Like Tree36Likes
Old 02-05-2005, 05:11 PM   #3241
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
I know but im thinking of getting out of this hobby
Roberto Falcon is offline   Reply With Quote
Old 02-05-2005, 09:43 PM   #3242
AND WHY ON EARTH WOULD YOU WANNA DO THAT?!
runnin rc10 is offline   Reply With Quote
Old 02-06-2005, 01:49 AM   #3243
RCknight's Avatar
Default best way to mill a chassis?
Any tips on the best way to mill out a chassis? I want it to look good and I don't want to ruin a good chassis. I want to do the cell slots, center brace (How many mm should I go on that?) and under the transmission cases.
RCknight is offline   Reply With Quote
Old 02-06-2005, 02:35 AM   #3244
fathead's Avatar
You will need to get access to a milling machine first and then you will prob want to use about a 8-10mm (3/8" I think) end mill to do the work.
Slavich Design
fathead is offline   Reply With Quote
Old 02-06-2005, 04:10 AM   #3245
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: best way to mill a chassis?
Go 3.5mm on the center brace and use a 5/8 bit for the battery slots and for the holes under the gear boxes
it comes out perfect
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-06-2005, 04:21 AM   #3246
I got the yokomo shock caps and bladder.I want to know that if the bladder will touch the shock piston before i fix it.
nicholasracing@ is offline   Reply With Quote
Old 02-06-2005, 04:30 AM   #3247
Originally posted by LoSi xXx S
alright i know that the rear needs to be softer than the front ! but my car is the other way around the rear is harder than the front right now i have #2 piston 30 weight oil and blue springs on the rear and #2 pistion 40 weight oil and gold springs on the front and the rear is still heaiver and the shock poistion on them are the same ! whats wrong!!! ????
Don't get hung up on the idea that the rear should be softer than the front. I have found that the TC4 works great with the same spring/piston/fluid setup on all four shocks and that it likes to be sprung much lighter than a TC3.
What kind of track are you running on?
NHRCRACER is offline   Reply With Quote
Old 02-06-2005, 07:20 AM   #3248
Same here
but I have found that the car also likes high roll centers on high bite asphalt too
I have about 3 really good setups for medhigh~high grip tracks right now for 19T and up motors that are really easy to drive :nod and carry great corner speed with a fairly good amount of turn in
-Dave
Old 02-06-2005, 08:19 AM   #3249
diskostew's Avatar
Send a message via Yahoo to diskostew
They will touch the bladder if you don't have your shock ends screwed all the way on. if the piston hits the bladder too hard it will make the shock leak. screw the shock end (the bottom ball cup part that attaches to the arm not the shock tower) all the way in. that should fix it. but make sure your shocks are still the same length.
diskostew is offline   Reply With Quote
Old 02-06-2005, 08:25 AM   #3250
ChrisP's Avatar
Send a message via Yahoo to ChrisP
If you're travelling that far, that hard with your shocks then you may have other concerns than your bladders holding up....
TeamXray.com
Team Tekin
ChrisP is offline   Reply With Quote
Old 02-06-2005, 09:44 AM   #3251
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default shocks
MY SHOCKS on my car make a squeeling nosie when i push the rod in. is this bcuz air is in the shocks or? ny info well appreciated
crACkeD ChaSsiS is offline   Reply With Quote
Old 02-06-2005, 10:37 AM   #3252
Default Question
I run stock carpet foam tires..
what are some ways I can free up the rear end with out it sliding around.?
I running the newest baker setup off the Ae site. and its good most everywhere on the track, there is a switch back section that everyone eats me up in. I cant get the to transition that fast in tight stuff.The car will just push a hair..
Thanks for anyinfo
StartBuck is offline   Reply With Quote
Old 02-06-2005, 10:43 AM   #3253
ChrisP's Avatar
The Stelleflue setup for stock on foams seems pretty good...planted off power and a very slight push on power...you may want to give it a try
TeamXray.com
Team Tekin
Old 02-06-2005, 11:00 AM   #3254
Good result for the TC4 over here today.
I managed to stick mine into first place in the B in 27 Turn Stock at this years Carpet Thrashnal Series, but CML/Associated Driver Olly Jefferies has sealed the 19T championship title with 4 out of 4 wins.
Incidentally the TC4's were on form in 19T with positions 1-6 on the A final grid all being TC4's.
Andy M is offline   Reply With Quote
Old 02-06-2005, 12:21 PM   #3255
I saw your car today andy, it looked really good. Like andy said the tc4s were just taking over 19T. Wish i had run my tc4 today, had a rubbish day with my tc3 qualified 6th in the C except for the top 20 i usually aim for .
Chazz
Chazz is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
