Like Tree19Likes
Old 02-27-2005, 11:16 PM   #3481
Patriiick's Avatar
i am working on getting some carbon fiber shims to replace the plastic ones.. less flex.. and much more bling..
pm me if you re interested
Patriiick is offline   Reply With Quote
Old 02-27-2005, 11:28 PM   #3482
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
What thickness will you be getting done..?? The PAL ones I have right now do the trick and they are .5mm/1mm/1.5mm if you could get something in the 2mm range that would be good
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-27-2005, 11:46 PM   #3483
utieh's Avatar
-Dave
It will be metric, probably like you said from 0,5mm to 2mm.
We are preparing also some other carbon parts for this car
Gilles
utieh is offline   Reply With Quote
Old 02-28-2005, 01:25 AM   #3484
Gilles
It would be interesting to see what you have in the works
-Dave
Old 02-28-2005, 04:48 AM   #3485
Default Foam Tire diameters
I'm looking for some recommendations on tire diameters for the TC4. I'm new to on road, and have been slowly tweaking the standard setup to my mediocre driving skills!!
I am still using the foams (TRC plaid/purple) out of the box.
I see most people shaving them down quite a bit. I understand the reasoning, but can someone suggest a reasonable starting point?
Some info on breakage, for those who seem to be interested. Given my rookie skills, and quite a few board hits, the only parts that have broken are the front arms (I think I've done 4 so far). Good news is that I can now change them in about 3 minutes!
I got rear ended BIG TIME by a modified who was allowed to run in the stock class "for fun", and it broke the rear hub carrier.
Thats it so far.
Tnx
Paul
paulct is offline   Reply With Quote
Old 02-28-2005, 05:03 AM   #3486
utieh's Avatar
Default Re: Foam Tire diameters
Thats it so far.
Tnx
Paul
I've installed on mine a Yokomo large bumper made for the SD, you have to make the mounting holes bigger but it fits the TC4 pretty good, I didn't have enough crash experiences with the TC4 yet but I used it on my SD and it saved me a lot of front arms
Old 02-28-2005, 06:57 AM   #3487
Patriiick's Avatar
dave : in the works : think "stiffness"
Old 02-28-2005, 07:40 AM   #3488
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Paul
59-60mm is a good starting point. CA the sidewalls as this will help prevent chunking. You also might want to go to Cyan/Magenta, this combo is faster everywhere.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 02-28-2005, 08:49 AM   #3489
Default cyan/magenta
Forgive my total ignorance, but aren't the colors sometimes specific to the mfg? I've heard that the Jaco's have another scheme that seems popular: Jaco double pink/orange front - double pink rear. Would that be the same as cyan/magenta? And is that from TRC?
Thanks!!
Old 02-28-2005, 08:55 AM   #3490
raving-monkey's Avatar
Send a message via MSN to raving-monkey
what is it with all these colours..why can't you be normal and use shore ratings
im in need of some new foams....one of mine has ripped
anyway, anyone got any recomendations (wheels and tyres)...and also what colours are best for 27t and mod carpet racing (medium grip carpet with additive).
thanks
matt
raving-monkey is offline   Reply With Quote
Old 02-28-2005, 08:55 AM   #3491
rayhuang's Avatar
Default Re: cyan/magenta
Thanks!!
TRC and Parma use the term Cyan while Jaco uses the terminnology Dbl. Pink/Orange.
There are subtle differences between them that make for handling differences between TRC, Jaco and Parma-most due to the diameter of the rim and the width of the ornage strip.
TRC and Parma use the term Magenta and Jaco uses Dbl. PInk.
They are all softer than Plaid and Purples.
Hope this helps,
Ray
Old 02-28-2005, 09:03 AM   #3492
Jack Smash's Avatar
The consensus is that Cyan-DblPink/Orange and Magenta-Dbl pink is faster than the old plaid/purple combo under all conditions. The Dbl pink foam is softer than purple however the characteristics of the foam go beyond just being softer. The dbl pink gives less sidebite and more forward bite. This helps the car rotate but allows you to still put the power down off the corner.
Old 02-28-2005, 05:49 PM   #3493
losixxxs's Avatar
what diff nut do i use on the irs lite diffs
thanks
travis
losixxxs is offline   Reply With Quote
Old 02-28-2005, 06:25 PM   #3494
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
It's PN 6575. Thats what I used when I had them, they worked fine.
Paul_TC4 is offline   Reply With Quote
Old 03-01-2005, 12:23 AM   #3495
if the irs uses a t nut then you need the screw and nut from the ntc3 diff.....thats exactly what i used in my steel diffs (AE ones) and they work fine.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
