some square CF tower/alu brace thingy on speedtech site
I appreciate the help, but that link doesnt seem to work for me. Where would I find it under?
Thanks.
#3643
#3644
try that
if it still doesn't work
go to speedtech's site - go to the store - go to aftermarket parts - go to square page - go to associated parts
try that
#3645
try that
try that
Thanks buddy.
