Like Tree58Likes
Old 10-01-2004, 07:48 AM   #331
anit dive will give less weight to the rear and give you less traction to the rear on power it shoud make the car come into the corner better hope that helps
joshprostek is offline   Reply With Quote
Old 10-01-2004, 08:10 AM   #332
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Hmmmm.... Triangle, Square, Circle, X, I bet there was a Playstation 2 controller somewhere near by when you "pimped" them?
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
Old 10-01-2004, 10:31 AM   #333
diskostew's Avatar
Send a message via Yahoo to diskostew
Yea i would bet it was PS2... that is just one more reason why Associated rules! I can't wait for the TC4....
diskostew is offline   Reply With Quote
Old 10-01-2004, 02:04 PM   #334
Tony, What's up? Yep I recieved mine this week and have been busy at the track testing carpet setups. After 4 packs it's already as fast as my TC3. The future is bright!
Eric Desrosiers (Old) is offline   Reply With Quote
Old 10-01-2004, 03:23 PM   #335
How did you get yours already????? I need one. I found parts, but no place has the kit yet.
TC4 Parts
TC4 Rider is offline   Reply With Quote
Old 10-01-2004, 04:19 PM   #336
linger's Avatar
Originally posted by TPhalen
...You will be able to run shims under each block (in .25" increments) to raise or lower the arm mounts for different situations. On the TC3, the standard height arm mount was great for asphalt, concrete, etc., but sucked for carpet. Most hardcore racers would mill down their blocks to lower the arm mounts for carpet....a task only the guys with milling machines could do. Now, that's a thing of the past.
TP: .25" increments??? That's 6.35mm...that's a LOT. Do you mean .025" increments?
Hmm...carpet season is coming up.....
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 10-01-2004, 04:28 PM   #337
Moderator
Speedo's Avatar
.025" sounds much better. I have .08", .05", and .03" off blocks for my TC3. Looks like Associated is going to be making aluminum versions of the blocks, at $13 each. Should be much more durable than the plastic ones that come with the car, which are prone to wearing out very fast.
$70 list price for the graphite components kit is very good, provided it includes all available graphite pieces.
Josh
Speedo is offline   Reply With Quote
Old 10-01-2004, 04:42 PM   #338
JimmyMac's Avatar
Tony or Barry, I have a tuning question for you guys concerning camber link adjustments.
Now I know, generally if you need traction say... in the rear.. you would either raise or lengthen the rear camber link. My question is... what is the difference in raising it vs lengthing the camber link? Does one offer more midturn traction vs the other or visa-versa? One offer more exit? More goin in?
Thankyou...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 10-01-2004, 05:35 PM   #339
HK Racing Joe's Avatar
Send a message via AIM to HK Racing Joe
I say don't go over 2 the TC4, from the looks of it it's as fast if not slower than a warpspeed or a BMI
HK Racing Joe is offline   Reply With Quote
Old 10-01-2004, 06:04 PM   #340
Default I'm wondering if AE waited too long to release a...
new car. With the other chassis brands out there no one may get the TC4. AE should have done some more tweeking. Perhaps a new shock design, chassis lightening (cell openings) A quick shaft release method. Designed it with the use of cvd boots and etc. They should have went all out on every little detail. Make it less prone to tweeking. My 2-cents.
Nightbreed is offline   Reply With Quote
Old 10-01-2004, 06:05 PM   #341
Moderator
Speedo's Avatar
Haha, you must be pretty skilled to be able to tell how fast something is just by looking at it
The Warpspeed or BMI chassis don't have the updated suspension.
Josh
Old 10-01-2004, 06:14 PM   #342
TPhalen's Avatar
Josh
HAHAHHA, ya, I just went to Warpspeeds and BMI's web sites and after looking at the cars online, I KNOW the TC4 is faster! Funny stuff!!!!
Ya, thanks Ling....it's in .025" increments. DOH.
Eric: when you get a good setup, please send it to us!!! Thanks bud!
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 10-01-2004, 06:16 PM   #343
TCR
Tony you need to make an ask
TQ Tony Phalen Topic =)
No thanks....not unless you work at the Playboy Mansion and make lots of money....then I might think about it
Thanks.
The arm mounts are now labeled with symbols instead of a letter....ie, the TC3 mounts were labeled F+2, F, R, and R3+2 (for instance). When someone asked you what F block you were running, you had to say F+0 or F+2, if you even knew what they meant.
The new labeling system is pretty cool. If you pay close attention to the labeling, you should be able to see where we 'pimped' the labels from.... Anyway, the labels are as follows: Triangle (replaces the F+2 block), Circle (replaces the F block), Square (replaces the R block), and X (replaces the R3+2 block). You will be able to run shims under each block (in .25" increments) to raise or lower the arm mounts for different situations. On the TC3, the standard height arm mount was great for asphalt, concrete, etc., but sucked for carpet. Most hardcore racers would mill down their blocks to lower the arm mounts for carpet....a task only the guys with milling machines could do. Now, that's a thing of the past.
Just alot more tuning adjustments for a wider range of surfaces.
TCR is offline   Reply With Quote
Old 10-01-2004, 06:19 PM   #344
John Tag's Avatar
Trader Rating: 42 (100%+)
All I can say is when I went from a tub to the BMI chassie on my TC3 I went 3 tenths quicker than I ever had.I hope the same thing is so when I build a BMI TC4.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 10-01-2004, 06:35 PM   #345
Default I was thinking. TPhalen...
I'm sure you can chime in here, but I have read that Losi keyed in the CF plates so it won't tweek.
I could see how it would help to keep things from shifting, but don't the carbon fibers contribute to tweeking. It's the twisting motion from a collision that makes it weaken over time. From my expirence it does not take a long time for this to happen. I'm sure a tub chassis would be less prone to this.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
