Like Tree59Likes
Old 02-04-2005, 06:40 PM   #3211
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
Hey guys,
I just came across a serios problem with my TC4. I just installed both steel outdrives. Both are built correctly and nice and smooth.
Now, when I put both diffs inside the car and spin the wheels, the input shafts pop off. Im pretty sure this is because of a mesh that is too tight. So I tried every possible shim combination, and now my drivetrain binds pretty bad. I even shimmed the input shafts and had no luck.
Does anyone have any idea on what the probelem is. I just want a drivetrain with no binding. Not this 10 sec. nonsense.
Thanks,
Paul_TC4 is offline   Reply With Quote
Old 02-04-2005, 07:51 PM   #3212
Paul_TC4's Avatar
what I also noticed is that when I spin the wheel one way its quiet but once I spin it the other way it makes a loud grind sound.
Old 02-04-2005, 07:51 PM   #3213
Trader Rating: 76 (100%+)
Default Diff
GDay guys,
Want go into detail but does anyone know if the yokomo one way diff fits the tcs3/4's I was told they do ,Just i am in desperate need to get the tc running for tomorrow and havent got a rebuild kit for it but ihave a spare yoke oneway here
Please can anyone help with this
It would be much appreciate
Do you won't free Post on your items, PLEASE contact AUSTRALIA POST to confirm your eligibility and enter your code number here. Otherwise standard rates apply. Why don't people haggle or complain with o/s postage but always want local postage for free or moan like their left hand was cut-off, Come on guys Aus post do have set costs , it isn't the seller trying to rip you off.Items must be sold. All reasonable offers considered
addicted is offline   Reply With Quote
Old 02-04-2005, 10:08 PM   #3214
RCknight's Avatar
Default Does anyone know what page the
TC4 battery mod is on. I checked and I can't find it anywhere.
RCknight is offline   Reply With Quote
Old 02-04-2005, 10:43 PM   #3215
Jack Smash's Avatar
Trader Rating: 29 (100%+)
http://www.rctech.net/forum/showthre...38#post1309238
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 02-04-2005, 10:44 PM   #3216
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default WEbsite here
Here u go man. i had a hard time finding it myself!
http://ca.geocities.com/[email protected]/index.htm
crACkeD ChaSsiS is offline   Reply With Quote
Old 02-04-2005, 10:54 PM   #3217
ChrisP's Avatar
That's the TC3 mod......he's looking for the TC4 battery strap mod...but it's ok...someone else pointed him to the post
ChrisP is offline   Reply With Quote
Old 02-04-2005, 11:01 PM   #3218
Default aluminum vs stcok driveshaft?
is the aluminum driveshaft better/lighter than the stock graphite one?why do i see so many people run these over the stock one?
Old 02-04-2005, 11:34 PM   #3219
cracked... the TC4 comes with aluminum...
Looking for some setup help... or perhaps its my driving...
Any tips on how to help both a lack of turn in at hi speed under power, and pushing thru low speed turns when i try and give the car some power. This is for is for hi-traction carpet
Front
Med sway on the front (went from softest to med - no noticeable change)
red springs
50wt Trinity oil
4 deg caster blocks, stock shims (totals 6 deg caster)
1 deg toe in
stock shock positions
rubber tires
2 deg camber
stock wheelbase shim positions
Droop 1.5mm
Rear
no sway -backordered
40wt trinity oil
tried both gold and copper springs same result
2 deg toe in (stock shims)
1 deg camber
wheelbase set forward with all hinge pin spacers at rear
Droop 2.5mm
Batteries positioned to the front
HPI Stratus (v1) baby wing
From the lack of difference the changes have made I am starting to think its either A) lack of rear sway or B) trigger finger
I run wide through the hi-speed sweepers, and I can't get around the slower turns very tight and push pretty hard on exit.
Oh yeah ball diffs front and rear.
Off the power the car has lots of steering, but it seems relative to others on the track I am losing alot of time in the slower corners.
Anyways, I am open to suggestions... even if it is all in the finger
MartynD is offline   Reply With Quote
Old 02-04-2005, 11:53 PM   #3220
johnbull's Avatar
Originally posted by utieh
I just love Minis but the only one I can afford is a RC one,mostly because renting a parking place in Paris is very expensive and I would never let my Mini out by night Do you still own one???Do you have some picture???
Gilles (Utrieh),
For the first time in over 40 years, I do not actually own a Mini Cooper. Son Josh wrote my last one off a couple of years ago. But we still have a Mini connection. The one in my avatar is the 16 valve Mini I raced myself up to a couple of years ago. It belongs to my brother and he races it at the moment.
We have built up a Terrapin (Mini engined single seater) for Joshua to drive. In fact we have a hill climb this weekend.
I have plenty of pics. I will send yousome in a private e mail as this is not the right place for it.
johnbull is offline   Reply With Quote
Old 02-05-2005, 12:07 AM   #3221
Jack Smash's Avatar
Most carpet setups with rubber tires use a one way. I would go with one but you would have to tune the setup to remove some off power steering but both high speed and low speed steering would benefit with one.
To try and tune your current setup with diffs, i would remove the front sway bar and go from one degree toe in the front to one degree toe out. It will help the car point into the corner and should help with low speed steering.
Raisng the rear roll center or lowering the front might also be a couple of things to try.
Don't forget, make only one change at a time so you can feel what each change does.
Old 02-05-2005, 12:38 AM   #3222
utieh's Avatar
Addicted: I tried the Yokomo one way diff for the SD I had and it's too large (1 or 2 mm)
Yokomo is making a oneway housing:
Yokomo SP-3967-6 One-way housing for HD front one-way
and you can buy the oneway bearing separately from Yokomo and probably from Squat too (not sure):
Squat 126 One-way bearing (2pcs)
You will need also special outdrives (inside diameter is 6mm like on the SD)
JohnBull: Thanks, I'll send you an email later I'm very curious
utieh is offline   Reply With Quote
Old 02-05-2005, 08:53 AM   #3223
Hey guys, since I'm runing my TC4 my ESC/motor gets very hot after 3-4 mins of runtime, this never hapened with my evo3S
The drivetrain is nice and free so I don't know where its coming from
I tried different motor/ESC and it still very hot and the gearing is fine too..
Can you guys help me please? Can it be the bearings? the ones on the cvd's?
Thanks in advance!
Tbevofreak is offline   Reply With Quote
Old 02-05-2005, 08:58 AM   #3224
What motor? What gearing?
Old 02-05-2005, 11:13 AM   #3225
I was using a 12*1 HT V2/lrp v7.1 and GM 12*2/quantum pro geared at 6.6 but when I took out the motor I realized the drivetrain wasn't free at all but it was fine before runing the car so I had to re-shim the drivetrain again, I also took one side of the ruber sealed bearing off to make them more efficient
Now everything is back to normal but I didn't have time to run the car after to check if it got better, perhaps I should check the wheel bearings and take off one side off the ruber also
One thing I'm sure of, the motors/esc never got so hot so there has to be something puting stress on the motor
Oh, I also checked if the wheels weren't too tightened
Have to wait until tomorow now, hope it will be ok cos I'm going to the track if the weather is not too bad
any sugestions would be helpful!
cheers!
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
