Like Tree59Likes
Old 02-14-2005, 06:06 PM   #3346
Soviet's Avatar
Originally posted by CRASH
Why the concern with lightening the car? The car is extremely capable of winning.
Because everyone in here is a sponsored professional who have no other way to drop their lap-times other than by milling away .00000000159 grams of weight.
People...just DRIVE!!!!!!
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 02-14-2005, 07:19 PM   #3347
CRASH's Avatar
Trader Rating: 26 (100%+)
Originally posted by Jack Smash
Ok guys, I need a little help. I am usually good at getting corner speed out of my setup but right now the xrays are killing me. So let's hear some ideas.
Carpet Setup
Front:
60wt #3 piston
Copper spring
Shock mounted inside hole on arm, 2nd from out on tower
4 deg caster blocks
camber link middle hole 3 spacers
outside hole on steering block
1 bump steer spacer
1 .025 arm mount shim on circle mount
no arm mount spacer on triangle
1 thick (offorad shock seal spacer) on rack
1 shim in fornt of arm, 2 behind
0 deg toe
5mm ride height
Rear:
40wt #3 piston
Red Spring
Outside hole arm, 2nd from out on tower
camber link inner hole, no spacers, inside hole on hub
no arm mount spacers
3 shim in front of arm, 0 behind
2.0 deg x block
5mm ride height
Diffs set per instruction
Parma cyan and magentas 58.5 - 59mm
Parma Alpha
Ti based 10dbl
everyone is about the same speed out of the corner and down the straight.
Car feels very balanced and feels fast. The other cars are just cornering faster. I am losing .2 to .3 tenths a lap and not sure what to change. I tried running some pro-squat but made the car just a little wierd transitioning to on power and didn't really help the rotation like I wanted. No real tight corners on this layout, mostly a series of 90s and some fast switchbacks.
Try going to #2 pistons all the way around and try the middle size sway bar up front.
What are you running for droop?
Later,
CRASH is offline   Reply With Quote
Old 02-14-2005, 07:23 PM   #3348
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Added droop and sway bar to post. Droop works out to about a 6 on the front and a 5 on the rear per the AE gauge.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 02-14-2005, 09:21 PM   #3349
It has nothing to do with being sponsored or thinkin I am. I just think the car feels heavy and sluggish in the corner. I just was BMI Xrays and pro-4's fly in and out of the corner with little or no work. Im tryin to get the car to where I can just drive just tryin to find out what works best. Everyone was milling on there TC3's for "transitional" handling couldnt have picked up that much time, it just made the car that much easier to drive.
runnin rc10 is offline   Reply With Quote
Old 02-15-2005, 03:10 AM   #3350
Hey guys, I plan on running a Reedy 19T quad mag in my TC4, and I was wondering what tooth pinion would be best to start with. Also, do you guys use the motor clamp spring the tighten down the motor or just use a regular screw without the clamp? I saw Barry Bakers car in the pics and it looks like he was just using regular screws. If so, what length screw shoud I use? Thanks in advance.
speedaddict is offline   Reply With Quote
Old 02-15-2005, 03:31 AM   #3351
utieh's Avatar
You should keep the screw if you don't want to strip the screw.
I don't how's your track but on a medium size indoor carpet track with my 17T I'm have a 28-72 combo, probably you should start with a 29 or 30T pinion gear
utieh is offline   Reply With Quote
Old 02-15-2005, 06:19 AM   #3352
CRASH's Avatar
Is the carpet extremely high bite? You might also try going to the #2 spacer front and rear for roll center. That is O=2 Triangle=2 Square=2 X=2. Then try removing 2 shims from the front. Then try running the rear camber link as RBlove would say "FULL LOOOOOOONG"
Later,
Old 02-15-2005, 06:42 AM   #3353
It should just reach top rpm at the end of the longest straight. On our track, we run a 28/100 (64p) with our 19's.
JWATT is offline   Reply With Quote
Old 02-15-2005, 11:45 AM   #3354
Thanks, I will try the 30 Tooth out for starters.
Did you mean that I should use the spring clamp that is included?
Old 02-15-2005, 01:09 PM   #3355
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
Hey guys,
I need a bit of setup help as well.
I need a starting point for running the shims under the X,O etc. blocks for Ozite Carpet. 19t spec motors.
Also my car seems a little too loose in the rear. What should I do to gain some more traction in the rear?
Swaybar possibly?
Front:
60wt. #2 pistion
Purple Spring
Inside Hole on the Arm, 2nd from innermost on tower
0* Toe
Rear:
40wt. #2 pistion
Copper Spring
-2.5 toe aluminum block in the rear
Outer Hole on arm , 2nd innermost on tower
Purple/Plaid Tires
Paul_TC4 is offline   Reply With Quote
Old 02-15-2005, 01:54 PM   #3356
Originally posted by Paul_TC4
Hey guys,
Swaybar possibly?
Front:
60wt. #2 pistion
Purple Spring
0* Toe
Rear:
40wt. #2 pistion
Copper Spring
Purple/Plaid Tires
On ozite we are running the dlb pink/ dbl pink orange tires and the rear shocks are 2nd farthest out on tower and outside on arm. With purple springs. Im still running no shims under any of the arm mounts. Im about to exp more with it. Its just soo many tuning options and combnations that it can get a bit crazy. I think we are running #3 pistons in the rear too. Not sure on that though.
edit: rear oil weight is a little light too...we are running 50 wt.
Old 02-15-2005, 02:17 PM   #3357
Paul_TC4's Avatar
Runnin, I agree. There are a bunch of tuning options that get me confused as well. Thanks for the reply.
Old 02-15-2005, 03:06 PM   #3358
Thats why everyone is so confused with the setups on these cars. But they are slowly gettin there.
Old 02-15-2005, 03:14 PM   #3359
I need some help on the shock pistons is 1 the softest and 5 the stiffest?
caleracer45 is offline   Reply With Quote
Old 02-15-2005, 03:31 PM   #3360
Jack Smash's Avatar
1 is the biggest holes= softest
3 is the smallest holes = firmest
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
