Old 03-02-2005, 04:28 AM   #3511
JDM_DOHC_SiR's Avatar
Trader Rating: 30 (100%+)
Default Re: Those parts look nice Dave.
Originally posted by RCknight
Dave do you know if they are working on some nice CF shock towers 4 the TC4?
Doubt it
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64d
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 03-02-2005, 04:33 AM   #3512
Originally posted by johnbull
Hi Dave.
Nice new stuff from Square. I might ask you to buy me a set some time, if that's all right with you.
Your description of your track sounds a bit like ours - medium grip tarmac / asphalt so we could be a bit of help to each other with set ups.
It seems like we might be able to help each other with the set ups
-Dave
BTW you have a PM
Old 03-02-2005, 07:31 AM   #3513
Anyone know where I can get some good ball cups I keep breaking the stock ones. I am using Lunsford turnbuckles.
caleracer45 is offline   Reply With Quote
Old 03-02-2005, 07:32 AM   #3514
RPM
JWATT is offline   Reply With Quote
Old 03-02-2005, 08:40 AM   #3515
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Default Re: Re: Those parts look nice Dave.
Originally posted by JDM_DOHC_SiR
Doubt it
-Dave
i would of thought the CF shock towers from the ntc3 would/should fit as the gear cases are the same (i think)....hang on, they dont use upper turnbuckles, they use pivotballs don't they...so the shocktowers/gear cases might be different...not sure, maybe someone could confirm this.
raving-monkey is offline   Reply With Quote
Old 03-02-2005, 10:29 AM   #3516
Greg Amendola's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to Greg Amendola
So I presume that you beat a very wicked fast BMI Xray? Sounds like your car was dialed all weekend. Wish I could have made it. Is the setup posted the one that you ran at the Hobbyplex?
Yeah, Bill was pretty quick and kept me working to improve my times. The complete results have been posted on www.hobbyplexraceway.com. Bill has a very nice setup, he's certainly got enough equipment
My car was back in form again after a month of neglect. I must say the the setup was awesome in stock, and was pretty good in 19t. When I put the setup into Jari's mod (8x1), he was generating alot more weight transfer...bumping up to the yellow spring settled the car down and he ran some very quick times...
I ran flawlessly in stock, but managed to blow it in 19t. The heat setup made 19t a real challenge as it was 2 heats behind my stock heat (race, marshall, race).
Greg
Greg Amendola is offline   Reply With Quote
Old 03-02-2005, 10:56 AM   #3517
Default PLASTIC OUTDRIVES
ThanksI have a buddy that has been having problems with his front dogbones popping out of the outdrives in very minor crashes in his TC4. First question, has anyone tried putting any type of sleeve over the outdrive to prevent this. If so what was the OD x ID and material used. Second Question, I've been told when upgrading to the Associated TC4 steel outdrives you need to buy several other parts to complete the conversion. Like bearings, d-rings, longer diff screw, ect... Is this true? If so could someone kindly post part numbers.
Davenport is offline   Reply With Quote
Old 03-02-2005, 11:39 AM   #3518
You use the TC3 diff rebuild kit with the associated lightened steel outdrives. Make sure you follow the directions, as some things are now on the "other side". You can find the exploded parts diagram at www.teamassociated.com.
Link to kit:
http://www2.towerhobbies.com/cgi-bi...=LXPA07&P=0
EDIT: I see my link is incorrect, but its easy to find.....
paulct is offline   Reply With Quote
Old 03-02-2005, 01:12 PM   #3519
Default Re: PLASTIC OUTDRIVES
Originally posted by rcman6
ThanksI have a buddy that has been having problems with his front dogbones popping out of the outdrives in very minor crashes in his TC4. Thanks
Yea i've been having that problem but i decided to try a spool and the car drove better and the dogbones never popped out
Chazz
Chazz is offline   Reply With Quote
Old 03-02-2005, 04:16 PM   #3520
Big KAT's Avatar
The picture shows the sleaves I made for that problem, I haven't had any popouts since. I run mostley stock & 19 turn. They are .374 ID and .450 OD, just turned out of 6061 aluminum.
Xray
Big KAT is offline   Reply With Quote
Old 03-02-2005, 04:25 PM   #3521
Default gearing ??'s
I have a gearing question.
I recently acquired a next to new TC4 and I noticed in the manual that the stock spur gear is a 72 tooth 48 pitch, but the TC4 came fresh from the birds and has a 100 tooth 64 pitch spur on it.
It is setup to run 57mm foams.
Any suggestions as to where to start pinion wise.
I think the trans ratio is 2.5.
I know its hard to suggest gearing due to variables, but i'd like to at least get in the ballpark.
Do i need to know rollout to figure this ???
HELP!!!!!
JIMC is offline   Reply With Quote
Old 03-02-2005, 04:26 PM   #3522
Jack Smash's Avatar
Trader Rating: 28 (100%+)
What motor will you be running?
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 03-02-2005, 04:49 PM   #3523
Default duhhhh on my part, sorry
I will either run the brand new EA Motorsports monster or one of two Putnam Excessive Force monsters or I have a brand new Bird handout motor
Old 03-02-2005, 05:13 PM   #3524
Default Square delrin outdrives
Hi guys, could you tell me if you can use the stock diff assembly with the square delrin outdrives? I thought they could be a good alternative to the AE light steel or the IRS, just wondering what assembly they use
Cheers!
Tbevofreak is offline   Reply With Quote
Old 03-02-2005, 05:28 PM   #3525
I run lightened steel on the front (had lots of dogbones popping out with the plastic) and plastic outdrives on the rear.
I've never had a problem with the rear running stock and 19T
MartynD is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
