Like Tree19Likes
Old 02-17-2005, 04:40 AM   #3391
Default Re: What kind of proto type stuff...
Originally posted by RCknight
was Baker using at the Birds? Some new shaft, stronger shock towers?
I dont know all of it, but from the pics I saw a piece of CF or FiberGlass that was bolted on his shock towers to strengthen and stiffen them. And as for a setup let me find it on this board. I put a carpet setup that I got from this forum that was the bomb.
Edit: https://home.comcast.net/~travissurr...20Amendola.pdf ran this on a small carpet track. Loved it.
runnin rc10 is offline   Reply With Quote
Old 02-17-2005, 09:56 AM   #3392
Registered User
tomlau's Avatar
Default bearings
hi,
im trying to get a little more out of my transmission. i have removed all the inner bearing shields of the stock bearings. at the moment the bearings are compleetly dry. is it ok to run them like that? even the tiniest ammount of bearing lube seems to add loads of drag
tomlau is offline   Reply With Quote
Old 02-17-2005, 10:24 AM   #3393
ChrisP's Avatar
Send a message via Yahoo to ChrisP
As the bearings warm up the viscosity of the lube will go down allowing it to free up...
don't be so hung up on how long your drivetrain will spin....
ChrisP is offline   Reply With Quote
Old 02-17-2005, 10:33 AM   #3394
Use light oil, it doesn't add much drag at all
MartynD is offline   Reply With Quote
Old 02-18-2005, 03:40 AM   #3395
No, if you don't add some bearing lube they will wear very quickly
When you run the car bearings get hot, lube helps to protect them.
Lube gives the feeling that is adds some drag but when running the car it has absolutely no drag effect
It will make them run less noisy also
Tbevofreak is offline   Reply With Quote
Old 02-18-2005, 10:10 AM   #3396
RacingStorm's Avatar
Default PRS Spur Gear
Any of you mounted up a PRS spur gear on your TC4 yet?
It appears that it is thicker where the mounting holes are and have heard of people having issues with the screws hitting the standoff.
I'm looking to put one on but want to know what I am getting myself into...
RacingStorm is offline   Reply With Quote
Old 02-18-2005, 01:29 PM   #3397
If you use one of the ones that is designed to have 1/8" diff balls snapped into it, I would think it would be about the same thickness as a Kimbrough. I've been using a 96t Kimbrough - I have a PRS gear, but it is too large, so I didn't try to install it. I can measure it if you want though.
Corner Weight is offline   Reply With Quote
Old 02-18-2005, 02:32 PM   #3398
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Re: PRS Spur Gear
Yes the PRS spur gear fits. I am using a 100T 64pitch. Just make sure that it is for a touring car.
Later,
CRASH is offline   Reply With Quote
Old 02-18-2005, 02:59 PM   #3399
raving-monkey's Avatar
Send a message via MSN to raving-monkey
agreed,a drivetrain that spins for ages will often have a large rotating mass....yes i admit a free drivetrain will spin for longer but a large rotating mass carrying a lot of momentum will allow the drivetrain to spin for longer.
if you run your bearings dry then they will get hot and often collapse..or collapse easier than a lubed bearing (this was the common cause of xray layshaft bearings collapsing..getting to hot from them running dry)
i run all my bearings with both sheilds removed (apart from the small metal shielded bearings) with a drop of LRP bearing oil in each one....after each run i spray a bit of motorspray (well mine is solvent spray, works same but smells nicer..muahaha lol) in each hub bearing and drop a bit of bearing oil there, they seem to run nicely and they aren't feeling gritty yet..i have run them shieldless since i built the car.
raving-monkey is offline   Reply With Quote
Old 02-18-2005, 07:14 PM   #3400
ghoppa's Avatar
Trader Rating: 50 (98%+)
Default TC4 Set Up for So Cal
Me and my buddy are drivin down from Vegas to run tomorrow....
Anybody got a good starting set-up for SoCal that I can try?????
RCAmerica - Xray - R1 Wurks - ActivRC - Hudy - ApexRC - Jgo Paintz - P1 Brands - 702 RCRaceway
ghoppa is offline   Reply With Quote
Old 02-20-2005, 01:19 AM   #3401
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: I wonder if...
AE will ever incorporate the lightened chassis mods into the TC4? This car has flex issues on carpet.
From what I have heard they are making some small chages to the chassis by the time the FT kit comes out.. maybe a tad bit stiffer not 100% sure on it though
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-20-2005, 04:20 AM   #3402
Hebiki's Avatar
Default Re: TC4 Set Up for So Cal
Tony Phalen's website... www.competitionx.com
has a set up for socal. it MIGHT be for mod tho. but its worth a look. here's a direct link: http://ebiz.netopia.com/competitionx/racingsetups1/
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-20-2005, 09:38 AM   #3403
diskostew's Avatar
Send a message via Yahoo to diskostew
Default Re: Re: TC4 Set Up for So Cal
That setup is for mod. but i started with it for my stock setup. it worked fine. but then i made some tweaks from there. the ones that stand out on my setup are that i am running the same size sway bar up front and in the rear (black) . I also preloaded my front right shock just a little bit to keep the rear end on the ground better. if you want my setup, PM me and i will send it to you.
Jay
diskostew is offline   Reply With Quote
Old 02-20-2005, 09:49 AM   #3404
RCknight's Avatar
Default I would like the stiffness, but more weight?
I wish AE would incorporate shock braces into the top diff case like the Pro 4 so that we could run CF shock towers. It would be nice to get the extra stiffness. I would have no problem with version2 transmission cases. Molded graphite diff cases?
RCknight is offline   Reply With Quote
Old 02-20-2005, 11:14 AM   #3405
ghoppa's Avatar
yeah, thanks for the info...
just back home from the trip to So-Cal, but never realized the amount of stock & 19 turn out there and "no" sportman" mod racers (it's hard to run with the factory guys).....
I do wanna say that me and my buddy had a "blast" but we were definately not in the right class......
next trip 19 turn and stock (FOR SURE)....
you all that have So-Cal as your home track don't realize how lucky you ALL are!!!!!!
see you all soon....
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
