Like Tree18Likes
Old 02-04-2005, 02:55 PM   #3196
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default weight
whats the average weight of a factory graphite tc3 with high end electronics?
crACkeD ChaSsiS is offline   Reply With Quote
Old 02-04-2005, 03:12 PM   #3197
I used grease last time but im not going to with this most recent rebuild. The grease thins out bad and its getting all in my bearings and leaking out of the case and just making a mess. I dont think many shims are needed for this car to get it where it should be.
runnin rc10 is offline   Reply With Quote
Old 02-04-2005, 03:17 PM   #3198
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
i dont use grease on my gears only where the diff balls are at
Roberto Falcon is offline   Reply With Quote
Old 02-04-2005, 03:29 PM   #3199
diskostew's Avatar
Send a message via Yahoo to diskostew
don't use grease! use stealth diff lube
diskostew is offline   Reply With Quote
Old 02-04-2005, 03:34 PM   #3200
diskostew's Avatar
Default asphalt good traction setup???
Ok who has a setup for good to high bite asphalt traction setup? I have my car close but it still needs something. It handles pretty good but has a weird high speed push that doesn't want to go away.
Anybody have any suggestions?
Old 02-04-2005, 03:59 PM   #3201
Default Birdman diff lube
has ny1 tried Birdman diff lube for tc3/tc4? is it good to use or?
Old 02-04-2005, 03:59 PM   #3202
thats what I mean, the diff lube.....im not gonna put it directly on the gears anymore...did more harm than benefit i think.
Old 02-04-2005, 04:23 PM   #3203
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: asphalt good traction setup???
I have a awesome High Bite Asphalt set up that will work with 19T and above motors
PM me and I will send it to you
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-04-2005, 04:33 PM   #3204
Default Pro4 shaft
will the pro4 shaft fit on a tc3/vice versa?
Old 02-04-2005, 04:36 PM   #3205
Default Re: Pro4 shaft
Nope too short
Old 02-04-2005, 04:38 PM   #3206
diskostew's Avatar
JDM_DHOC_SiR:
you got PM
Old 02-04-2005, 05:05 PM   #3207
JDM_DHOC_SiR:
you got PM
I sent you a PM with the High Grip Set up
-Dave
Old 02-04-2005, 05:07 PM   #3208
ghoppa's Avatar
Trader Rating: 50 (98%+)
Default sway bars
hey guys,
question:
"How do you "correctly" set the car up with the new sway bars?" I am very confident that I can set a touring car "correctly", but for some reason, I am puzzled.....
I am setting the car up for tomorrows race in town.
this is the steps I take
1. set ride height (measure shock pre-load as well)
2. place car on a set-up gauge (to determine camber & toe)
3. re-set ride height (should be okay, but "maybe" slightly off)
4. set droop (no shocks or sway's are "connected")
5. re-install shocks & sway bars
6. check tweak (I have the Integy Laser one)
"Now how do I corectly set the Sway bars up??????"
can anyone help me out, I know they can adjust from the access hole on the bottom of the arms, but how do I do this correctly???
ghoppa is offline   Reply With Quote
Old 02-04-2005, 05:15 PM   #3209
Default Re: sway bars
I pretty much have set them up by 1st measuring them with a set of digital calipers and then adjusting them to the same lenght.. next I would adjust them on the car to make sure that both sides would react the same with the shocks taken off (equal movement on each sus arm)..
I`m sure there is more but this is what I have found to work the best for me
-Dave
Old 02-04-2005, 05:21 PM   #3210
Bob Nilsen's Avatar
Originally posted by Tbevofreak
Whats the average weight of a body?
See ya!
My Parma Alfa weights 98 grams painted.... and it's trimmed pretty standard.
Bob Nilsen is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
