Like Tree32Likes
Old 09-30-2004, 06:30 PM   #316
Anybody have a release date on this car yet? Will they be as hard to get a hold of as the REVO was when it came out?
TC4 Rider is offline   Reply With Quote
Old 09-30-2004, 06:45 PM   #317
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by TPhalen
JDM_DOHC_SiR: you have a response!!!
Thank Youuuuuuuuuuuuuuuuu
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 09-30-2004, 07:19 PM   #318
Default TPhalen....
can we trade lives? I have always wanted your job! You get all the cool stuff first? That's just wrong!
Nightbreed is offline   Reply With Quote
Old 09-30-2004, 07:31 PM   #319
Default Is there any other company that makes a titanium...
input shafts for the TC3/4? I guess the "Titanium Racing" shafts are bad quality and you can't get them anymore. Anyother company come to mind?
Old 09-30-2004, 07:48 PM   #320
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Square makes aluminum ones...
Speedo is offline   Reply With Quote
Old 09-30-2004, 07:59 PM   #321
Default Ha, I know IRS makes one, but...
I thought a titanium would hold up better.
Old 09-30-2004, 08:00 PM   #322
The Square ones are a very good Quality... Crest Speedway in Japan also makes a nice set for the TC3 also..kind of $$$ though.
-Dave
Old 09-30-2004, 08:06 PM   #323
Default Is the Crest one titanium?
Do they have an on line website to order from?
Old 09-30-2004, 09:16 PM   #324
JimmyMac's Avatar
I believe TeamBomber/G-Style also makes aluminium input shafts for the TC3 as well. Except these input shafts are one peice with the drive cups on them. Only problem is finding these parts. R10 doesn't have them.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 09-30-2004, 09:39 PM   #325
JimmyMac's Avatar
Hey Tony... I like the editable setup sheet! That's nice!!
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 09-30-2004, 10:04 PM   #326
Moderator
Speedo's Avatar
Tony, how do the triangle and circle shims work?
Josh
Old 09-30-2004, 10:18 PM   #327
Kilruf... PM me... I know of a place that has a few in stock
-Dave
Old 09-30-2004, 10:54 PM   #328
TPhalen's Avatar
No thanks....not unless you work at the Playboy Mansion and make lots of money....then I might think about it
Thanks.
The arm mounts are now labeled with symbols instead of a letter....ie, the TC3 mounts were labeled F+2, F, R, and R3+2 (for instance). When someone asked you what F block you were running, you had to say F+0 or F+2, if you even knew what they meant.
The new labeling system is pretty cool. If you pay close attention to the labeling, you should be able to see where we 'pimped' the labels from.... Anyway, the labels are as follows: Triangle (replaces the F+2 block), Circle (replaces the F block), Square (replaces the R block), and X (replaces the R3+2 block). You will be able to run shims under each block (in .25" increments) to raise or lower the arm mounts for different situations. On the TC3, the standard height arm mount was great for asphalt, concrete, etc., but sucked for carpet. Most hardcore racers would mill down their blocks to lower the arm mounts for carpet....a task only the guys with milling machines could do. Now, that's a thing of the past.
Just alot more tuning adjustments for a wider range of surfaces.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 09-30-2004, 11:00 PM   #329
What does cutting the blocks down do? I have heard of the cutting of the front block to give anti dive. Is this what you are talking about.
mtc3od is offline   Reply With Quote
Old 10-01-2004, 06:33 AM   #330
TPhalen's Avatar
Yes
Tony Phalen
RCDriver.com
CompetitionX.com
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
longuylander
